TonyG > New Race Car Build Thread
#1006
Rennlist Junkie Forever
Update...
The car is out of the engine shop and back at Vision for a further sorting and finishing of a few things that we didn't get time to do last time.
But what's real interesting is that the car was on the dyno today. And I was under the car while it was on the dyno inspecting for oil leaks or any problems visually while the car was under full load.
And I witnessed the most amazing thing...... The torque tube actually bows under load. I really couldn't believe my eyes when I actually watched the trans slightly rotate relative to the 997 suspension cross brace. WOW.
I told Dwain (owner of Vision Motorsports) about this and he confirmed what I thought I saw..... Yes... the torque tube actually flexes under load.
Amazing!
Umm.... that will be the last time I'm under a 944 making big power on a dyno at full load. EVER.
What was I thinking?
TonyG
Amazing!
TonyG
#1008
Interesting. Did it bow in a constant direction or rotate?
Wouldn't be standing under there at all!
#1009
The transaxle tail must have rotated, relative to the 997 cross member, at the about 1/2"-3/4"(visually observed... see avatar).
I took some cell phone video. It's not great, but you can still see it if you look closely. I'll have to edit it to cut everything else out and post it.
TonyG
#1010
Have you braced your gearbox to the chassis? Simple mod worth doing.
#1011
The brace you have is a lateral brace (left-to-right).
No I don't have one. And I don't need one because the trans is mounted rigidly to a custom mount which is part of the sub frame. It can't move left or right.
But what I see is the trans rotating, counter to the axle rotation. Not left to right movement.
This can only occur if either the engine is moving upward, or the torque tube is flexing.
TonyG
TonyG
#1012
So the trans is moving up and down (fore to aft)? Seems like it's floating out back but I'm just using your Avatar as reference. I'll go back and have a bit more of a look for a larger pic.
#1013
TonyG
#1014
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I am with Patrick's thinking on this. The problem being the output shafts are perpendicular to the torque tube/input shaft. The way you are describing the rotation would indicate a fore to aft rotation opposite of the output shafts rotation. At least that is how I am picturing it. Is the transaxle body/housing rotating opposite of the input shaft rotation direction? ie... Looking straight at the back of the transaxle CW or CCW?
#1015
No.
The transaxle is rotating in the opposite direction to the axles.
What makes this odd is that you would think that this would not be possible because the transaxle is connected rigidly to the engine via the steel torque tube.
But apparently the torque tube, under high torque conditions, actually flexes albiet a small amount... it's enough to observe with the eye.
TonyG
TonyG
#1016
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
No.
TonyG
TonyG
If you want to remove the stress on the torque tube shell you would need to stabilize the transaxle - the best way is two cross braces similar to Particks but further from the center line of the transaxle and going to opposite sides.
Here is a crude sketch up from Patrick's pic. (you don't need the original brace anymore - just the upper and lower - also if needed that can run to the same side of the car but it would be better to run them top opposite sides. The longer you can make the triangle mount the better it will work.
#1017
Rainman
Chris,
Ideally wouldn't the braces to counteract this phenomenon be mounted vertically?
From the tail of the trans up to Tony's cage X-brace perhaps? Then the torque bending the torque tube would be directed through the whole cage/car instead.
The OD of the torque tube should just allow for a 3.5ID steel tube to slip over it and weld into place, if you wanted to try to stiffen it.
#1018
1 Post
Looking at Chris's mock up picture, again I only see this helpful for CW or CCW rotation looking straight from the rear, which I thought Tony was originally describing. Apparently, this is not what Tony is experiencing, or I am totally lost. Can't wait for the video.
#1019
Sounds like the transaxle is rotating in the car's pitch plane, and if it's opposite direction of the wheel spin, then the rear of the transaxle is moving down, and the front is moving up, with the inner cv joints being the axis or rotation.
Interesting stuff, would be better to observe via a remote camera than by eye at 3 feet I think!
#1020
Tony, what gear did you observe this in when on the dyno? To me it seems like the torque at the transmission is equal and opposite the torque at the wheels. That would suggest that the torque tube will bend most in low gears. The suggestion to grab the back of the transmission and brace it to the chassis with a vertical strut makes a lot of sense to me. You could also weld some angle iron down the length of the bottom of the torque tube to try to get some stiffness out of it that way.
