My 964 C2 Transformation Build Thread
#271
Any idea what the ride height is measured at, I'd also be interested to know what alignment spec you went with. Mine goes in for the uprights soon and you might be able to save me a bit of guess work! Sway bar settings as well if you don't mind!
#273
And...wheels studs ordered. http://www.msiracingproducts.com/products.html
These really are the best out there. Run these on my RS and they are in perfect condition after many, many days.
52mm bullnose studs should work great, with their yellow open ended lug nuts.
#274
You want the porsche single ended studs and the yellow coated nuts (they have pink and black too). They have 4 stock lengths of studs, 3 on their website. I think they have a 60mm too. For my setup the 10.0009 length is perfect front and rear.
#275
I randomly found this thread during a search and of course I thought of your build.
Thought you would like to see this set up.
https://rennlist.com/forums/964-foru...-splitter.html (Nice work Vandit)
#277
Looking at your wheel / offsets and had a quick question. What is the limiting factor on the inside when they are mounted? Do need to be running a coil over with a smaller diameter spring than stock for these to fit? Or would they fit on a car with stock diameter springs? I'm just trying to figure out how many things I need to change at once...
#278
Fronts not sure on inside. If you have clearance concerns get an 8" wheel w a less agressive offset for front.
#279
Did a little canyon driving. Car is real nice.
Here's my impression: super direct and connected, very firm, but supple, not jarring, car is really planted with a ton of grip. It's interesting how similar and how different it feels from my RS. Just turn and it sets and sticks.
Brakes are insane. Like pull your eyeballs out insane.
Tires need some time on them I always find nt01 a little floaty until they get a couple heat cycles on them. Then they grip hard
Also removed lower dash, radio, and passenger air bag and replaced with rennline parts. That setup had to be 25 lbs.
#281
Car will go in for additional work in a few weeks, then i drive it, i'm holding off on any engine or gearbox mods, car runs really strong, want to do some track days and enjoy it:
Quick summary:
--wing
--front splitter
--euro rear bumper
--functional brake ducts
--wiper delete
--remove rear seats
--remove carpets
--remove sound deadening
--remove rear shelf
--install appbiz carpets
--rennline pedals
--rennline floor boards
--rear cage welded in
--harnesses
--recaro seats
--replace pedal box bushings
--drop engine
--valve adjustment
--refinish fan/housing
--possibly 2nd oil cooler
--rothsport headers
--custom muffler and heater setup
--rothsport pulley conversion
--rothsport engine beam
--wevo engine mounts
--rennline tranny mount
--rothsporth shifter, goldenrod, forward rod, and all new shifter bushings
--RS 4.0 clutch/flywheel assembly
I think that is most of it :-) Have most of the parts sitting here, just need to get it to the shop and slot it in, they're finishing some other builds at the moment so probably early march.
Quick summary:
--wing
--front splitter
--euro rear bumper
--wiper delete
--remove rear seats
--remove carpets
--remove rear shelf
--rennline pedals
--harnesses
--recaro seats
--drop engine
--valve adjustment
--rothsport headers
#283
Rennline dash parts in. Next week I think I'll get up the energy to start on the rear interior :-) oh and did rennline heater bypass. Need to jump the relay still.
#285
I've no idea. It was the only non stock thing on the car. It's a kn filter and some sort of l shaped connection. I'm usually a fan of stock air filters but this does make a nice induction noise. Intake point is similar to the stock filter.
