From 981 CS to Base 987.2, The Story Continues
#136
The European one from Mityvac. It's more robust than the Motive one where people have had issues with hoses popping off (though probably rare).
https://www.skf.com/mityvac/products...leeding/mv6844
#137
While the interior plastics improved with the 987 generation, some areas are still prone to wear. Anyone else have the same issue?
![Name: sW6dst1.jpg
Size: 3.63 MB](https://rennlist.com/forums/attachments/987-forum/1341660d1683252799-from-981-cs-to-base-987-2-the-story-continues-sw6dst1.jpg)
You'd think that'd be a pretty straightforward swap, but seeing how I'm addressing this in ownership month #20, yeah, not so much. There are 2 critical steps one needs to take before tackling this task:
Number 1 - disconnect the battery since you'll be disabling an airbag.
![Name: 6GPplYv.jpg
Size: 3.49 MB](https://rennlist.com/forums/attachments/987-forum/1341661d1683252799-from-981-cs-to-base-987-2-the-story-continues-6gpplyv.jpg)
Number 2 - get yourself a hot beverage and a chocolate chip cookie (none of that oatmeal raisin nonsense).
![Name: XlpcM8r.jpg
Size: 3.32 MB](https://rennlist.com/forums/attachments/987-forum/1341662d1683252799-from-981-cs-to-base-987-2-the-story-continues-xlpcm8r.jpg)
As you've probably guessed by now, the door panel needs to be removed. Not terribly difficult, just a few Torx screws neatly tucked away.
![Name: 6WzQJFs.jpg
Size: 823.7 KB](https://rennlist.com/forums/attachments/987-forum/1341663d1683252799-from-981-cs-to-base-987-2-the-story-continues-6wzqjfs.jpg)
After you've disconnected the door handle cable...
![Name: da8SLPs.jpg
Size: 3.65 MB](https://rennlist.com/forums/attachments/987-forum/1341664d1683252799-from-981-cs-to-base-987-2-the-story-continues-da8slps.jpg)
...you'll need to pop off the trim for the mirror switch (just 2 clips on the bottom), then disconnect the press-fit connector.
![Name: rROvJBO.jpg
Size: 3.63 MB](https://rennlist.com/forums/attachments/987-forum/1341665d1683252799-from-981-cs-to-base-987-2-the-story-continues-rrovjbo.jpg)
Unfortunately that connector was giving me a hard time so I temporarily taped that assembly to stay out of the way while I popped the door clips off.
![Name: e1t3dY3.jpg
Size: 2.85 MB](https://rennlist.com/forums/attachments/987-forum/1341666d1683252799-from-981-cs-to-base-987-2-the-story-continues-e1t3dy3.jpg)
As long as the door doesn't suddenly fall, it'll be fine.
Door fell.![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
The weight of the door yanked the connector out from the switch and ultimate broke it. Soooo buying a new switch wasn't something I was expecting to do that day.
![Name: EkcrW7W.jpg
Size: 2.38 MB](https://rennlist.com/forums/attachments/987-forum/1341667d1683252799-from-981-cs-to-base-987-2-the-story-continues-ekcrw7w.jpg)
While searching for the switch, I got notified about another Etsy photo sale which covered the cost of the switch. Thanks DL from Long Beach!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
![Name: 16ADxXQ.jpg
Size: 3.21 MB](https://rennlist.com/forums/attachments/987-forum/1341668d1683252799-from-981-cs-to-base-987-2-the-story-continues-16adxxq.jpg)
Door panel removed.
![Name: Vigh6G1.jpg
Size: 2.45 MB](https://rennlist.com/forums/attachments/987-forum/1341669d1683252799-from-981-cs-to-base-987-2-the-story-continues-vigh6g1.jpg)
So here's the deal: that trim insert isn't held in by clips, tabs, screws, glue, double-side tape, peanut butter, or honey. No, it's held in by 9 plastic pins/posts that are welded to the door panel.
![Name: KSVHtDf.jpg
Size: 822.6 KB](https://rennlist.com/forums/attachments/987-forum/1341670d1683252799-from-981-cs-to-base-987-2-the-story-continues-ksvhtdf.jpg)
Which means the official procedure for removing the insert is drilling them out, then using a plastic welder to attach the new one. Who thought this was a good idea?![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
And how the hell did I break a drill bit?! Pre-load & heat, is what I reckon.
![Name: ouT5RG3.jpg
Size: 2.04 MB](https://rennlist.com/forums/attachments/987-forum/1341671d1683252799-from-981-cs-to-base-987-2-the-story-continues-out5rg3.jpg)
An absolute mess but finally got it out.
