964 Forum 1989-1994
Check your engine mounts!
Old 11-05-2013, 09:01 PM
njansenv
njansenv's Avatar
Default Check your engine mounts!
Well, I've known for some time that my mounts had sagged 'a bit', but I finally replaced them tonight (easiest mounts I've ever replaced! Maybe a 20min job?).
What. A. Difference. I bought the 993 mounts from Pelican, and the car feels quite a bit newer: it was noticable the first time I took off - no drivetrain 'slack' on take off, and better shifting.
I love these cars...
Old 11-05-2013, 09:23 PM
christallon
christallon's Avatar
Yup,
New MM's make a world of difference. I installed the Wevo's with black pillows and have been so pleased with the result. I too love these cars!!!!
Old 11-06-2013, 02:23 PM
garrett1021
garrett1021's Avatar
How can you check?
Old 11-06-2013, 03:00 PM
911Jetta
911Jetta's Avatar
sagging
new
I replaced my sagging MM with Wevo black pillows... wow, really tightened up the car. The new mounts also make on/off throttle transitions much more direct... instead of the engine flopping around.
My experience: (wow, back in 2009?!): Wevo m.m. installed - impressions
https://rennlist.com/forums/964-foru...ferrerid=19642
Old 11-07-2013, 02:48 PM
bmwtinut
bmwtinut's Avatar
Default Bad engine mounts
Well it has been about a month of ownership so far. Can't wipe the grin off of my face every time I take the car out. And yes as others have said I find any reason to go for a drive. One thing that I have noticed is that the car currently rides like a Cadillac, very soft and wallows . The rear shocks are shot. Looking at Bilsteins and H&R greens. In addition the shifting is notchy at times and other times nice and smooth. Took a look at the engine mounts last night and here is what both of them look like. Now this is with the car just parked and not jacked up at all. The outer rubber is cracking and breaking down, very gummy.
What mounts would you recommend upgrading to for daily driving? 993c4 mounts?
Old 11-07-2013, 03:45 PM
911Jetta
911Jetta's Avatar
Originally Posted by bmwtinut
..What mounts would you recommend upgrading to for daily driving? 993c4 mounts?
High quality Wevo Motor Mounts! (no affil)
What do ebay 993 mounts cost?? Can't be much savings... Wevo's cost $300 a set, and you are done.
Old 11-07-2013, 06:12 PM
bmwtinut
bmwtinut's Avatar
993 C4 mounts at Pelican are only $182 a pair.
Old 11-07-2013, 06:24 PM
Vandit
Vandit's Avatar
Careful with eBay motor mounts. People have literally had the motor drop out of the rear of the car from cheap quality, no brand, eBay mounts.
Old 11-07-2013, 06:40 PM
ja78911sc
ja78911sc's Avatar
I installed the 993 C4 mounts from Pelican. I am very satisfied......
Old 11-08-2013, 01:09 AM
garrett1021
Geez guys because of this thread I went out and checked mine ... TOAST...
Looks like New motor mounts are (and have been) needed.
This explains... so much
Old 11-08-2013, 06:04 PM
PelicanParts.com
Basic Sponsor
PelicanParts.com's Avatar
Changing your engine mounts is a straightforward project and does have positive effects as mentioned above. We see this over all 911s needing fresh mounts.
Our 964 engine mount options are listed here and a fairly-applicable article on how to make the swap can be found here.
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old 11-08-2013, 09:10 PM
RW964
RW964's Avatar
All of you check the mounts and see if they look like the ones above and if so get some new ones I went with the 993 mounts and works great for the street easy 20 min install. I need to try the Wevos and see how they are ... Get em done ..
Old 11-09-2013, 02:03 AM
garrett1021
Can someone link to the best/cheapest mounts?
Old 11-09-2013, 11:35 AM
Tmistry
Tmistry's Avatar
Whoa. I just checked mine for the first time. No expert, but they look like there's some travel.
It didn't get mentioned during inspection, so I never thought to look.
Is this really a 20 min DIY R and R? I thought I had to drop the engine?
How do mine look to you guys?
Old 11-09-2013, 01:32 PM
njansenv
njansenv's Avatar
Very easy. I backed onto some ramps, put a jack under the motor to hold it, and then three bolts later the first mount was out. A ratchet, tq wrench, extension, 19mm deep socket and 13mm socket were all that it took. Very accessible.
Quick Reply: Check your engine mounts!
