Dyno results for Georges car-529WHP @ 23.4 psi
Old 07-18-2008, 04:50 PM
  #196
blown 944
blown 944's Avatar
Not to mention the extra heat generated by further compressing the air to get the same pressure as sea level.
there is a loss turbo and definately no turbo.
Old 07-18-2008, 08:14 PM
  #197
dand86951
dand86951's Avatar
Originally Posted by jmayzurk
Actually, cars with MAF sensors from the factory don't need pressure/altitude sensors, because the MAF compensates for this already. MAF sensors measure air mass, not volume.
The stock 951 has a flapper door measuring air volume, so it needs a barometric pressure sensor to compensate for changes in air density. So would a car with a MAP sensor.
I was under the impression that George is running a MAF sensor, which is why I'm confused at the existence of this problem. George, are you running MAF or MAP with TEC3?
OOPs, my typo, I meant AFM not MAF, I agree most of the early EFI systems used non mass air flow meters and thus needed altitude compensation.
Old 07-18-2008, 08:59 PM
  #198
nize
nize's Avatar
my MAP setup takes a temperature reading after the throttle body, so it's reading the temperature of the already-compressed air. no need to compensate in this case.
good point when applied to a MAF or AFM system, though, assuming they don't take a secondary 'correct' temperature reading after the TB.
Old 07-18-2008, 09:44 PM
  #199
TurboTim
TurboTim's Avatar
Map sensors cannot read temperature. IAT or MAT sensors read temperature. There is proably one of those in your MAP system.
Tim
Old 07-18-2008, 09:50 PM
  #200
nize
nize's Avatar
Tim
you are right tim. as i have mentioned, i have a temperature sensor after the TB in addition to a MAP sensor.
Old 07-19-2008, 01:04 AM
  #201
dand86951
dand86951's Avatar
Tim, in thinking about this, would it be possible to use an auxillary MAP sensor not connected to actual manifold pressure to feed a voltage to the TEC to use as a fuel correction factor?
Might be more trouble than it is worth but a thought.
Old 07-19-2008, 04:37 AM
  #202
nize
nize's Avatar
for that amount of trouble, why not go all map with a temperature sensor in the manifold?
Old 07-19-2008, 11:32 AM
  #203
dand86951
dand86951's Avatar
The temperature sensor in the manifold is already in the system and the ECU does correct for the effects on density caused by inlet air temperature and also by coolant temp. The ambient barometric pressure is to some extent accounted for by the MAP system but if you are up at altitude and correspondingly low pressure then the oxygen content in the air will not be the same so a correction table could be possible. I don't know that it is needed for sure, so I was just thinking that since the fuel curve is modified by coolant temp and air temp in the ECU and if altitude is a factor then why not use a second MAP sensor and modify the fuel and/or ignition curve based on altitude.
Old 07-19-2008, 12:29 PM
  #204
George D
George D's Avatar
MAP.
Old 07-19-2008, 01:51 PM
  #205
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
A car with a MAP sensor (Speed Density) does not need a second MAP sensor for barometric pressure. Rather a Speed Density system utilizes absolute pressure, so 'altitude' is part of the equation to begin with.
-Rogue
Old 07-19-2008, 04:49 PM
  #206
dand86951
dand86951's Avatar
Rogue, I agree that the MAP sensor automatically takes into account the altitude as it is based on Absolute Pressure, however as George's car seems to illustrate even though it may be operating in a cell with a given Absolute pressure say 180 Kpa, when the car is at 8500ft altitude then that 180 Kpa of pressure doesn't have as much oxygen in it as the same 180kpa which occurred at sea level??
I haven't had mine up to a high enough altitude to verify nor have I been able to dig out any hard facts but it does seem to me there may be some effects which could modified by having a correction table based on ambient absolute pressure. On the other hand maybe the physics says it should all be taken into account by the absolute pressure.
I do know that in my airplane it will only make 100% rated power up to a given altitude. Above that the Turbo doesn't have enough flow to make up for the lower density so it will only make x % of max rated power which decreases as I climb even higher.
Old 07-20-2008, 12:52 AM
  #207
Rogue_Ant
Rogue_Ant's Avatar
Assuming the same temperature and humidity, then absolute 180kpa is 180kpa regardless of altitude, the density is the same. Where most people get confused is the lower atmospheric pressure at altitude, and think that gauge pressure is the same as absolute.
-Rogue
Old 07-20-2008, 11:05 PM
  #208
95ONE
95ONE's Avatar
Soooooooo.................... 1/4 mile numbers yet?
Old 07-20-2008, 11:20 PM
  #209
David Floyd
David Floyd's Avatar
Or timed 100 to 200 kph sprint, several have posted in the past to compare to.
Old 07-27-2008, 05:28 PM
  #210
95ONE
95ONE's Avatar
This post was pushed back 4 pages already.
George, have you made it to the track yet?
Even if you don't do a bad *** run, it should still be fast. please post so we can get our cars rep up.
Quick Reply: Dyno results for Georges car-529WHP @ 23.4 psi