![Name: YnyXtya.jpg
Size: 2.73 MB](https://rennlist.com/forums/attachments/987-forum/1341672d1683252799-from-981-cs-to-base-987-2-the-story-continues-ynyxtya.jpg)
New/old comparisons:
![Name: Bm5buiR.jpg
Size: 3.53 MB](https://rennlist.com/forums/attachments/987-forum/1341673d1683252799-from-981-cs-to-base-987-2-the-story-continues-bm5buir.jpg)
![Name: Bl2ZWs0.jpg
Size: 3.68 MB](https://rennlist.com/forums/attachments/987-forum/1341674d1683252799-from-981-cs-to-base-987-2-the-story-continues-bl2zws0.jpg)
Then I spent some time cutting away the extra melted plastic left behind from the factory.
![Name: FhOHfbO.jpg
Size: 2.96 MB](https://rennlist.com/forums/attachments/987-forum/1341675d1683252799-from-981-cs-to-base-987-2-the-story-continues-fhohfbo.jpg)
Prepped the holes for insertion.
![Name: s4kMgev.jpg
Size: 3.18 MB](https://rennlist.com/forums/attachments/987-forum/1341676d1683252799-from-981-cs-to-base-987-2-the-story-continues-s4kmgev.jpg)
Like others, I decided that I wasn't gonna deal with trying to melt the plastic using a soldering iron (who's got a plastic welder anyway?) but instead, use screws & washers. This has the benefit of making the part easily replaceable in the future while having more control with drawing in the insert uniformly. Fortunately I was able to use existing hardware. I think I measured the pin OD to be 0.220" with an ID of 0.110", and the screw thread OD was 0.140" (5/8" long).
Used a Dremel to cut the pins flush with the door panel.
![Name: NzGDzpl.jpg
Size: 2.50 MB](https://rennlist.com/forums/attachments/987-forum/1341677d1683252799-from-981-cs-to-base-987-2-the-story-continues-nzgdzpl.jpg)
![Name: RQDtVRB.jpg
Size: 2.67 MB](https://rennlist.com/forums/attachments/987-forum/1341678d1683252799-from-981-cs-to-base-987-2-the-story-continues-rqdtvrb.jpg)
That's what I'm talking about:
![Name: CYAqgPF.jpg
Size: 3.11 MB](https://rennlist.com/forums/attachments/987-forum/1341679d1683252799-from-981-cs-to-base-987-2-the-story-continues-cyaqgpf.jpg)
![Name: mkxMJSe.jpg
Size: 1.67 MB](https://rennlist.com/forums/attachments/987-forum/1341680d1683252799-from-981-cs-to-base-987-2-the-story-continues-mkxmjse.jpg)
Covered the screw heads with wire loom tape to prevent rubbing (also prevents them from backing out).
![Name: Cif6tOd.jpg
Size: 3.24 MB](https://rennlist.com/forums/attachments/987-forum/1341681d1683252799-from-981-cs-to-base-987-2-the-story-continues-cif6tod.jpg)
Even though only 2 door clips broke during removal, I replaced all 9. Old plastic is old.
![Name: lu9HQat.jpg
Size: 838.8 KB](https://rennlist.com/forums/attachments/987-forum/1341682d1683252799-from-981-cs-to-base-987-2-the-story-continues-lu9hqat.jpg)
Thought I was home free when I realized the screw head was interfering with the door pivoting mechanism. Even after removing the washer, it wasn't going to clear.
![Name: wydkpOD.jpg
Size: 3.18 MB](https://rennlist.com/forums/attachments/987-forum/1341683d1683252799-from-981-cs-to-base-987-2-the-story-continues-wydkpod.jpg)
So I found a small piece of plastic that was laying around, busted out the soldering iron, and melted it to make it work. Turned out alright.
![Name: 2VPYBEt.jpg
Size: 3.03 MB](https://rennlist.com/forums/attachments/987-forum/1341684d1683252799-from-981-cs-to-base-987-2-the-story-continues-2vpybet.jpg)
And here we are.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![Name: m2YWaeQ.jpg
Size: 1.92 MB](https://rennlist.com/forums/attachments/987-forum/1341685d1683252799-from-981-cs-to-base-987-2-the-story-continues-m2ywaeq.jpg)
![Name: sW6dst1.jpg
![Name: 6GPplYv.jpg
![Name: XlpcM8r.jpg
![Name: 6WzQJFs.jpg
![Name: da8SLPs.jpg
![Name: rROvJBO.jpg
![Name: e1t3dY3.jpg
Door fell.
![Name: EkcrW7W.jpg
![Name: 16ADxXQ.jpg
Door panel removed.
![Name: Vigh6G1.jpg
![Name: KSVHtDf.jpg
![Name: ouT5RG3.jpg
![Name: YnyXtya.jpg
![Name: Bm5buiR.jpg
![Name: Bl2ZWs0.jpg
![Name: FhOHfbO.jpg
![Name: s4kMgev.jpg
![Name: NzGDzpl.jpg
![Name: RQDtVRB.jpg
![Name: CYAqgPF.jpg
![Name: mkxMJSe.jpg
![Name: Cif6tOd.jpg
![Name: lu9HQat.jpg
![Name: wydkpOD.jpg
![Name: 2VPYBEt.jpg
And here we are.
