Some Maintenance work
Ryan, I always remove the fans to get additional space. Its not hard to do and they can be removed from the top. Its only 2 connections.
One way to get more space would be to losen the rear belt cover. Its held in place by 2 10mm bolts on top to the back of the cam pulley cover and on the bottom by 2 additonal 10mm bolts. If your tensioner is out, you should be able to remove these are be able to move the rear belt cover a bit. To remove the belt cover, you need to remove the bs pulleys if that might help.
Raj
Raj
Update: 3/13/2008
Removed Gas Tank to trace gas leak. So far it looks like the hose between filler neck and tank is what could be causing the leak. That could be a good sign because I won't need to buy another gas tank. Just to make sure, I am getting it pressure tested. The shop told me that there are plastic weld kits available in case there is a leak.
So far, its been a positive day and I might be getting off easy on the gas tank leak problem. Looks like all parts for plating will have to wait till monday.
Also, I found the passenger side motor mount to be completely shot and cracked. All the fluid was missing.
Changed the front and rear crank seal. The o'ring for the oil pump gear for so old and hard that it broke like it was plastic. Next is engine cleanup and getting it on engien stand so I can start workng on the oil pan section. i might check the rod bearing while the pan is off to make sure they look fine.
Raj
Raj
Seems like a lot of cabs have this gas smell problem. I know I get it at times, but could never track it down. Are the lines accessible without dropping the tank? (I bet I know the answer to this already)
Surprisingly the tank is very easy to remove once you have the transmission off. This could potentially help others figure out the problem with their tank smell.
I know someone who had to swap their gas tank because of some idiot electronic installer who drilled right into the tank while installing the amp.
Raj
I can't imagine the canister being the cause of the fumes. The fumes come from the back and I saw how the setup can be the cause for fumes on a cabriolet. The filler necks are completely different between cabs and coupes. The cab neck make a strong turn while the coupe comes in straight. There is a flexible hose that connects the neck to the tank. In cabs its easy for the flexible hose to not seat well or come lose over time and possibly cause drips from splashes when the tank is filled.
This could be the case in my car as well. I can't see any evidence of gas tank rupture of any sort.
Raj
Raj
I made an adapter to go to the filler neck from the outside that way you test the entire gas tank, associated hoses, and it uses compressed air. So if there is a leak follow the hiss and you will find it.
Not sure if it would be that simple with the tank in the car. You can hardly trace any hiss that is on top of the gas tank. With hoses up in the area you would still need to drop it to further investigate.
That test would only eliminate or troubleshoot lower gas tank leaks or filler neck hose leaks with the tank in the car. Those are easier to trace anyway.
Raj
Raj
I have the same gas smell in my coupe. But I only get the smell if I fill the tank over 3/4 .... when I bought the car, the fuel gauge didn't read over 1/4 tank despite being full, so I replaced the fuel sender unit ($5 on E-Bay!) and not only does the gauge work perfectly, but the smell has diminished as well (????). I don't understand why or how.
Update: 03/15/2008
Good News. There is a leak in the gas tank and its right where the neck is. It looks like the plastic welds gave in on the seams. I was told of a local place that could fix it. I was also told that I could do it myself with the right epoxy but its one of those things I prefer leaving to a shop so they pressure test it afterwards.
I will be installing the engine on the engine stand tonight and start cleaning the engine area. I have a little 968 gathering going tonight to watch the 1st F1 race of the season. This should help me get the engine on stands so I can start working on the rest of the seals.
Raj
Raj
Absolutely, along with the engine, transmission and all other bits and pieces. Everything is begining to show up and I should have the hardware back later on this week. I am dying to put it back together. It should be a fun 2-4 weeks.
Raj
Raj
