What did you do with your 987 today?
Old 10-08-2021, 03:56 PM
  #436
The Boz Abides
The Boz Abides's Avatar
Originally Posted by palestar
Just picked up a 2007 Boxster S that needs a little love. First order of business is fixing the convertible transmission gear. Top was making a pretty bad knocking noise, which is now totally fixed. Thankfully the driver side had already been upgraded! $45 in parts and a few hours work and my top is 100% functioning and smooth.
Great work! How easy was the fix? My 2009 operates but seems to be making the same sort of knocking noise. Also, where did you acquire your parts?
Old 10-08-2021, 08:25 PM
  #437
NAMR6MT
NAMR6MT's Avatar
Originally Posted by DEEJ11
What material are the risers? If ABS, is there significant wobble from the wing at higher speeds?
I'd have to think it's billet aluminum, and no, there's no significant wobble. I see a slight flutter/vibration in the rear view at high speeds. Jon @ Composite Concepts is the creator who spec'd this piece from the OEM wing at a fraction of the price.
DEEJ11 (10-08-2021)
Old 10-09-2021, 06:39 AM
  #438
palestar
palestar's Avatar
Honestly not too bad. I spent about 3-4 hours doing both sides, which included disassembling both transmissions and re-greasing everything. I bought the gears off of Amazon. $39 for one, $45 for the other. They are both composite plastic and apparently much stronger than the originals.
Amazon Amazon
Amazon Amazon
They also sell the End Clips for about $10
Old 10-09-2021, 10:53 AM
  #439
The Boz Abides
https://www.amazon.com/MTC-7559-987-...3772258&sr=8-1
https://www.amazon.com/MTC-7555-987-...1CGOCXPC&psc=1
Thank you. I'll certainly think about getting this project underway as soon as convertible season ends.
palestar (10-09-2021)
Old 10-16-2021, 02:28 PM
  #440
The Duke
The Duke's Avatar
Yesterday, I replaced my scratched door trim insert. It's something I've wanted to do since I bought it in May.
My 2010 CS was treated with TLC by its prior one owner. It's a testament to the poor quality of the soft touch finish that scratches abound on almost every surface.
I also plan on doing the same piece on the passenger door, but I may wait until next spring.
Big ups to @kiznarsh - without his detailed photos and commentary, I'm not sure that I would have attempted this project, https://rennlist.com/forums/987-foru...l#post16906268
Project notes
  1. I would rate this as a relatively simple DIY project. It took about 4 hours, but I work slowly and clean surfaces to which I otherwise don't have access when they're disassembled.
  2. Be very careful when removing the triangle holding the electric mirror switches. The bottom is secured with two horizontal clips, the top slides down, securing itself to the flimsiest inverted "T" mounting point. You need to pop out the bottom of this triangle and then slide it upwards to remove it. I did something short of that and almost ripped the inverted T right off its mounting. I used some crazy glue to sorta fix it. It's fine now, but it's not something I want to ever have to go back to.
  3. I found that #6 screws were the perfect size to fit the posts in the new trim piece. Unlike Kiznarsh, I found that 5/8" were too long for this project. Unfortunately, I found this out with the door apart. I had to improvise and cut them to length - the smallest approx 1/4", the longest approx 1/2". In one case, I bought myself some wiggle room by doubling up on the #6 washers.
  4. Purely speculative - my new stone gray piece had a date of manufacture of Feb 2011. The black one that Kiznarsh installed appears to have a sometime in 2017 date stamp. Does this difference in age have anything to do with the relative popularity of the latter interior color relative to the former? Anyway, interesting to think that this trim piece has been sitting in a warehouse for 10-years prior to my having installed it in my car. The piece I replaced had a date stamp of August 2008. It's hard for me to say whether there's any real difference in the quality of the soft touch between the two.
Some before and after pics:
Meh!
Night and day
New car smell!
The following 3 users liked this post by The Duke:
Chris MI 987 (10-17-2021), J Free (10-16-2021), kiznarsh (02-22-2022)
Old 10-16-2021, 02:30 PM
  #441
GT3twenty10
GT3twenty10's Avatar
can’t see if you have a front splitter… if not you’ll need it to accommodate the wing
Old 10-16-2021, 03:24 PM
  #442
NAMR6MT
NAMR6MT's Avatar
It's being installed this Friday.
Old 10-16-2021, 03:27 PM
  #443
GT3twenty10
I did both… NR auto GT3 wing and Joe Toth front and side splitters… waiting on the diffuser
Old 10-16-2021, 03:36 PM
  #444
NAMR6MT
NAMR6MT's Avatar
Interesting. His diffuser is certainly more reasonable than the Verus carbon fiber.
Old 10-16-2021, 03:43 PM
  #445
GT3twenty10
Joe Toth is the first word in customer service…
he is a great guy and answers his phone and even calls you back. All his stuff is well made and priced where it should be.
The guy from NR auto… ya, worthless.. great wing tho….
the best wing imo
Front splitter
Old 10-19-2021, 03:54 PM
  #446
justicepool
justicepool's Avatar
Oil and filter change and complete brake service on my 2007 Boxster.
Chris MI 987 (10-20-2021)
Old 10-19-2021, 04:28 PM
  #447
The Duke
The Duke's Avatar
Impressive!
More so - you appear to have done this service without removing your car cover!
Old 10-24-2021, 09:09 AM
  #448
palestar
palestar's Avatar
Added LED's to my 987s. For less than $75 this was a fantastic upgrade! Also did the front fogs which are substantially brighter now and match the headlights really well.
Old 10-24-2021, 07:35 PM
  #449
NAMR6MT
NAMR6MT's Avatar
GT3 Cup splitter
Old 10-24-2021, 07:37 PM
  #450
NAMR6MT
NAMR6MT's Avatar
Jocke Rydell (10-28-2021)
Quick Reply: What did you do with your 987 today?
