E-85 MEGA THREAD
Old 11-15-2008, 02:03 AM
  #106
Lorax
The Impaler
Lorax's Avatar
Originally Posted by blown 944
As far as storing
I had no problems storing in 250 gallon plastic totes. Never tried barrels but I wouldn't recommend it.
You can also get ahold of chemical processing companies. ie: safety clean and others. They have nice little 15 and 30 gallon plastic containers. Just buddy up to a driver and he will probably hook you up.
Printing companies utilize them regularly so maybe you can get info through them locally.
I have a few good plastic containers that we sotre emergency gas in, It's only been a few months so I don't think the fuel will be bad.
Old 11-15-2008, 02:31 AM
  #107
333pg333
333pg333's Avatar
Originally Posted by manu4jc
E85 station is 6 miles from my home... tempted to use it on my 951. any reasons not to? Harmful to the engine life etc? Also have we decided on the best E85 conversion parts list and procedure yet or is that still in the making?
This E85 is snowballing and people are starting to ask the same questions. (no disrespect intended). Search under user name 'blown 944', E85, or just read this thread. I think this should almost be made a sticky?
Old 05-11-2009, 10:41 AM
  #108
DLS
DLS's Avatar
I have converted to E85 and i must have blown the headgasket but there´s no sign of it on the gasket.
My head must have lifted just a little.
My plugs and valves are all white but maybe thats how it should look with E85?
Old 05-11-2009, 10:56 AM
  #109
blown 944
blown 944's Avatar
Yea it'll start cleaning the interior of the engine
It looks like that gasket may have been ready to go by the looks of the discoloration.
What boost were you running and what were the AFR's??
Old 05-11-2009, 10:58 AM
  #110
blown 944
blown 944's Avatar
The plugs do look a little lean
Old 05-11-2009, 11:21 AM
  #111
DLS
DLS's Avatar
1.2 bar and the afr at boost where around 12
Old 05-11-2009, 12:41 PM
  #112
blown 944
blown 944's Avatar
That's a little lean but not enough generally to push a HG. Like I said I think the HG was pretty bad anyway. Any pics of it??
Old 05-11-2009, 01:25 PM
  #113
DLS
DLS's Avatar
The gasket has only gone 2 seasons
Old 05-11-2009, 03:12 PM
  #114
blown 944
blown 944's Avatar
very interesting
must be a torque, decking, or lift situation
Old 05-21-2009, 02:36 PM
  #115
DLS
DLS's Avatar
I´m back with decked head and o-ringed block
I only wish i had a adjustable camgear to.
I wonder how much boost i dare to run now
dammit, i had to delete some of my older pictures to upload new
Old 05-21-2009, 03:04 PM
  #116
95ONE
95ONE's Avatar
What made you think you blew a headgasket?
A/F should be in mid 11's. But.. I'm sure it will hold for a while now. My gasket blew with the typical hot spot on number 4. Doing some cooing tricks to try and stop it. I'm convinced it's the cooling /lack of issue thats causing it.
Old 05-21-2009, 03:13 PM
  #117
DLS
DLS's Avatar
too much pressure in the cooling system and the cooling water smelled exhausts and there where black particles in the water, my new expansion tank are not so white anymore
Hm every one i spoked with told me that i should be around 12-12:5 for best performance with E85?
Old 05-21-2009, 03:17 PM
  #118
95ONE
95ONE's Avatar
Don't ask their advice on E-85 anymore. Harsh, I know.. But yes, it can be ran at that. but if you want your motor to last, just go to a safer A/R like 11.5-11.8 - or a .79-.8 Lambda.
And it does sound like a head gasket. probably a warped head though. Did you look for cracked sleeves?
Old 05-21-2009, 03:23 PM
  #119
DLS
DLS's Avatar
couldn´t find any cracked sleeves, but i could be wrong, let´s hope not.
i think it was the higher cylinder pressure together with a bad decked head last time and to little nm on the headbolts that did it.
Old 09-01-2009, 09:12 AM
  #120
etiennekuh
etiennekuh's Avatar
I have a quick quistion, and I can't find it in search.
For a school project I with a buddy are converting a 944 turbo engine to E85.
Using a DTA S60 PRO. The engine is totally stock. I know if I want to run on E85 it isn't a problem for the head and valves. But he and the project leader, are saying the valves and the valve seats and valve guides will not withstand the heat, and that the E85 will effect the metal. Does anyone have some hard facts to oppose these idea's.
Etienne
Quick Reply: E-85 MEGA THREAD
