My porsche 944 S2 16 valve turbo project
Old 12-24-2013, 09:44 AM
  #181
blade7
blade7's Avatar
Tim had no choice but to make a new manifold, how much benefit would that plenum and throttle body give with an 8V head I wonder ? I still think the inlet should be opposite the runners like a Cosworth.
Old 12-24-2013, 06:58 PM
  #182
turbotim3
turbotim3's Avatar
Originally Posted by refresh951
Thanks Tim, very helpful. Thanks! I found this on ebay:
[URL="http://www.ebay.com/itm/intake-manifold-for-Toyota-supra-1jzgte-1jz-jzz30-turbo-intake-manifold/201006976156?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo% 3DSIC.FIT%26ao%3D1%26asc%3D19462%26meid%3D3609705980212471667%26pid%3D10 0005%26prg%3D8798%26rk%3D1%26rkt%3D5%26sd%3D131074595130%26"]http://www.ebay.com/itm/intake-manifold-for-Toyota-supra-1jzgte-1jz-jzz30-turbo-intake-manifold/201006976156?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo% 3DSIC.FIT%26ao%3D1%26asc%3D19462%26meid%3D3609705980212471667%26pid%3D10 0005%26prg%3D8798%26rk%3D1%26rkt%3D5%26sd%3D131074595130%26[/URL
Any chance you could post up some basic dimensions? My application would be slightly different as it would be for an 8V. Mainly looking for dimensions on the plenum.
Yes that's the one. You have cut a little of the width and the length also. Some welding involved but its a good shape and a nice strong casing.
Originally Posted by Thom
Tim, how did you do the bellmouths on the back plate?
Looks like he kind of incorporated them into the plate itself.
The bellmouth is machined into the plate on a CNC milling machine. It then as a recess in the other side for the runners to sit, welding to both sides and then port and finish. Then its a case of fitting and welding the plenium on.
Old 12-24-2013, 07:19 PM
  #183
turbotim3
turbotim3's Avatar
Your right I had to make a new manifold, mainly because there was nothing out there for a 16 valve, nothing I liked the look of anyway.
Whether it would be any good on a 8 valve only trying it will tell. I think the plenum works well, all four cylinders burned equal, spark plugs all same colour. no cylinder trim required and it made dam good power.
Old 01-18-2014, 12:06 PM
  #184
turbotim3
turbotim3's Avatar
I have now got the intercooler made and installed. It as a 100mm/4inch bar and plate core, I have a 63mm inlet on the left hand bottom corner and a 70mm outlet on the right hand top corner. I've just got the connection pipes to make.
Its all coming along nicely, I'm also waiting for my flywheel and clutch to be made and I should then soon have her up and running.
Some pictures of intercooler.
Old 01-18-2014, 03:57 PM
  #185
gruhsy
gruhsy's Avatar
Nice. What's the intercooler coated with?
Old 01-18-2014, 06:18 PM
  #186
turbotim3
turbotim3's Avatar
just a couple of coats of satin black paint
Old 01-18-2014, 06:44 PM
  #187
Dougs951
Dougs951's Avatar
Very interesting approach for the intercooler.
Old 01-18-2014, 08:37 PM
  #188
333pg333
333pg333's Avatar
How long until you have it on the rolling road Tim? Be good to compare temps with the new i/c.
Old 01-19-2014, 05:32 AM
  #189
Diver944
Diver944's Avatar
It's all coming together nicely Tim. Shame you're not a few weeks further down the road to completion as there is a 944 Dyno Day down in Thruxton next weekend. It would have been great to get your beast along
Old 01-19-2014, 10:02 AM
  #190
blade7
blade7's Avatar
I'll be interested to see how it all gets plumbed up in the space.
Old 01-21-2014, 03:42 PM
  #191
turbotim3
turbotim3's Avatar
Paul, Surely you don't think I've made an intercooler and fitted it, without first working out how its going to be piped up.
Old 01-21-2014, 04:38 PM
  #192
blade7
blade7's Avatar
No Tim, I first wondered how it was going to be piped up when I saw the inlet manifold
Old 01-21-2014, 07:20 PM
  #193
333pg333
333pg333's Avatar
Does look like it's going to be tight coming up from the bottom there?
Old 01-21-2014, 07:25 PM
  #194
V2Rocket
Rainman
V2Rocket's Avatar
is the turbo pointing down?
Old 01-21-2014, 09:13 PM
  #195
refresh951
refresh951's Avatar
I believe the compressor is clocked down. Pretty cool configuration.
Quick Reply: My porsche 944 S2 16 valve turbo project
