964 Forum 1989-1994
Porsche 964 - 200kg challenge
Old 06-14-2022, 01:16 PM
  #286
revolve40
revolve40's Avatar
@Jonte Thanks for sharing this journey with all of us. I've watched most of your videos several times over already. I'm curious about your plan for oil breather lines and PCV ventilation. Watching the oil tank video, seems like you will run the standard breather from the crankcase to the oil tank. What about the pre- and post- throttle body hoses? Any concern about pressurizing the tank with blow by if you just plan to vent to atmosphere? Seems like in stock form, the tank needs suction from behind the throttle body to pull excess gasses out of the tank to prevent pressurization.
Old 06-14-2022, 05:25 PM
  #287
Ski Porsche
Ski Porsche's Avatar
Jonte taming Spa! I love it. Nice find Sirenty.
Jonte (06-26-2022)
Old 06-22-2022, 03:54 PM
  #288
Henrik964
Henrik964's Avatar
One of those threads and the Youtube that will be alive forever.
Jonte (06-26-2022)
Old 09-21-2022, 01:03 PM
  #289
Jonte
Jonte's Avatar
Default Next piece uploaded
A long break and summer Holliday is now behind me ;-)
Back on Track - Installation of Steering Column
fridtjov_RS (09-26-2022)
Old 09-24-2022, 04:28 AM
  #290
Jonte
Jonte's Avatar
This is a piece I’m not completely finished thinking about.
I either put a catch tank to the crank case in the back and ventilate that to the air filter.
or I pull a long hose all the way to the tank where I will have to have a catch tank anyway on the breather.
appreciate any insight on this!
Old 09-29-2022, 10:00 AM
  #291
Peteinjp
Peteinjp's Avatar
Always fun to watch for sure!
One thought: I've found (not a pro by any means so FWIW) that when when welding though holes in a tube to a plug (in your case the double D's) that countersinking the holes in the tubing gives much better penetration to the pressed in parts. With steering parts you want all you can get in terms of connection.
Pete
Jonte (12-11-2022)
Old 12-11-2022, 05:07 AM
  #292
Jonte
Jonte's Avatar
Default Frunk is coming together finally!
Plumber time - Brake and fuel line madness!
The following 2 users liked this post by Jonte:
kos11-12 (12-11-2022), weekndr.porsche (12-12-2022)
Old 12-11-2022, 09:06 AM
  #293
Peteinjp
Peteinjp's Avatar
Another awesome episode Jonas. I've used inch compression fittings with metric lines on my old BMW 2002 tii rear brake lines with success so you'll likely be fine. That said I also was looking to adapt the steel fuel lines of the 964 to AN-6 and found both the 8 and 10mm adapters here: https://www.lindseyracing.com/LR/Por...A-COMPFIT.html
Don't think you'll need them but just in case someone else comes across this issue that does not have your skills to adapt the 3/8" fittings....
Pete
Jonte (12-11-2022)
Old 12-11-2022, 12:42 PM
  #294
Jonte
Jonte's Avatar
Pete
I might end up needing those fittings in the end…Thanks for the recommendation!
Peteinjp (12-13-2022)
Old 01-01-2023, 12:01 PM
  #295
Jonte
Jonte's Avatar
Default Oil tank found its home
Oil Tank 2.0 - Remote mounted dry sump tank
koenig_roland (01-04-2023), weekndr.porsche (01-01-2023)
Old 04-29-2023, 01:21 PM
  #296
Jonte
Jonte's Avatar
Finally some more time in the garage and finally managed to pull the switch and power the electrical on!
The following 5 users liked this post by Jonte:
Ecosse911 (04-29-2023), Garydose (05-19-2023), jeff33702 (04-29-2023), kos11-12 (05-04-2023), weekndr.porsche (05-01-2023)
Old 04-30-2023, 09:24 AM
  #297
Peteinjp
Peteinjp's Avatar
Epic step! Those heat shrink boots are simply amazing and the level that you brought this up to with the wiring and electrical complements engineering-
So - did you have to build those harnesses more than once or did you get it all right the first time. That is the only thing that I don’t understand about the harnesses is that it seems you have to start over from the beginning if you need to make a change to a part of the system.…?
Pete
Old 04-30-2023, 11:34 AM
  #298
Jonte
Jonte's Avatar
Pete
I did make a mistake in how I spliced the can bus wires that I will have to live with as it's bured deep inside. Not a big thing but will chase me in my nightmares...
It's a bit overkill, but a fun process and becomes part of the design concept and appearance of the build since it's all exposed!
Old 04-30-2023, 05:34 PM
  #299
38D
38D's Avatar
Really nice work. One small suggestion is to abrade the raychem before adding the epoxy; this creates a stronger bond that is less likely to fail.
And you are absolutely right that people have no idea how long this stuff takes.
Old 05-01-2023, 07:19 AM
  #300
Jonte
Jonte's Avatar
This step I missed completely. Thanks for the tip!
Quick Reply: Porsche 964 - 200kg challenge
