964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 06-25-2016, 09:46 PM
  #571
Spyerx
Spyerx's Avatar
Received 1,809 Likes on 1,104 Posts
Went to visit Joey at his new shop. Big space. Very empty for now!
I helped him do another bleed on my brakes after the abs pump replacement. Had just a bit of air in the passenger rear. Brakes feel perfect now!
His new location:
E-Motion Engineering
1592 Monrovia Ave
Newport Beach, CA
Old 06-26-2016, 01:23 AM
  #572
Spyerx
Spyerx's Avatar
Been working on finalizing the next work i'm doing on the car. call this 'phase 1b'
in my head phase 2 = engine and trans. if there were a phase 3 it would be a 'nice' paint job (which to me is nice enough to enjoy, not too nice to want to sit in garage)
this is basically finishing the cosmetics, aero for the track, safety equipment, lwfw, headers/exhaust, oil cooler, and a bunch of other 'things', and removing a little more weight. i need to weigh car again, but i think about 2750 is achievable.
Everything in this list I have in hand except the clutch parts.
PAINT / BODY
Paint splitters same color as headlight rings (black)
Paint cultwerks center bumper guards red section to match car
Paint FVD cooling ducts guards red
Paint headlight rings black, install
Paint Ruf A Pillar aero parts guards red, install
Paint Getty wing
INSTALL
Install Cultwerks splitters front bumper
Install new lower front bumper plastics left/right
Install new lower bumper plastics with cultwerks RS extensions
Cultwerks Carrera RS rear bumper center section + lights
Modify rear bumper, remove extensions drill rivets, etc
Install Rear license lights,screws for RS Bumper
Relocate tow hook on rear bumper for Cultwerk bumper
FVD / cultwerks front brake ducts
Install front cooling ducts kit from FVD - USE FOR OIL COOLERS
Ruf A Pillar aero kit
Getty Glass RS 3.8 wing carbon top blade
RS Motorspot hood support
INTERIOR
Strip interior, remove all surfaces
Remove all coating and sound deadening
Install center console wing switch delete
Disable / unplug / remove wing module
H3R halguard fire extinguisher
Brey-Krause roll bar extinguisher mount
Rennline quick disconnect fire bottle holder
Appbiz RS perlon carpet kit, BLACK
Appbiz rear firewall INTERIOR sound pad
Rennline aluminum pedals + dead pedal, perforated silver
Rennline hell toe extension - Red
Rennline floor board drivers silver perforated
Rennline floor board passenger silver perforated
Rennline cup driver side floor board silver
Rennline cup passenger side floor board - silver
Rear cage welded in modeled after Joey’s Car
Paint cage + prime/paint weld areas
Reinforce front seat front rail mount positions - box in welded steel plate
Retain OEM seat belts (front only) remove rears, mount to roll bar
Install red seat belts
Inboard harness mounted using Sabelt backing plates, drilled to tunnel in RS positino
Sabelt harnesses, red, both seats (aluminum)
Replace clutch and brake pedal box bushings (4 total)
ENGINE
Remove cruise control mechanism / cables in engine area
Valve adjustment
Inspect engine for seepage
Oil and filter change
Install second oil cooler - carnewal
Refinish fan / housing - paint or powder coat fan gold or red
Inspect fan and housing for cracking
Wevo Engine mounts 964 (blue pillows/stiffer)
Install Appbiz race engine sound pad (silver covering)
Rothsport fan hub single belt
Rothsport pulley half
Rothsport single belt crank pulley with ac
New primary drive belt - 99919233850
New AC drive belt - 99919236350
Remove belt sensor, short wires, tie out of way
Rothsport engine support beam
Rothsport headers
Fabricate muffler and exhaust out of 991 turbo muffler
O2 sensor for headers - 96560612601
Custom heat boxes for rothsport headers
Heat shields for lower valve covers / headers
TRANS
Change tranny fluid - Motul synth
Bleed clutch with new brembo fluid
Porsche Light flywheel - RS setup
FVD braided slave cylinder pipe
Balance flywheel/clutch assembly
Rennline Tranny mount
Rothsport billet shifter black
Rothsport goldenrod
Rothsport forward shift rod
Check / order long bushing - Rothsport to supply
Replace all shifter action bushings
Throttle linkage bushings on bell housings
OTHER
Replace receiver/drier in the AC system
Old 06-27-2016, 12:55 AM
  #573
mooty
GT3 player par excellence
mooty's Avatar
Received 5,718 Likes on 2,344 Posts
His new location:
1592 Monrovia Ave
Newport Beach, CA
nice space, joey.
love the white snap on box.
you HELPED JOEY bleed? you mean he helped YOU
Old 06-27-2016, 01:08 AM
  #574
Spyerx
Spyerx's Avatar
Originally Posted by mooty
nice space, joey.
Well he did the hard part. I was the pedal pusher. So either or lol.
Old 06-27-2016, 12:25 PM
  #575
ekoges
ekoges's Avatar
nice space, joey.
Hahaha, GOT YA!
Old 06-28-2016, 01:46 AM
  #576
Antonov
Antonov's Avatar
I've got the same box, white too. Great to hear Joey is expanding.
Old 06-30-2016, 12:49 PM
  #577
C4inLA
C4inLA's Avatar
Yeah, that is about right for a "residential" garage space in Newport Beach... Is it just me or are there a lot of boutique/low volume "special project" shops out there and NOT enough, make an appointment, car in on Monday, out on Friday? Three in Southbay off the top of my head.... Nature of the beast, I guess....
Old 06-30-2016, 12:54 PM
  #578
Spyerx
Spyerx's Avatar
Hahah...yeah pretty much :-)
Old 06-30-2016, 01:58 PM
  #579
Matt Andrews
Matt Andrews's Avatar
cool. I need to drop by Joey's place. I don't venture too far from newport. his old shop was too far away.
Old 07-01-2016, 11:20 AM
  #580
inactiveuser7616
inactiveuser7616's Avatar
Wow....WOW! Chris, I didn't realize just how deep you are in to this project. I'm super impressed! Love it!
Old 07-01-2016, 11:27 AM
  #581
Spyerx
Spyerx's Avatar
Hahaha yeah thanks. My advice to you: Don't drive an antique, they're addictive :-) But if you do.... Checkout a 964 coupe.
Car is super fun as it sits, last bit of work for now will add: safety equipment, some aero, reduce some weight, make it a bit louder, and generally make it less tolerable for the wife.
Old 07-02-2016, 02:31 AM
  #582
inactiveuser7616
LOLOLOL....
dude...I like your style my friend!
Old 08-14-2016, 01:42 PM
  #583
Spyerx
Spyerx's Avatar
Adding this, part of the adventure (speedometer failure):
https://rennlist.com/forums/964-foru...eter-dies.html
Old 08-14-2016, 10:06 PM
  #584
cweed
cweed's Avatar
I really enjoy this thread, thanks!
Old 08-17-2016, 12:06 AM
  #585
feirfiez
feirfiez's Avatar
Hey Spyerx,
Been watching this thread and have to say, wow! Was wondering why you went with the KWs over Bilsteins or JRZs? Thanks again for letting us share in this journey with you.
P.S. I had the KW Clubsports on my Golf R at one point in time and loved them so not knocking them.
Quick Reply: My 964 C2 Transformation Build Thread
