AFRs are lean at idle... surging idle and doesn't want to rev.. VIDEO ON PAGE 6!!
Old 03-07-2010, 07:04 PM
buddd
buddd's Avatar
Default AFRs are lean at idle... surging idle and doesn't want to rev.. VIDEO ON PAGE 6!!
So I installed my LR stg. 2 maf kit, turbonetics t61, new max951 tune, and 72lb injectors.. and since then the car has no spark.
'86 turbo.
gets fuel.
coils good and has 12v power.
no spark.
no tach bounce.
everything was working fine before i installed everything, i pulled the dme back apart and made sure everything was in order.
bypassed the klr and still no spark.
how can i test and check my reference and speed sensors and the wiring without an oscilloscope? maybe the dme is bad now somehow? i never touched the sensors so i dont know why they wouldnt work now.
FIXED WHAT IS ABOVE, bad DME was the culprit.
NEW PROBLEM BELOWWWWW!!!
yeah i was told resistors shouldnt matter.
OK so I got a new battery and heres the current situation..
AFRs stay right around 14.7 - 16.00 at idle. idles a bit high (about 1000 rpm on the dot)
if i give it any gas the AFR buries to 21.00, car doesnt want to rev and pops every once and awhile...
p.s- my boost gauge reads -15.5 while idling with a warm motor, and if i attempt to give it gas the highest i've seen it go was 0.00, usually is around -4.00 when trying to rev
p.p.s- my battery gauge reads low in my cluster, stays around 11v
VIDEO ON PAGE SIX!!!
Old 03-07-2010, 07:35 PM
Bri Bro
Bri Bro's Avatar
Maybe you bent a pin under or put it in backwards when you installed the EPROM. It is very easy to fold a pin under the body of the IC, it will look like it is OK but it will not make electrical contact. Sometime the socket is installed backward on the board, you need to go by the marking on the circuit board.
This is a picture from FRWilkes site. In the picture the socket and the circuit board show pin one correctly. This picture is showing how to add pins, ignore that part.
Old 03-07-2010, 07:41 PM
buddd
buddd's Avatar
Originally Posted by Brian Broderick
Maybe you bent a pin under or put it in backwards when you installed the EPROM. Sometime the socket is installed backward on the board, you need to go by the marking on the circuit board.
This is a picture from FRWilkes site, in this one the socket and the circuit board show pin one correctly. This picture is showing how to add pins, ignore that part.
nope, checked and the pins are all good. and the notches line up so its not backwards.
Old 03-07-2010, 07:45 PM
Bri Bro
Bri Bro's Avatar
Need to check the pulses from the sensors, got a scope?
https://rennlist.com/forums/944-turb...ighlight=scope
I am assuming you checked that they are plugged in and not reversed.
Old 03-07-2010, 07:55 PM
buddd
buddd's Avatar
how can i tell if theyre reversed? i dont think i reversed them but anythings possible, also i just noticed the sensor closer to the firewall (notsure which one of the two it is) has the bolt missing! its in the right position but theres no bolt.. what i dont get is the car ran fine before the new mods and i never toucehd those bolts so it must have ran without the bolt in? ... confused
Old 03-07-2010, 07:59 PM
buddd
buddd's Avatar
$50 to whoever gets this thing running!
Old 03-07-2010, 08:02 PM
Bri Bro
Bri Bro's Avatar
There are marking on the sensor wires on both ends, just match them up.
https://rennlist.com/forums/3708978-post5.html
Old 03-07-2010, 08:10 PM
Mark-87-951
Mark-87-951's Avatar
Did you try a DME relay bypass?
Old 03-07-2010, 08:17 PM
buddd
buddd's Avatar
which relay is this? i know i bypassed the fuel pump relay.
Old 03-07-2010, 08:23 PM
Techno Duck
Techno Duck's Avatar
DME and fuel pump relay are basically the same.
Do as Brian says and switch the connectors for the speed and reference sensors. There is no harm in trying and its a fairly common mistake to make.
Old 03-07-2010, 08:24 PM
xsboost90
xsboost90's Avatar
try putting the bolt back in the ref sensor- in case its too high to pick up a signal. Then if nothing, try swapping the ref sensor plugs cuz this is very common when putting a motor back together.
Old 03-07-2010, 08:25 PM
Fishey
Fishey's Avatar
Did you back probe the Speed/ref sensors? to make sure your getting an accurate signal from them? Also, The wiring for those sensors is known to go bad around the connectors. It has been known to break the wires inside form just moving them around. (Your car is now 24 years old)
Just a thought.
Old 03-07-2010, 08:26 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Bad chip.
Old 03-07-2010, 08:27 PM
buddd
buddd's Avatar
the ref sensor wiring is pretty crispy, it looks beat right off the plug on the harness side, can i open the plug and rewire further into the plug? doesnt look like id have a good enough length of 'good' wire to work with if i cut and tried to rewire em. the ref and speed sensors look fresh. i think they were replaced 15k ago when the motor was rebuilt.
Old 03-07-2010, 08:28 PM
buddd
buddd's Avatar
Originally Posted by Rogue_Ant
Bad chip.
fack. you think?
Quick Reply: AFRs are lean at idle... surging idle and doesn't want to rev.. VIDEO ON PAGE 6!!
