Rogue Tuning: DME Logger!
Old 09-06-2013, 03:55 PM
  #91
blown 944
blown 944's Avatar
Originally Posted by gregeast
Time for cloning Rogue?
Great idea!!
Old 09-06-2013, 04:47 PM
  #92
bebbetufs
bebbetufs's Avatar
Rogue. I'm up for it but it will take a while. A buddy of mine already has some working OBD2 translation code which I could adapt. I'll contact you once I'm ready to pick up the programming.
Yes, there would be a delay, but I'm unsure how significant it will be. The best would be if Rogues DME logger would output OBD2 directly as that would open a vast range of possibilities, but there are many reasons for why Rogue may not want to do that. Lack of time possibly the biggest, but it would possibly require a hardware change? (As far as I know OBD2 is request based meaning a request is sent to the DME which then replies, while Rogues DME logger simply sends a continuous stream of serial data).
Old 09-06-2013, 05:42 PM
  #93
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by blown 944
Great idea!!
Yep - 3 please.
Originally Posted by fast924S
Here's a question if OBD-2 was to happen... Would the data rate not be real time, since the Motronic code gets translated into M-Tune code- then would have to go to another box and convert to OBD-2 code, Your refresh rate/data rate would suffer I'd think, even our $8,000 Toyota Techstream at work has a slow refresh rate
No matter what system, there is always a slight latency between the ECU and laptop. A decent converter box should (ideally) not add any noticeable latency (say only a few mS).
One of the problems with OBD2 is it generally uses newer communications hardware than what we have in the DME.
For example, one protocol uses PWM (pulse-width modulation); another uses VPW (variable pulse-width). The DME does not have the hardware to support this type of communication.
Yet another protocol is CAN, which again the DME does not have the hardware to support.
The remaining protocols are: ISO 9141-2, and ISO 14230. These are closer to what the DME has (hardware). However, the maximum standard data-rate is only 10.4k Baud... This is only 1/11th the rate of what my logger currently does. This means that the rate is really slow, and will reduce the update rate for all values coming from the DME. Currently the update rate is 15-20hz; conforming to 10.4k would reduce the update rate to only 1-2hz.
Furthermore, these two protocols also specify bi-directional communication, which is not possible without modifying the DME hardware (the production DME can only output data, not receive). It might be possibly that bi-directional communication is not needed, though I doubt it - regardless, I would have to really look into the protocol to find out.
Finally, hitting 10.4k Baud is also not possible with the stock DME hardware. Even if bi-directional communication is not needed, we would still have to update the DME hardware just to be able to hit that slow Baud rate.
Really, if OBD2 communication is desired, then the best thing would be a MitM box which has the newest/fastest communication hardware (CAN), and it reads the DME output data, stores it, and then sends it to the OBD2 logger when that data is requested from your OBD2 device.
Old 09-06-2013, 06:07 PM
  #94
bebbetufs
bebbetufs's Avatar
Thanks for taking the time to clarify. I will soon order the logger and start to look into this.
Old 09-07-2013, 01:02 AM
  #95
fejjj
fejjj's Avatar
Joshua, I someday hope to learn the foreign language that you speak.
Old 09-07-2013, 01:24 AM
  #96
333pg333
333pg333's Avatar
Ask Lart to help you with that. ;-)
Old 09-07-2013, 04:28 PM
  #97
jm964cab
jm964cab's Avatar
There was a movie made about cloning rogue except his 3rd didn't turn out so well.
Old 09-04-2014, 10:08 AM
  #98
hally
hally's Avatar
Default TunerPro load definition file problems
Anyone else getting a failure to load their M-Tune adx definition file?
I've had it working in the past, but have re-installed the 951 bundle via Joshua's website link on a new laptop. TunerPro v5.00. I get a message saying "Unrecognized encoding (parser does not support utf-8 encodings)".
cheers
Old 09-06-2014, 11:44 AM
  #99
hally
hally's Avatar
looks like an issue relating to the recently released latest version of TunerPro RT (5.00.8414).
I installed v5.00.8202.00 and the definition file load was OK.
Old 09-06-2014, 03:04 PM
  #100
Rogue_Ant
Rogue_Ant's Avatar
Glad you figured out the issue...
I've occasionally ran into that error - just haven't had time to pursue it.
Old 09-07-2014, 08:01 AM
  #101
hally
hally's Avatar
No worries, car has developed a rich condition, thought I'd fire up the logger to look for clues. Such a cool piece of kit!
Old 03-20-2016, 05:58 PM
  #102
Black51
Black51's Avatar
Just need some clarification here... Does pin 12 need to be cut, or do I just 'splice' in the blue wire to the wire going to pin 12?
Old 03-20-2016, 06:37 PM
  #103
refresh951
refresh951's Avatar
Old 03-20-2016, 08:05 PM
  #104
Black51
Black51's Avatar
I saw that diagram. I interpret it as I have to cut the wire, but just wanted to make sure. Thanks.
Old 03-20-2016, 08:41 PM
  #105
User 52121
User 52121's Avatar
You cut the wire for pin 12. Once cut, you'll have two "ends" - one end that heads off to the engine, and one that heads to the DME.
The engine end gets left hanging for dead, you don't do anything with it (it just goes back to a grounding point). Tape it off.
The DME end connects to the blue wire of the DME logger.
Quick Reply: Rogue Tuning: DME Logger!
