VW/Audi 07K (2.5L 20V I5) Swap Thread
#1951
Glad I invested in a power bleeder a while back then. Curious as to how all the air gets out of the system though, but I guess that by forcing fluid into the slave the air works its way back into the reservoir/power bleeder.
#1952
Hmm, sounds like I forgot to package some clutch slave bolts. If you want to get them at your local hardware store, they are 15 or 16 mm long M6 x 1.0 socket head cap screws. Or we can include them in your intake manifold shipment (assuming you ordered one). As for the small size, they are ok because this is a push type clutch, so all those bolts are doing is holding the slave in place. The back of the bellhousing takes all the load.
The slave bled very easily on my car and Mike’s. I think the first time I did mine, I didn’t even use a power bleeder. Just keep the brake fluid reservoir full while you very slowly lift and push down the clutch pedal through its full stroke.
Thanks for the positive feedback on the oil pan. Glad you’re happy with it!
Wow guys, I am majorly impressed. The oil pan looks amazing, certainly worth the wait. Was the bellhousing supposed to come with bolts for the slave cylinder? If not, what size bolts should be used? They seem quite small for a slave cyl but I guess if it worked for GM it shouldn't be a problem for us. Lastly, I noticed there isn't a bleeder on the slave. Do you only bleed it at the master?
#1953
David from PE brought over my harness to test fit yesterday. It is our first production 07K harness, and it is beautiful. Really nice loom and heat shrink job, and every connector is labeled. This is how they will all be done.
I will be using some of the valve cover bolt locations to add some p-loops to hold the coil harness in place... just wanted to snap some quick photos to show you guys what it looks like.
The following 4 users liked this post by vt951:
Droops83 (05-02-2020),
EastEnd944 (05-02-2020),
SamGrant951 (05-03-2020),
senior_squishy (05-02-2020)
#1955
Yes. However, our first batch of thermostat housing cover adapters got lost in transit. We are waiting on the second batch and they will be here in a few weeks. Unfortunately you can’t permanently install the intake until you have this piece so we were going to wait to ship it all together. I’m fine with shipping intakes now though if that’s what you all prefer. There is also some wiring that needs to be done with the intake off for proper access, although you might be able to access it from below.
#1957
#1958
Other major things to install on the engine before dropping it in: upper oil pan and pickup, oil sump, flywheel, pilot bearing adapter, clutch disk, bellhousing, TOB. Optional: psgr side engine mount.
I’d recommend having little else on the engine so it’s easier to get it in without scratching your paint (ask me how I know 😬.
#1959
As long as you have the rear coolant flange installed, you’re good. There’s plenty of room to install hoses and sensors afterwards.
Based on our experience, it is easier and safer to install the header/manifold and power steering AFTER the engine is in the car.
#1960
I've spent the entirety of the day attempting to get the engine into the car. However I can't get it to go the last inch or two (which I assume is the clutch/pilot bearing being a pain). I have the subframe lowered as much as possible without taking the bolts out, torque tube jacked up, and don't have anything extra on the engine that is preventing it from going in. I believe my current issue is that even though I have done all of that, the lower oil pan still hits the subframe, which I think is blocking me from being able to get the engine level enough to push into the clutch/pilot bearing. However, I'm pulling it out tonight to check if the clutch isn't centered, as the tool that came with mine has a decent amount of room for play and that could also be the issue. As for the paint... well my engine bay certainly could use a fresh coat as is.
#1961
Can’t emphasize enough, get the crossmember out of the way, and get the engine hanging at the correct angle before you start sliding it back. As far as lifting the torque tube all the way up, that was something we had to do when we didn’t remove the crossmember (due to oil pan hitting crossmember, like you said). The problem with raising the torque tube is it puts it at an angle relative to the floor, so when you roll the engine hoist backwards, it puts the driveshaft in a bind with the clutch. So, again, remove that crossmember, and everything should be easier!
Sorry it didn’t go all the way in yet.. keep trying and you’ll get it.
#1962
Yeah, if the clutch disk isn’t right on center, the tip of the driveshaft isn’t going to line up with the pilot bearing. Also, we recommend removing the crossmember completely so you have a clear path to align the engine with the torque tube. And, use an engine leveler on your engine hoist to get it at the correct angle (fore/aft). It also needs to be clocked pretty close to 15 degrees (tilted toward psgr side) so that after you get the engine all the way back, you can get the four torque tube bolts into the back of the bellhousing. Another thing we found helps if the driveshaft spline doesn’t want to go into the clutch disk, spin the crank using a strap wrench around the crank pulley while you push the engine back. I know you got further than this, but these tips might help others as well.
Update: Took me maybe 5 mins to work it into position with the crossmember removed. For those who have yet to install their engines, take the 10 minutes to drop the crossmember. It'll save you a day of headaches
I'm happy to say I now (hopefully) have my engine permanently installed. I was able to manage it on my own but I'm sure it would be even easier to slide onto the driveshaft if you had another person helping to level and raise/lower the engine.
#1964
Hey Patrick, does this pic help? If not, let me know what other angles you need.
Looking at my car now, this turbo location is definitely in the way of a RHD steering shaft. I think a good option for RHD could be to use the Gallardo header and mount the turbo up front. Lots of room in front of this engine.
[/QUOTE]
