Project 2010...
#121
I used the dial indicator to find TDC and then used a feeler gauge on the block to measure.
It gave me a good enough number to know I'm safe
#122
if the piston rocks in the bore you mark the crank with the piston down 3mm each way then bisect the 2 marks .
I love these "nah all rong" comments sitting in my chair while my engine sits in bits .. lol
#127
Lot's of time consuming stuff at this stage. Modifications to they cable harness, fuel system, intake etc..
But it's getting closer!
#130
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Interesting angle on the turbo outlet….
When it come to a manly size contest at least I know that I can win a plenum size bragging contest with Duke!
#131
Hehe, it's larger than it looks on the picture. I have very short runners!
No need for more torque. It just breaks trans-related stuff and too much sudden torque spins the tires. I'm building a fast car
A plus is that the intake doesn't sit over the turbo anymore so I can shield it off effectively. That turbo outlet angle is the only way to do it since my intake runs so much forward. I run "reversed" IC-pipes though so it's pretty ok.
#132
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
#134
Engine is started. Full oil pressure, good vacuum and good throttle response.
Now it's only about 1001 things left to do before the first test drive..
