It's alive!! My 3.3l
Old 07-20-2016, 04:54 AM
  #136
333pg333
333pg333's Avatar
How much do you pay at the pump for it Sid / Shawn? Another issue seems to be a variation of or inclusion of MTBE in Flex Fuels. This is the component that is the most harmful for motors, injs, fuel systems etc.
Old 07-20-2016, 11:42 AM
  #137
dizzyj
dizzyj's Avatar
in texas e85 is ~$1.50 a gallon right now. I've looked at vp racing e85, but its ~9$ a gallon for a 55 gallon drum. At that cost, im not sure what the benefit of e85 vs say a 104 race gas would be. I would consume less fuel with race gas
Old 07-20-2016, 06:03 PM
  #138
refresh951
refresh951's Avatar
About $1.70 us per gallon. I have been running pump E85 exclusively for years now and seen no ill effects to any components.
Old 07-21-2016, 01:06 AM
  #139
v8killer
v8killer's Avatar
$2.25/ gal in AZ. Been running pump E85 since 2011, 22k miles and a lot of HPDE events with no issues at 22psi.
Old 07-21-2016, 03:15 AM
  #140
333pg333
333pg333's Avatar
Damn that's so cheap!!!
Old 07-21-2016, 11:53 AM
  #141
blown 944
blown 944's Avatar
1.99 down here. A little further away than what I was used to in Colorado, but still worth it to fill up a few jugs whenever I'm close.
Old 07-21-2016, 03:55 PM
  #142
David Floyd
David Floyd's Avatar
My 2 local stations recently changed wording from
E85 min 70% to Flex fuel min 51%
Alarmed at first but as of now in the summer heat still tests out 85%.... We will see if mixture changes when temps cool down.
$1.49 per gallon
Old 07-21-2016, 06:49 PM
  #143
refresh951
refresh951's Avatar
Racetrac built a new station 3 miles from my house with E85 and they built a new station right next to Road Atlanta that has E85.
Old 07-22-2016, 12:27 PM
  #144
dizzyj
dizzyj's Avatar
update: looks like we are going with -8an teflon coated lines for supply, and -6an return.
I feel like a mini tony g
Old 11-06-2016, 10:27 PM
  #145
dizzyj
dizzyj's Avatar
Thought I'd give another update. It's been a while.
I'm now running ptfe coated fuel lines 8 and 6 an with a fuelab pump. Been dealing with trying to get it reasonably tuned. It's been pretty difficult but I've been learning a lot. We finally got it to a point where the car is running reasonably well on e85 and Ive hit my limit on what to do to the tune next. We found a shop in Houston who knows turbos, e85, and the tec3 so at this point we're going to take it to a tuner with a dyno. Hopefully that's the last bit and nothing else needs to be done to the car. It's been 2 years since I've driven it
Old 11-07-2016, 11:45 AM
  #146
dizzyj
dizzyj's Avatar
if anyone is interested in seeing a current datalog, this is our starting point. This is a little log viewer I wrote since the tec3 software is pretty much crap.
one is with tog set to 9, the other is with tog set to 11. the 9 to me looks better, but the 11 feels better when driving. This is only done on an empty side street, NOT on a dyno.
File Type: html
File Type: html
Old 11-16-2016, 10:50 PM
  #147
dizzyj
dizzyj's Avatar
And we're done!!
Old 11-16-2016, 11:03 PM
  #148
rlm328
rlm328's Avatar
What kind of boost are you running?
Old 11-18-2016, 01:37 AM
  #149
dizzyj
dizzyj's Avatar
That's running e85 at 18 on a fairly conservative race tune
Old 11-18-2016, 06:09 AM
  #150
Thom
Thom's Avatar
Stock cam and intake?
Quick Reply: It's alive!! My 3.3l
