964 Forum 1989-1994
9m11RS-R - creation of a modern icon - '74 3.0RSR on 9m64RS platform
Old 01-06-2012, 12:58 PM
  #496
deutschland-dobson
deutschland-dobson's Avatar
Originally Posted by NineMeister
OK, so let's have some good news. Hands up who likes the new 9m billet machined centrelock hub adapter, as made by the guys who machine similar items for several Le Mans Sports Car manufacturers.
Looking good!
How thick is the adapter? Just wondering of this could allow for the fitment of centre lock BBS E28's on the 964?
Chris
Old 01-10-2012, 12:18 PM
  #497
The Old Dutch
The Old Dutch's Avatar
Hi Colin, 9m guys and dear fellow forum sisters & brothers, wishing you all a very happy new year 2012. Life with happiness, bright cheer, joy, prosperity and good health, more and more updates on those fantastic builds 9M has to offer and last but not least pure driving pleasure in our beloved Porsches.
Old 01-10-2012, 02:05 PM
  #498
BHMav8r
BHMav8r's Avatar
Received 2,772 Likes on 1,753 Posts
Many thanks for all the great pics on a project I could only dream of and will never have the means or knowledge to complete.
Old 01-16-2012, 11:04 AM
  #499
NaplesBound
NaplesBound's Avatar
Colin, any more updates? I'm keen on seeing the motor write up myself. I know you guys have probably been working full bore over there, but this build is what brings me to the board(and your other posts). Keep it up!
Chris
Old 01-19-2012, 09:32 PM
  #500
NineMeister
NineMeister's Avatar
Sorry for the leave of absence boys, it's that work thing getting in the way of having a good time again.
Lots of progress, but all in details that do not seem to amount to much. Robin has been working on the heater box this week, deleting everything apart from the aircon evapourator and direction valves. The plan is to bin the stepper motor controls and replace them with a set of early 911 heater sliders to save weight and provide the correct early 911 look to the dash.
Old 01-19-2012, 09:46 PM
  #501
NineMeister
Meanshile, Jack has been working under my supervision sorting out the oil system. The (freshly painted) 964 oil thermostat fits in the usual location under the oil tank (which will be filled from inside the engine bay), along with stock 964 lines and oil filter housing.
The front oil coolers are proving to be a bit of a nightmare, but I think we are getting there now. The original plan to use a standard laterally mounted 964 oil cooler has been abandoned in favour of the late 3.2 Carrera / 930 turbo unit which allows a lot more wheel / tyre clearance. New oil lines will have to be produced to fit this, but relatively speaking it is an easier job than getting the 964 cooler to fit.
The front mounted Setrab cooler is also proving to be a pain as well. This rad fits nicely into the opening of the front bumper, however we now need M22x1.5 banjo fittings for the end because there is not enough room for a conventional in-line connector. Any suggestions here would be welcomed.
Fan assistance will be used on both coolers, we'll finalise this once the pipework is done just in case there is a clash of space issue.
Old 01-19-2012, 09:50 PM
  #502
NineMeister
Originally Posted by deutschland-dobson
Looking good!
Chris
The centrelock hub is 30mm thick, uses conventional steel 911 nuts to hold it on and BBS M72 wheelnuts in LH & RH threads.
Old 01-19-2012, 09:57 PM
  #503
NineMeister
Gearshift cable mountings were finalised last week, this is the basic bracketry before full fabrication and the routing of the cable past the inner trailing arm mount. Special order motorsport cables will be commissioned for the final installation.
Old 01-20-2012, 12:29 AM
  #504
FeralComprehension
FeralComprehension's Avatar
You mentioned this once before. Is it a fairly straightforward operation, or are grizzled guys and a machine shop required? Given the.... idiosyncratic? nature of the HVAC controls in these aging machines it would be nice to have something simpler to fall back on.
Old 01-20-2012, 10:31 AM
  #505
NineMeister
It is, and it isn't. Because the car is destined for a hot climate we are only fitting aircon, so the basic flap functions we have are up/down and centre off/on, there are no mixing flaps for the heater. Then there is the retro fitting of a suitable heater control module in the dash; we luckily sourced a rare, oversize new old stock unit which fits the hole perfectly. I'll post more photos later this afternoon.
Old 02-04-2012, 03:52 AM
  #506
My car is faster
My car is faster's Avatar
any updates?
Old 02-12-2012, 09:33 AM
  #507
My car is faster
Still no updates??????
Old 02-12-2012, 05:35 PM
  #508
evoderby
evoderby's Avatar
Some nice Lollipop seats:
https://rennlist.com/forums/9064625-post54.html
No affiliation.
Old 02-29-2012, 10:49 AM
  #509
Jacke2c
Formerly turbotwoshoes
Jacke2c's Avatar
Unhappy How's the beast progressing?
Updates? I am having withdrawls.
Old 02-29-2012, 03:00 PM
  #510
Madness911
Madness911's Avatar
Why did I miss? ooops still no updates....
Quick Reply: 9m11RS-R - creation of a modern icon - '74 3.0RSR on 9m64RS platform
