Some Maintenance work
#31
Update: 03/02/2008
Decided to remove the heatshield by the manifold and saw that it was cracked. That explains some of the rattle.
Since the coolant used was not phosphate free, I decided to remove the head and I am glad I did. The head gasket had bubbles in some of the water jackets. Fortunately, it did not cause any pitting to the head surface.
So, now I guess all the gaskets and seals will be new .
Why is the engine still in the car??? I am begining to wonder. It could have been easier with the engine out. I promised myself to leave it in there so I will be true to my promise.
Regards.
Raj
Regards.
Raj
#34
Trevor, I am not sure yet. I will have to ispect the head better and see. It made very good numbers so the head is in excellent shape. I will go to my machine shop and see if they can surface it.
Arash, no slope. Just try to do things right and not cut any corners.
Raj
Raj
#36
Yes Luis.
It started with front engine reseal and lower bs seal. I was planning to do all this in winter of 2008 but I guess I am ahead of schedule now .
I have a spare fresh head so I will put that on for now. Nothing trick, just new guides, seals and a 3 angle valve job. The trick stuff will be later.
I have also decided to get all nuts/bolts plated while I wait for parts.
Ordered a new water pump and rebuilt alternator. I think the budget just went from $300 to $1000.
Raj
Raj
#40
In case you didn't know, silicon comes in different flavors. When used for o'rings, it works as a lubricant to avoid o'rings from getting chewed. I learnt this from Dave Lindsey yrs back.
There is no need to ever use silicon as a sealant. The o'rings act as seals.
Raj
Raj
#42
The story is pretty much a carbon copy of what happened with our blue 968. Was just going to change the chain and pads. Then I noticed all the brittle plastic and gooey hoses. I thought a 220k-mile engine should probably need a HG soon so I took it out, and I saw the 2 or 3 holes which had just poked through the gasket by the water jackets. The head was pitted very slightly but easily fixed!
I set out with a budget of $200 and ended up spending... $1000 I think.
#43
One more reason why it's usually better to buy a car from an **** enthusiast as it's usually well kept and cheaper in the long run. Pay now or pay later?
H2
#44
I think the big ticket items are something I could avoid but prefer doing. I don't need an alternator or a new water pump but with 118k miles, how long before I actually need them?
I don't have much spare time with my kids and job. If I am going to do something, I try to look in the surrounding areas and see what else can be done. It might pinch me now, but it could save me a lot of TIME in the future. Its not about the $$ with me, its about time.
As with most of our cars, the ps hoses have slight leaks so I am also swapping both hoses on the reservoir. After reading Jim's article in Excellence, I feel compelled to fix this nagging problem that eats castor blocks, swaybar busings etc.
I know when I am done, I will feel good knowing nothing was left on the plate for later. It is all done and I can have happy motoring for a long time to come. I have no plans to sell this car. Can't find a worthy replacement to something this unique.
Regards.
Raj
Regards.
Raj
#45
Update: 3/5/2008
Transmission is out of the car. Now I can pull the torque tube back and pull the bell housing off to get better access to rear main crank seal.
I am going back and forth on if I should pull the engine out. If I do, I know I would want to plate all nuts and bolts.
Decisions..Decisions...
Raj
Raj
