VW/Audi 07K (2.5L 20V I5) Swap Thread
Old 05-02-2018, 11:48 AM
  #271
nickskater09
5th Gear
nickskater09's Avatar
Originally Posted by V2Rocket
i say that because they seem not to have any interest in acquiring actual customers, only shotgunning pictures of beautiful cars with 1.8 engines fitted.
they have a continuous history of never answering direct questions through any line of communication regarding pricing info, so for now, just wall posters.
You should probably check out the Jäger "wall poster" turning laps on the MWR Facebook page. Which might I add, is a customer's car, just like all the rest of the builds. https://m.facebook.com/story.php?story_fbid=2011042082302735&id=109417815798514
Old 05-02-2018, 12:21 PM
  #272
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by nickskater09
You should probably check out the Jäger "wall poster" turning laps on the MWR Facebook page. Which might I add, is a customer's car, just like all the rest of the builds. https://m.facebook.com/story.php?sto...09417815798514
like you guys have been doing for years now, just deflecting off the actual question.
good luck.
Old 05-02-2018, 01:13 PM
  #273
chrenan
chrenan's Avatar
Can you post a pic of your bellhousing to torque tube adapter solution?
Old 05-02-2018, 07:05 PM
  #274
alxdgr8
alxdgr8's Avatar
It's just a simple adapter plate, several other 944 people have used a similar solution for 1.8t swaps
The 1.8T head does have some protrusions on the rear, but nothing that interferes with the 944 bellhousing or an adapter.
The 07k on the other hand...
Old 05-02-2018, 07:08 PM
  #275
alxdgr8
alxdgr8's Avatar
Should be pretty easy to build mount arms that use the factory crossmember mounts using the Iroz adapter block. I'm not concerned about that aspect.
Old 05-02-2018, 07:53 PM
  #276
nickskater09
5th Gear
good luck.
I don't know what question Ive deflected off of. I was just replying to your wall poster comment showing the cars get used. If you're referring to price, their contact information is on the website. If you're talking about how the swap is done, that's not something I'd expect a business to just throw up on the internet for free to copy when they've spent hours researching it.
Old 05-02-2018, 08:48 PM
  #277
chrenan
chrenan's Avatar
This is a technical forum, not social media, so the expectation here is technical content and discussion. I’ve seen your work on Facebook and it’s very impressive, but I’d never ask technical questions there as it’s an advertising medium for the most part. To advertise here you need to pay to be a site sponsor, but you’re welcome to delve into technical conversation for free. Welcome, and glad to have you here!
Old 05-02-2018, 09:31 PM
  #278
nickskater09
5th Gear
No advertising here, I just want to share cool stuff!
Old 05-03-2018, 09:35 AM
  #279
vt951
vt951's Avatar
Ok, let’s get back on track (sort of)... here’s the car I’m going to install my 07k in. Just pulled out the LS last weekend, so it’s a nice clean slate!
Old 05-03-2018, 01:13 PM
  #280
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
holy SHlT (a five cylinder engine might finally be in a 944?)
and holy SHlT.... (8 cylinders to 5 cylinders?) :sosad:
Old 05-03-2018, 03:37 PM
  #281
vt951
vt951's Avatar
My buddy Dan has coined the name "Project Displacement Replacement." I probably should start a new thread showing the build, rather than clutter this one. Maybe when I get a little bit further along...
Old 05-04-2018, 11:38 AM
  #282
Chris Prack
Chris Prack's Avatar
Looking forward to seeing where this goes. I've never considered swapping out the Porsche engine in my personal car until now. I've driven several of the recent 5 cyl cars as I work at the 4 ring HQ and love the engine.
Old 05-05-2018, 09:56 PM
  #283
odurandina
Team Owner
odurandina's Avatar
i think it's really cool VW & Audi are back building 5 cylinders.
So sad there isn't a high displacement racing block available.
Does anyone know what years since the Audi 5000 was first introduced to recent years
when VAG/Audi wasn't running a 5 cylinder in at least one of their production cars?
i know we had them in some VW Quantum's after 1981 over here, the Audi 90's and 1990's S4's
w/ turbos.
Old 05-06-2018, 12:43 AM
  #284
audisport
audisport's Avatar
I don't believe there was any 5cyl turbo in the US from 1994ish? AAN motor with the UR S4/6 till the MK2 TT RS in 2012. At least a turbo version. The rabbit/golf had a NA 2.5 for a while. Not sure on years.
Old 05-06-2018, 10:54 AM
  #285
vt951
vt951's Avatar
Good news... it looks like we will be able to use a 240 mm clutch setup. The flywheel and pressure plate will be same as or similar to a VR6 w/ 6-spd 02M trans. Clutch disk will be 951. Starter will likely be from 02M trans. TOB and slave will either be VW or Solstice GXP (recommended by Dave at SPEC). I have a bunch of these parts on order to get dimensions and design the bellhousing around. Should have what I need to finalize the bell design next weekend (hopefully).
Quick Reply: VW/Audi 07K (2.5L 20V I5) Swap Thread
