CNC'ed Aluminum Water Tree Adaptor for DBB Turbo Upgrade
#121
Found this on the Aeroquip website to help with AN sizing:
http://aeroquipperformance.com/file/...ting+Sizes.pdf
Print it out and then lay your fitting on top of the print out.
Looks like -6 and -4 AN for my Lindsey Super 53.
#122
Any pics Bruce?
I have a new Lindsey Super 53 TBB that just arrived yesterday and I'm going to be using one of Eric's trees.
I'm struggling with the AN fitting sizes as well, my turbo came with a couple of fittings attached but still trying to figure out what I have, what I need and hose barb sizes.
Thanks much!
Thanks much!
My vitesse has a tube/stud water connector that has a 3/8 NPT thread. I could only find 2 connectors that were Female 3/8 NPT to AN, so went with -6AN as I already had a -6 AN 90 deg flare connector(and a -8 but couldn't find female 3/8 to -8AN) . The other was -10AN and so would have needed to order even more bits to get that working.
I went with 8mm barbs but not sure if they will fit factory hoses yet but figure if they dont, standard brass adaptors are easy to get and cheap, if I need to step hose size up to bigger size.
Anyway just waiting on the above peice and I am golden
#123
Thanks Bruce, looking good!
My car is in storage but I'm going to go over today and try and take some measurements of the turbo cooling hoses. I'm leaning towards -8 AN for my fittings, I'll post up a pic when I get it sorted out.
Cheers
Cheers
#124
From: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
I am pretty sure I used -6AN on mine, but -8AN should be just fine. I think the water passage for the turbo is smaller than 1/2" therefore the restriction should be in the turbo and not the hose. The turbo water pump is a bit of a joke honestly. Very low pressure.
