964 Forum 1989-1994
Project Lightweight C2
Old Mar 6, 2014 | 09:49 AM
  #106
jevvy964's Avatar
jevvy964
Originally Posted by Captain Ahab Jr.
Does anyone have any front wheel arch liners they can weigh for me please!
Front RH side 2 parts = 1200g(dry) + fasteners
Old Mar 6, 2014 | 12:18 PM
  #107
9six4's Avatar
9six4
Mine came in at 1322g (732/590) for the right and 1296g (724/572)on the left. (w/two metal clips still on). LHD car if it makes a difference.
Old Mar 6, 2014 | 02:32 PM
  #108
jevvy964's Avatar
jevvy964
Good work, were those wet or dry weights? Clean or dirty? Did you calibrate your scales beforehand
So are you gona round up or down Stephen?
Old Mar 6, 2014 | 03:59 PM
  #109
9six4's Avatar
9six4
They were clean and dry, but not detailed! I put a pound of butter on the scale for calibration.
Old Mar 6, 2014 | 06:06 PM
  #110
Captain Ahab Jr.'s Avatar
Captain Ahab Jr.
WOW, my boring pictureless thread has been noticed, glad people are reading it and hope all my weights help others.
Originally Posted by Nski
Keep on stripping
Do away the glass for perspex, doors, wings bonnet, bootlid, door mirrors, loom, carpet, underfloor underseal & paint, exhaust boxes, engine tin wear, wheels for lightweight, are you doing all these?
Want to get to the end of the stripping stage first, still got a lot of kgs to go with ABS delete, power steering delete, sunroof delete and few odds and sods. I'm pushing to hit 200kg of stripped weight (will be hard but I don't think impossible) and then yes to lightweight parts for everything you have listed and more
Originally Posted by Andy Roe
What about aiming for something like this?!
That is mad, its lost all the pleasing qualities of the 964 shape so not a direction I will follow. I'd like my car to look fresh like Nski's, love the clean, simple and understated look
Originally Posted by kos11-12
captain, great job !
I am thinking buying the tools to make carbon parts from Easy composites in UK, but it's quite time consuming
thanks kos, carbon is my thing been designing cars with it since 1989, Easy have done a great job de-mystifying it all. Go for it as I'm sure you'll get a lot of satisfaction from making your own parts, for inspiration have a look at Rob964's excellent build. Feel free to PM me if you need any advice
Thank you very much gentlemen, this info. has pushed me onto the right side of 160kgs, I'm going to go for middle for diddle and call it 1250g per side, always find its better to be pessimistic when it comes to weight saving
Old Mar 6, 2014 | 07:07 PM
  #111
Captain Ahab Jr.
forgot to update my running total
2.50kg pair of front wheel arch liners including fixings
Weight removed running total 160.66kg or 354.2lbs
Old Mar 8, 2014 | 05:43 PM
  #112
Captain Ahab Jr.
and yet another round of part removing
0.368kg LH rear plastic lower engine shroud and fixings
0.352kg RH rear plastic lower engine shroud and fixings
0.582kg RH plastic lower engine shroud and fixings
not sure what the correct name is for these parts, they are plastic silver foil covered panels that seal around the engine between the engine tin and the rear under tray panel to duct the engine cooling fan out through the two rectangular holes in the rear under tray
0.444kg pair of bumper mounting to chassis rail reinforcing steel tubes
0.025kg rear under tray steel mounting bracket (forward engine position)
0.102kg radio chassis steel surround
0.219kg pair of HVAC dash vents, ones nearest the doors
Weight removed running total 162.75kg or 358.8lbs
not driven my car since starting this diet but I can really feel the difference when pushing it in and out of my garage
Old Mar 15, 2014 | 08:04 PM
  #113
Captain Ahab Jr.
and yet another go at picking off weight
5.062kg front aluminium bumper beam and mounting bolts
0.917kg front bumper steel mounting tubes, mounting bolts and gaskets
0.388kg large horn and steel mounting bracket (a bracket on a bracket )
0.349kg steel mounting bracket for horns
0.050kg foam front bumper in fill pieces
0.246kg headlight washer nozzles and tubing in the front bumper
0.387kg LH dash knee pad
0.406kg RH dash knee pad
Weight removed running total 170.555kg or 376.01lbs
Think that's about enough stripping of parts for now
Need to reconnect my ignition wiring, fire up the engine and check all the electrics work before starting to pick apart the wiring loom.
Hoping by the end of all the stripping of parts the car will be 200-205kg lighter, then upward and onward with fitting some lightweight parts
Old Mar 16, 2014 | 11:56 AM
  #114
kos11-12's Avatar
kos11-12
Hi captain, good stuff ,
You are replacing the front beam or drive without it ?
Old Mar 16, 2014 | 12:36 PM
  #115
jack.pe's Avatar
jack.pe
Hey Cap, glad to see you're finally going to stop taking stuff off!! Great work so far!
Had mine weighed again two days ago while doing geo and it was 1348kgs with 3/4 tank of fuel. So that tallies with the previous measure of 1304 with less than a quarter tank I think.. Yours should be way better!
Old Mar 16, 2014 | 06:57 PM
  #116
Captain Ahab Jr.
thanks Kos, I'm going uber-light on this build so front beam won't be replaced
thanks Jack, not stopping taking stuff off, just taking a pause to take time out to simplify the wiring loom
Does anyone have a weight for a pair of front spotlights they can post up please??
Old Mar 16, 2014 | 07:03 PM
  #117
J81 JKR's Avatar
J81 JKR
You're removing the bumper beam(s) to save weight? Seems a little OTT to me considering their structural benefits in an accident (god forbid)...
Very interesting thread, just hope you don't compromise your safety for the sake of (minor) additional speed gains
Old Mar 16, 2014 | 07:17 PM
  #118
Captain Ahab Jr.
thanks for your concern, I drive my 964 in the same way I ride my bicycle on the road here in Italy
Basically I assume everyone else on the road is a complete idiot and are out to kill me
Old Mar 18, 2014 | 08:19 AM
  #119
blockhed's Avatar
blockhed
Who here has the lightest c2 that is still driven on the streets here and there?
Captain- what is your final goal?
Old Mar 18, 2014 | 10:10 AM
  #120
ThomasC2's Avatar
ThomasC2
I'm not the winner but I'm at 1.190 kg with 10 L of petrol, no driver. (a C2 MY -92)
Thomas
