Refresh951's Hybrid Ultra Stroker Build
#1531
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
The power flex stuff is what he warned against in his thread though. I have polyurethane bushings on all of my turbo ricers and he is exactly right about the greasing and squeaking. Honestly, i noticed almost no difference going from the stock rubber to the poly other than the annoying squeaking. If you recall I swapped about 7 sets of brake pads to get rid of the squealing, Ha! . Even if his up graded rubber units are expensive I am willing to pay if performance improves with no annoying squeaks. Remember mine is a daily driver. Thanks for the Clark's post reading now.
#1532
So how does the car ride on the street as compared to before with the added size of the bars and coil-overs?
[/QUOTE]
Is that a before and after ? Oh no that's and 86 vs a later bushing but, man that is amazing how good that looks .... I did mine, but had to go to great lengths to seal the bearings, when I had them re-plated !
I always wondered if those bearings could be replaced?
Looks awesome
regards
Ed
#1533
Really like the combo. Seems like a good compromise for a street/DE car. I need a long trip to do a proper comparison but thus far I really like it. Does not feel harsh. With the old OEM spring rates, I felt quite a bit of front end lift when getting into the power and that is gone now. I never really realized how much this influenced the car until I changed it. The car is more stable under heavy load with this setup and I feel WAY more confident at high power levels . I should know how balanced the car is in a couple weeks after the next autocross event.
#1534
Really like the combo. Seems like a good compromise for a street/DE car. I need a long trip to do a proper comparison but thus far I really like it. Does not feel harsh. With the old OEM spring rates, I felt quite a bit of front end lift when getting into the power and that is gone now. I never really realized how much this influenced the car until I changed it. The car is more stable under heavy load with this setup and I feel WAY more confident at high power levels. I should know how balanced the car is in a couple weeks after the next autocross event.
When Tom would nail the gas in his car the rear would almost touch the ground but of course he also had a bit more power going on there
#1535
Yep, I did this to help out at the track and really discovered that is helps a great deal in managing my power. If you have a high HP build you should consider stiffening things up a bit. One downside may be less grip at the strip and that only really matters to one guy
#1536
#1537
http://www.elephantracing.com/projec...ngplatediy.htm
#1538
I had those Elephant Poly Bronze bushings and they were also pretty squeeky. Had to be greased pretty often. Didn't bother me but I think for a nice road car it could get a bit annoying.
Stiffening up the suspension will make the world of difference on the road and track.
#1539
Rainman
#1540
(don't get it on your clothes...)
http://www.skf.com/group/products/lu...nts/index.html
Cheers,
Mike
#1541
Had a great weekend. Took the 951 up to Road Atlanta and worked pit crew for my neighbor Jon Gearhart who races SCCA. He has several 951 race cars and this weekend he set the SCCA track record for his class in one of his 951's. About 30 cars in his class and his was the only 951.
Took a long drive (3 hrs) with my wife and still really like the suspension setup. I really think it is a great compromise setup for the street. My Wife took a nap in the car so that tells you it not overly harsh. I definitely have less traction under heavy acceleration as it is noticeably easier to break the tires loose in 2nd and 3rd due to significantly reduced squat.
#1542
Be interesting to hear Jon's impression of your car should he get the opportunity to drive it Shawn.
#1543