![Name: m2YWaeQ.jpg
The following 4 users liked this post by kiznarsh:
#138
Amazing as usual. Love the detail in your DIY guides. Thanks!
#140
Awesome write up, thank you!
Nice work too, that’s a major cosmetic upgrade IMHO.
#141
#142
Received 1,150 Likes
Great writeup. I was thinking those bits on my car would look good if they matched the newly painted console.. but after seeing the plastic rivets I'm not so sure. Wonder if it would be possible to reassemble it with some 3M double-sided emblem tape?
#143
Overall this was time-consuming but not particularly hard. Plastic welders aren't that expensive either but I didn't see myself needing one in the future so I didn't consider buying one, plus the soldering iron can do the job.
#144
A tale of suction, seduction, and a reduction of debris.
Screenshots:
![Name: SQjCHEr.png
Size: 2.45 MB](https://rennlist.com/forums/attachments/987-forum/1341611d1683252799-from-981-cs-to-base-987-2-the-story-continues-sqjcher.png)
![Name: qUUejmE.png
Size: 2.74 MB](https://rennlist.com/forums/attachments/987-forum/1341612d1683252799-from-981-cs-to-base-987-2-the-story-continues-quuejme.png)
![Name: 2k4WS9V.png
Size: 3.25 MB](https://rennlist.com/forums/attachments/987-forum/1341613d1683252799-from-981-cs-to-base-987-2-the-story-continues-2k4ws9v.png)
![Name: fi5a0gj.png
Size: 1.79 MB](https://rennlist.com/forums/attachments/987-forum/1341614d1683252799-from-981-cs-to-base-987-2-the-story-continues-fi5a0gj.png)
![Name: q3R3d8I.png
Size: 2.55 MB](https://rennlist.com/forums/attachments/987-forum/1341615d1683252799-from-981-cs-to-base-987-2-the-story-continues-q3r3d8i.png)
![Name: eIS4MLP.png
Size: 2.62 MB](https://rennlist.com/forums/attachments/987-forum/1341616d1683252799-from-981-cs-to-base-987-2-the-story-continues-eis4mlp.png)
![Name: rBTtEQ2.png
Size: 2.73 MB](https://rennlist.com/forums/attachments/987-forum/1341617d1683252799-from-981-cs-to-base-987-2-the-story-continues-rbtteq2.png)
![Name: 8Qx2dos.png
Size: 2.66 MB](https://rennlist.com/forums/attachments/987-forum/1341618d1683252799-from-981-cs-to-base-987-2-the-story-continues-8qx2dos.png)
![Name: HJKwkVr.png
Size: 2.70 MB](https://rennlist.com/forums/attachments/987-forum/1341619d1683252799-from-981-cs-to-base-987-2-the-story-continues-hjkwkvr.png)
![Name: XJmuj6f.png
Size: 1.95 MB](https://rennlist.com/forums/attachments/987-forum/1341620d1683252799-from-981-cs-to-base-987-2-the-story-continues-xjmuj6f.png)
After buttoning everything up, got an error about my LED license plate lights not working. I knew I plugged them and after some troubleshooting, realized they both fried at the same time.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
![Name: KVhav0V.jpg
Size: 3.12 MB](https://rennlist.com/forums/attachments/987-forum/1341621d1683252799-from-981-cs-to-base-987-2-the-story-continues-kvhav0v.jpg)
![Name: iEW5ElW.jpg
Size: 2.95 MB](https://rennlist.com/forums/attachments/987-forum/1341622d1683252799-from-981-cs-to-base-987-2-the-story-continues-iew5elw.jpg)
Screenshots:
![Name: SQjCHEr.png
![Name: qUUejmE.png
![Name: 2k4WS9V.png
![Name: fi5a0gj.png
![Name: q3R3d8I.png
![Name: eIS4MLP.png
![Name: rBTtEQ2.png
![Name: 8Qx2dos.png
![Name: HJKwkVr.png
![Name: XJmuj6f.png
![Name: KVhav0V.jpg
![Name: iEW5ElW.jpg
#145
Hit you with a sub on YouTube. Massive props for starting to make videos. I know it's much more work than it appears to get started, but if you stay with it it'll pay off!
Also how nice is that quick jack?! I'm jealous.
#146
The monetization requirements are pretty extreme too: 1,000 subscribers and 4,000 hrs of watched content over 12 months. I just want to get to 100 subscribers so I can create a custom URL.
The following 2 users liked this post by kiznarsh:
9872SpeedYellowCS (09-21-2020),
SantaFePorsche (09-19-2020)
#148
I hit you with a sub, that was very therapeutic to watch and now my OCD is making me want to do the same...
kiznarsh (10-28-2020)
#149
Finally got another roll of film developed.
And a couple long exposures with the DSLR.
#150
Awesome pictures, love following this thread
