VW/Audi 07K (2.5L 20V I5) Swap Thread
#1291
I was thinking of the front mount option for my car, maybe I can figure out how big the core/end tanks can be and estimate the piping run this weekend. Maybe I can come up with a decent intercooler design that we can leverage as a group. How many of you guys are looking at the front mount option?
#1292
Are the trap doors going to be welded onto the inside of the baffle box, or rivet/bolted? Also with either option will the hinge have enough clearance to rotate without getting stuck by rubbing on the inside of the box?
Other than that, looks good. Id put that in my car in a heartbeat.
The trap doors I'm planning to use are aluminum and they're supposed to be riveted. Also I think the lower pan and baffles will be steel, so I wouldn't be able to weld them anyway.
Yes, I am designing the position of the trap doors so they can't interfere with each other or with the pickup. These particular trap doors have hard limits that prevent them from rotating up more than about 45 degrees (to prevent them from flipping all the way up and sticking up there).
#1293
Rainman
#1294
#1295
I was concerned that when pressed tightly up against the wall of the baffle box, the moving plate's hinged connection would rub on the wall and be sticky. Upon further inspection of the trap doors, I see now that they are sufficiently bent outwards in a way that this won't happen.
Seen here:
So we're good. I answered my own question 😁
#1296
Right, but I was talking about the circular part of the hinge that rotates, right here:
Seen here:
Seen here:
#1297
I’m looking at finding something like this with measurements to allow me to pass through the factory intercooler holes in the nose . I can have one made by Griffin , don’t know about a price yet .
#1300
The one I have for my widebody car is nearly identical to this. It’s an eBay bar and plate job designed for a FD RX-7. Super inexpensive and I’ve had good luck with those intercoolers in the past
#1301
Rainman
No-- between the frame rails ahead of the radiator is less than 25".
Here's a potential intercooler if you don't care about going up through the factory holes in the core support. Says it's good for up to 550 hp. LINK
I wonder if it would fit without cutting the factory sheet metal structure between the "frame rails"
#1302
I mean something different.... I think the typical FMIC mounting on a 944 requires this sheet metal beam between the rails to be cut out (in red).
Here's a pic of a FMIC mounted, and shows where they cut out that sheet metal and welded in a tubular cross beam.
And shown in yellow is what I'm suggesting. The intercooler pipes would go around the outside of that 25" frame you're referring to. They would come up in the space behind the headlights.
#1303
Anyone going to 944 Fest? It's in a few weeks at Nelson Ledges Road Course (northeastern OH). Unfortunately it looks like we are not quite going to have Mike's car running in time, but I plan to bring my car with everything mounted up (everything that that we have so far, anyway).
#1304
Im in... Gonna bring another 944 guy with me from buffalo. It will be cool to see all the parts on your car... Im Just observing at this point and have a chassis in the woods ready to make a killer o7k Track car at some point...
