Worth it on a full race car. Not so much on the street. Plus, the problem with bracing is that on front end impact, the more bracing, the more destroying of the chassis. So if you did the full x brace in the front, and then had even a light tap to the nose, you will twist the entire tub. So it's a terrible idea unless you are racing against a competitive group of equally prepared cars where 1/100th of a second means something.
Or....just never crash. Lol.
Personally - i like as much stiffening as possible - because then you are left with just the suspension taking care of the handling. I like the directness and the feel. Street or track. But...I'd never do this on a street car for the reasons above. Getting hit on the street is too common. No need to lose the car over a fender bender.
I'm thinking the rubberized type vs. sandpaper type... I have aluminum floor boards in one of my other car and they are slick especially if they get a little wet.
I have no doubt for a street car that the improvement is profound over what it was. Sounds great looks like it has no problem getting out of its own way. Very nice. Although we know you will find something else to tweak.
Geoffrey's car was amazing way over the top and far more advanced than the 3.8 RSR's I had seen. I spent an afternoon at his house with Ilko and his attention to detail was impressive to say the least. I was stunned when he sold it. I know the current owner. I hope to see it again one day. When I was told what it changed hands for I wanted to cry. I would have snagged it in a heartbeat if I knew. Loud as can be though.
Picked up car today. Will go tear up the canyons this weekend then bring it back for a nut bolt and checkout.
So first issue is i turn on lights and clock stops working and doesn’t light up. Get home pull it and find a broken trace. Jumped it and resoldered all the connections. Shop didn’t have clock out so not sure what caused that. Age i suspect. There were no burn marks.
drove car up and down pch this afternoon a few thoughts
ac works good. So does heat.
Car has a nice raspy growl. Exhaust is not that loud
the lwfw is awesome. So revvy. Like my gt3rs kinda.
With ac on installed it once after 2 hours of driving.
Car feels super agile and light.
It’s plenty quick.
Front end has massive grip
no bump steer at all
the kw feel very nice. Shop spent some time adjusting them
i have a fair amount of mechanical noise in the cabin. Just enough for me. It adds to the visceral feel when pushing it
when cruising with windows up you hear the trans thanks to the hard rubber trans mount and minimal sound deadening
Csr feels much stronger pulling
gets a lot of looks hahahha
working to get on Steve wongs schedule to tune the car hopefully next week
