964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 08-20-2018, 04:14 PM
  #886
LPMM
LPMM's Avatar
The whole build is great, but that exhaust... Interested in your feedback once up and running, especially regarding drone (or lack thereof).
Old 08-20-2018, 07:19 PM
  #887
Spyerx
Spyerx's Avatar
Received 1,789 Likes on 1,089 Posts
I'm not very sensitive to drone.. just drop a gear :-) we'll get some video of it for sure.
View this post on Instagram
Old 08-20-2018, 07:32 PM
  #888
Spyerx
Spyerx's Avatar
Just look at the total. Not aligned yet.
J
Old 08-20-2018, 08:05 PM
  #889
eddieb4
eddieb4's Avatar
J
Nice diet!
Old 08-20-2018, 11:37 PM
  #890
tjb616
tjb616's Avatar
With an interior, half cage, and a/c? Impressive!
Old 08-21-2018, 10:32 AM
  #891
nolift911
nolift911's Avatar
A few things:
the fog plug is about 16mm inner, so a standard cigarette plug won't fit, too small
the plug that fits right in is 999-703-344-40-01C
Wrapping up exhaust heat setup, on to finish the fab
Went through the same thing - I got plugs from Lowes/Home Depot in all sizes that matched the grain and color for my 84 - you may want to check there...you can also trim them to fit, or if they are a little large, trim the backside for a nice press fit and the outer dimensions will cover - hope that helps. Awesome build and no sunroof!!!!!!!!!!
Old 08-21-2018, 11:07 AM
  #892
Finlander
Finlander's Avatar
Ok, now I'm jealous.
Old 08-21-2018, 11:37 AM
  #893
Spyerx
Spyerx's Avatar
I’m a little surprised. Even though back of napkin math showed this range.
We took a on a lot of unnecesssry things off. And a lot of little things.
majors were: interior sound deadening, power steering, flywheel, exhaust, sunroof, rear decklid.
Previously, it was all the suspension, shocks, brakes, wheels, battery, seats, etc
weight added: cage, kept ac, kept heat, harness stuff, secondary oil cooler.
You could do more for sure. Remove support beams, glass hood and fenders, strip wiring.
After that you cut into convenience features. Like interior, heat. Ac. Etc. heat and ac and interior would easily be 100lbs.
Thing to keep in mind everything counts. Like. Engine mounts. A few lbs vs 1 lb for wevo.
Anyway happy with result. This is essentially rs weight.
Old 08-21-2018, 11:58 AM
  #894
golfnutintib
golfnutintib's Avatar
very cool chris
didn't know wevos are lighter than stock mounts... makes sense that they are now that one thinks about it!
Old 08-22-2018, 11:03 AM
  #895
Spyerx
Spyerx's Avatar
Wrapping up alignment. If you recall i removes the factory RS uprights and installed BBIs custom parts. Two reasons. Stiffness of the mounting location and additional bump correction.
The front bump movement is .014” over 1.5” of travel I would say these uprights are spot on.
Nyx (04-29-2024)
Old 08-31-2018, 01:19 AM
  #896
Spyerx
Spyerx's Avatar
Old 08-31-2018, 01:27 AM
  #897
Spyerx
Spyerx's Avatar
Old 08-31-2018, 01:30 AM
  #898
Marine Blue
Marine Blue's Avatar
That’s a serious diet and I bet it will be an incredible driving experience. So when will it be ready?
Old 08-31-2018, 10:40 PM
  #899
Spyerx
Spyerx's Avatar
Old 08-31-2018, 10:48 PM
  #900
Achtung964
Achtung964's Avatar
Sounds super aggressive. Well done. Any concerns of passing smog?
Quick Reply: My 964 C2 Transformation Build Thread
