Porsche 964 - 200kg challenge
^^^ that's going next level.
If you REALLY wanted to be baller you'd get a motec PDM setup and remove the majority of the wiring with 2-3 simple power boxes and CAN cables between them :-)
Just cry when you see prices!
This is what race cars use, there are some guys using them on their hot rod builds, makes for an amazingly clean install. Basically an ECU, a power module in front and rear and engine, and that module basically has a power cable and CAN bus cable, and then the wiring from there.
Take a look at what Andrew has done on his 911:
https://www.instagram.com/rasantproducts/
I’ve not ordered mine yet but I’m going PDM for sure. Just uploading episode 166 now where you can see why ;-)
I pulled weight off my 964 anywhere I could think of. Down to 2640 lbs keeping a/c, radio and sunroof. Still some more I could remove but for now I'll just keep it like that. I can definitely feel the difference
911Jetta (12-18-2019)
what is 'boattailing the block' ?
I’ll show more about this in a later video as I check the engine.
The following 2 users liked this post by Jonte:
Mikke_Possu (12-29-2019),
RyanH. (12-29-2019)
Jonte (12-28-2019)
911Jetta (12-28-2019)
Me too. Makes me really want to tear apart (someone else’s 964).
Really good job communicating your thought process, making it fun to follow along. Plus, it’s honest too, you show your mistakes. We’re all rooting for you. Post on RL Facebook if you haven’t already, this series deserves a larger audience.
The following 2 users liked this post by 911Jetta:
JP-"S" (02-18-2022),
weekndr.porsche (12-28-2019)
