964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 02-15-2018, 11:30 PM
  #766
Spyerx
Spyerx's Avatar
Received 1,809 Likes on 1,104 Posts
Itll be painted in 2 weeks. 8 weeks ago lol. Job is quality tho. Looks nice.
Old 02-16-2018, 01:16 AM
  #767
The Greek
The Greek's Avatar
^ reminds me of Money Pit.....
“How long will it take to finish after the permit?”
2 weeks....
Old 02-16-2018, 07:14 AM
  #768
rkwfxd
rkwfxd's Avatar
He said two months. You just heard two weeks. LOL. Its beautiful. Who did it?
Old 03-26-2018, 02:24 PM
  #769
Spyerx
Spyerx's Avatar
Update! Car has been back from paint. Interior going in this week. Progress!
Goals: Complete and driving on its own power for Luft 5!
Old 03-26-2018, 03:30 PM
  #770
Marine Blue
Marine Blue's Avatar
Paint looks incredible, looking forward to seeing it at Luft!
Old 03-26-2018, 06:48 PM
  #771
HiWind
HiWind's Avatar
Originally Posted by Spyerx
We didn't weigh it all out - we did take a weight of car before it started strip down and will when its done.
The CAD program said about 50lbs based on materials selected and sizing.
My target weight is 2750 ready to go. We should be close to that with the cage added, but we are taking more weight off (flywheel, exhaust, the interior strip, sunroof delete, etc).
OK nice .. I just did mine (44mm hoop (1.75in) and 40mm (1.575in) chromoly with 1mm walls to save weight ... it's really just a glorified har(d)ness bar modelled on the 993 Cup cage (Driver B top to Passenger B bottom and Passenger B top to driver rear seat wheel arch interior corner) so much less complete than yours but makes a material difference. I got it back last week powder-coated .. weighs 11.3kg (24.9 lbs) so a bit more than I expected but happy enough and even without B gussets it feels way more rigid ... also did the slightly rear of B pillar hoop positioning (looks great from the side and gives a bit more room for the seat to move back if your legs are long). Did the fennlane delete as you suggested at the same time .. worth noting that a good spot welder and panel beater means dramatically less filler is required and I'm glad we took a extra day just to work on the shape and reduce the need for filler. Interesting the rear screen weighs 8kg! Had to come out for the headliner to go in nicely. ... and thanks, your thread got me properly motivated to get the next level!
fennlane spotted in then etch primer
test fit after powdercoat (not quite centered)
any time now
Old 03-26-2018, 07:20 PM
  #772
Spyerx
Spyerx's Avatar
^^ Wow that looks really nice. My cage has a little narrower rear profile as we went through the firewall and tied to the suspension points, we also gusseted to the B pillar. But otherwise pretty similar. We ended up with a thicker hoop and thinner materials for the rest.
Here are a few pics of the cage. I will get more this week when I get back to the shop.
Old 03-26-2018, 07:22 PM
  #773
Spyerx
Spyerx's Avatar
Old 03-26-2018, 07:59 PM
  #774
HiWind
HiWind's Avatar
yes I saw the firewall through-posts are way narrower than I would have expected but once I looked into the engine bay I see the mounts are quite a way from the corners .. wierd I've looked at them 100 times and still hadn't noticed that lol. Roof looks flawless .. worth the extra effort for sure.
Luckily I have this 993 nut&bolt resto going on near me so we could model off it very closely .. guy had this white cup for years and then found out from factory that it was originally Riviera .. no brainer!
Note the weld 'tidyness' is not very high .. but cleaning welds not allowed for race spec I guess.
Old 04-05-2018, 02:14 AM
  #775
Spyerx
Spyerx's Avatar
Will it be done by LUFT!?!?!
BBI Says Yes!
PUSHING!
Old 04-05-2018, 11:51 AM
  #776
LuisGT3
LuisGT3's Avatar
See you there Spyerx!
Old 04-06-2018, 12:26 PM
  #777
GMKF
GMKF's Avatar
Wow what a great build thread ! Im so glad is stumbled upon this
I have "known" BBi/Joey since Matt Farah "TST" did his first ever /Tuned show on Drive... and reviewed Project-Angry a few years ago.
Thanks for the documentation again, it really was fun to check it all out... .
Old 04-06-2018, 11:48 PM
  #778
Spyerx
Spyerx's Avatar
Was at the shop this afternoon. I really should have taken some pictures. Located MOST of the parts for the build, they are all at the shop... now if we can just find those headers! :-)
Old 04-13-2018, 09:50 PM
  #779
Spyerx
Spyerx's Avatar
Old 04-13-2018, 09:52 PM
  #780
Spyerx
Spyerx's Avatar
<div style="text-align:left;">Yard sale!!! Hahahha</div>
Quick Reply: My 964 C2 Transformation Build Thread
