964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 12-23-2015, 12:42 PM
  #91
Spyerx
Spyerx's Avatar
Received 1,789 Likes on 1,089 Posts
Originally Posted by rsabeebe
when do we see the 'sum of the parts'?? great project.
I'll post a full "phase 1" build list once complete. It continues to evolve but the end state for this part I have pretty well defined in my head at this point.
Cost? Who knows. Mid 5 figures plus the car. But who is counting. I will post that too to scare people away. LOL and same again for the engine build.
Let me put it another way. I have driven the 991 gt cars and I'm not a fan. Faster, "better" sure. But the feel is gone. Maybe it gets right on 991.2gt3/rs.
But for now my $ is going into an "antique" that I think will be much more fun and teach me a lot more as a driver. Cost may end the same. But that is ok by me.
Old 12-23-2015, 12:49 PM
  #92
FLYT993
FLYT993's Avatar
killer, just absolutely killer! love it.
Old 12-23-2015, 01:30 PM
  #93
bobaines
bobaines's Avatar
I like what you are doing, and LOVE your attitude!
Old 12-24-2015, 01:34 AM
  #94
Spyerx
Spyerx's Avatar
MORE PARTS
these are the BMW brake lines that allow you to connect the 993 master cylinder to the abs unit. 10mm on one side 12mm on the other. Part 34326752405 $15 each and a local dealer actually had them in stock. On shelf since 2009 he said! Other option is an adapter or fab new lines or tweak current lines to work. Lines must be bent to match current lines. Easy job.
Other pic is all the shifter mechanism bushings, washers, o rings, clips and any other part in the shift chain. All will be replaced with rothsport shifter install.
Old 12-24-2015, 02:11 AM
  #95
Texas RS
Texas RS's Avatar
Gearing will get done alongside motor build. After hearing a certain 3.9L screaming this weekend. I need it. BAD.
Yes and nope, porsche factory. Squint and you can see the part number.
We can get you fixed up on an air cooled 3.9L, with more torque than your 7.1.
Old 12-24-2015, 10:27 AM
  #96
Bill Verburg
Bill Verburg's Avatar
Originally Posted by cobalt
Interesting on the hats. I had to loose mine with aluminum hats and coleman rotors. Are you modifying them to monoball or having them pinned to make them solid? I pinned mine which made a huge difference.
The reason Spyrex is able to retain the parking brake w/ the hats is that the caliper he has are radial mount. This allows the caliper to be spaced out a bit more than on the 993RS rear 322mm rotors. The parking brake requires rotors in ~330mm. This is also done on Cayman, Boxster and 996, 997.
It could be done w/ 993RS if the calipers are converted to radial mount and a bigger rotor is used
like this
On left stock axial mount 993RS rear caliper, on right 993RS rear caliper converted to radial mount w/ caliper adaptor
Old 12-24-2015, 11:04 AM
  #97
Bill Verburg
Also thanks for the info on the gearbox. I'm going to hold off until I decide what I want to do with the engine as that will dictate the gearing.
always a good idea, but the 6 speeds have a lot of flexibility
here is a comparison of some of the 993 6 speeds that have been used
Tee /30s use a different mainshaft that laaows 1 -6 to be altered easily, the /20s all have a fixed 1 and mostly all have fixed 2 as well. Here is the break down on the #s where the loose 2 ended, M220 is w/ lsd
G50.20 - 02693
G50.20 - 02174 (M220)
G50.21 - 05072
G50.21 - 03094 (M220)
I have the /30 in mine it is great for both street and track, the RS /31 or /32 have much taller 6 for more relaxed highway use. Other differnces will be found in the choice of internal components, the /30 and /34 are pure race transmissions w/ all steel syncros and more robust build, the /32 and /31 are slightly less robust, w/ the /31 least so. The /20s are street trans which will tend to have more issues w/ track use. Among the issues that will be found are brass syncros and plastic bearing shells
Old 12-24-2015, 01:30 PM
  #98
Spyerx
Spyerx's Avatar
Bill - Benefit of a 993 trans vs. modifying what I have with steel synchros and the like? Obviously the additional ratio... but I think the stock 964 gearing is a bit nicer than the 993 gearing?
Old 12-24-2015, 02:00 PM
  #99
Bill Verburg
Ther are several way s to look at it and the torque curve of the motor has a huge influence on what way you go
Just for instance I did this comparison for a friend the engine is a very healthy 993 non vram in a 964 RSA. The trans choices available were g50/03/ g50/05( these are 964 5speeds) and a g50/20 from a US 993. The thrust curves take unto consideration the aero resistance of a stock RSA
Except for 3rd the /20 is better, but the /03 3rd is fabtastic in comparison to the other 2 if the car is driven between 60 and 110mph. This is likely to be the most used gear on most race tracks. AFAIK the 964 g50 come w/ steel syncros stock, don't know about the bearing shells or other internal components.
Now compare the 2 964 trans to a g50/30, same chassis and engine
here the 03 still has better thrust in 3 between 70-105, but the 30 has a smaller drop into 4 and even 5 for the speed realms above 110mph. Here the smaller drops overall in all gears are the big advantage.
Old 12-24-2015, 03:25 PM
  #100
Spyerx
Spyerx's Avatar
^^ Great info. My car has the G50/03, this gives me something to think about.
My driving style/use is canyons which are mostly 2-3 and track which will be 2-3-4 with 3-4 being most common. 1 track here, auto club speedway 5th would be used, but I rarely drive there.
Do you have a way to do something similar with the G50/03 tranny but changing just the final drive ratio to (I think ? 3.89?)
Old 12-24-2015, 05:05 PM
  #101
Bill Verburg
Sure, but all it does is move all the blue lines up a bit, you still have the same big drop from 3 to 4 and 4 to 5 3 now goes from 60 - 95 and 4 is 178-122 and 5 is 98 -152 some what less w/ shorter tires
In the thrust charts note how the /20 at he end of 3 kisses 4 and the end of 4 kisses 5 etc. That is a good thing compared to the drop from 3 to 4 and 4 to 5 etc in the /3 or .5, even w/ 3.89 or shorter tires.
Old 12-25-2015, 09:40 AM
  #102
kos11-12
kos11-12's Avatar
Hi guys, As a stock box I quite like the gearing of the G50/01 , What do you think From what I understood It's not a straight fit, The front case needs to be changed plus an LSD to be fitted, I came across one for 2500 € with 70000 km ...
Old 12-25-2015, 12:59 PM
  #103
Spyerx
Spyerx's Avatar
Thanks for the info as always Bill!
I've traded some notes with Matt (GT Transmissions) and his feeling is similar with the 5spd, keep it and address a bit shorter on the higher gears, to tighten up the spacing but it's pretty good as it sits.
Ugh I think my tranny is going to be seeing Bill Rader sooner rather than later for some GT Gears updates :-)
Old 12-25-2015, 04:57 PM
  #104
Jjm4life
Jjm4life's Avatar
After looking at An endless number of charts, I decided to regear a six speed this winter instead of doing the 5 speed. No matter what ratios, the 5 speed always had a compromise to it. Not the case with the extra cog.
Old 12-26-2015, 11:46 AM
  #105
Bill Verburg
The /01 is the same as am /03 but w/ shorter 4 & 5 the drops to 4 & 5 are 25% & 27% vs 30% & 25% for the /03.
You might be better off just regearing a /03
Aosako (04-02-2023)
Quick Reply: My 964 C2 Transformation Build Thread
