zerMATT951's re-assembly thread
#47
Your parts look great. Good work.
Jason
Jason
Did a little more work last weekend, but not much. Installed the new LR fuel line fittings in the fender well, cleaned up the belt covers, and installed some timing/balance gears & rollers until I picked up the smooth steel roller and felt it's a little too loose for my taste, so I'm buying a new one. Funny thing is that ALL of the rollers were supposed to be replaced less than 5k miles ago when I sent it to the shop for a refresh... I guess that got overlooked just like the front cam seal.
I also picked up my powder coated parts... they look nice! I'm going to sand off the raised letters on the cam tower this weekend:
#48
Your PC'd stuff does look great! I hope your experience sanding the letters smooth goes better than mine has. On mine, the original casting was nothing resembling level and I had to take off a lot of material to get it close... It still doesn't look the way I want it to, but it's a lot better. Next time I have it off, I'll probably take it to a machine shop and have them shave the letters (like they would a head) and then have it PC'd. I hope your casting is better.
Anyway, looks great!
#49
I've also thought about removing the coating with a small die grinder or dremel with a soft abrasive wheel. I wonder which process will be more tedious?
I asked the powder coating guys about doing the machine work first, they said it would be cleaner to have it done after... so I got it PC'd, them took it to a machine shop friend and he tells me that the machining process might chip the PC. Geez!!
#50
I started with 60 grit sand paper on a block and worked it finer and finer. Then used Mothers to polish. Took an hour or two but was really happy with the results.
#51
On my Alfa, I used a bastard file, and then 80 grit, and then worked finer and finer until about 600. I wasn't going for a polished look, more of a brushed sort of look... 600 was where I stopped cause I thought it looked good. On the 951, so far, I've used the file.. need to pick up some more sandpaper.
#52
Once I remove the paint/powder, I plan to mask off most of the surrounding paint then shoot some clear over the area where I removed the paint to seal it. I'm thinking it will make for easier maintenance & appearance in the long-run. Has anyone done that before?
#53
If it was mine, I'd just be prepared to polish the letters quickly once a year or so. Masking the edges for clear wouldn't be all that pretty, and the clear wouldn't want to stay on bare aluminum all that well. JMO
#55
Only got a couple of garage hours in this weekend, so I buttoned a few things up with the PC'd brackets. I had to chase threads in all of the threaded holes because of the PC overspray... and they were covered up!
#56
Lookin' good, Matt. Just out of curiosity, can you remove/replace the brake booster heat shield with the turbo in place? I was just wondering that when I had my engine out, and I notice yours is removed but your turbo is there...
#57
Once I removed it, I could see how rusty the brake booster unit was, so I decided to paint it. I left everything in place, masked it all off, and sprayed it with eggshell black paint... the thing looks new again and it only took like 30 minutes!
#59
Very Nice. Aren't rattle cans awesome! Between a few rattle cans, some scotch-brite and a little elbow-grease, all sorts of 25 year old stuff can look brand-new!
#60
This took about 30 minutes with the help of a couple of old Porter Cable friends. Started with 50, 80, then 120 on the belt sander, then knocked it down a bit with 220 on the random orbit. I think it came out great, and I've only got one accidental tiny scuff on the far left where nobody but me will ever know it's even there.
