BAM!.....602 RWHP 951
Old 11-22-2007, 10:47 AM
  #91
dougoh
dougoh's Avatar
that is amazing to see the power you have gotten out of that little 2.5....congrats..
Old 11-22-2007, 10:52 AM
  #92
DVC
DVC's Avatar
Great pull, Jim.
It's not a four-banger.....it's a bangin' four.
Old 11-22-2007, 11:57 AM
  #93
BC
BC's Avatar
Originally Posted by special tool
Pistons are 8:1, but my static is slightly higher from decking on block and head.
My egt's are always cool because I keep the timing as early as possible so it is cooler by the time the ex valve opens.
I did run the latest timing I have EVER run on the 944 today, however because I believe the powemist burns as fast or faster than the tolene blend.
It is still my contention that the MLS steel gasket gives lateral support to the alusil sleeves when torqued.
My head flows 243 cfm @28in/hg@.5" on the intake.
My exhaust flow is very, very good now for a turbo head.
I would put my exhaust flow against any turbo head in the world that retains the ceramic.
Thanks for the info. That comment on the cometics are nice to hear.
Old 11-22-2007, 12:21 PM
  #94
tommye
tommye's Avatar
Originally Posted by lart951
Hold on, are you saying your car is as fast as TinyG's v8 with 745rwhp?
Looks like you're got your next goal set-up for you there already.......750rwhp !
Tommy
Old 11-22-2007, 12:46 PM
  #95
reno808
reno808's Avatar
Here is Jim's 602whp Dyno Run
Old 11-22-2007, 01:05 PM
  #96
evil 944t
evil 944t's Avatar
Good job Carlos, Thanks for taping everyones runs! It was nice to meet all you guys and put faces to screen names. Its a shame more people didn't come up as it was a good time. Perhaps ST can host some more of these.(if his wife lets him)
Old 11-22-2007, 01:13 PM
  #97
reno808
reno808's Avatar
haha yeah dave no problem. Nice meeting you too. keep me updated
Old 11-22-2007, 02:52 PM
  #98
nitehawk951
nitehawk951's Avatar
Congratulations special tool. That's a one of a kind 951 now. Nice job man.
Old 11-22-2007, 09:30 PM
  #99
evil 944t
evil 944t's Avatar
Originally Posted by reno808
keep me updated
lol, will do!
Old 11-22-2007, 10:59 PM
  #100
yellowline
Under the Radar
yellowline's Avatar
Coming from the other thread, if you have another get-together (from the sound of it), I would come up if I'm free and invited. I'm never in the 951 corner, maybe I'll have to look more often.
Old 11-23-2007, 12:10 AM
  #101
V2Rocket
Rainman
V2Rocket's Avatar
jesus.
Old 11-23-2007, 01:21 AM
  #102
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
Originally Posted by 944CS
Why have you not raised the compression even higher for more area under the curve? You won't have to run as much boost, and thus you'll have a greater temperature differential when the air enters the plenum, which will give you the power you want and also help suppress detonation.
Raise the CR to help suppress Detonation, LOL
Congrats Tool, now go get yourself a proper Boost controller
Old 11-23-2007, 03:13 AM
  #103
reactor2
reactor2's Avatar
That is a horrendous powerband for a "street car". If you didn't "market" this engine as a street engine I wouldn't be so harsh, but a street engine should not start making power at 5000rpm. A bolt on Turbo S has a better curve from 0 to 5000 rpm. Thats huge considering this setup only offers superiority for 2200 rpms. In fact, at 4000, most are over 300 ft lbs to the wheels, 100 ft. lbs higher than your current powerplant configuration. Why have you not raised the compression even higher for more area under the curve? You won't have to run as much boost, and thus you'll have a greater temperature differential when the air enters the plenum, which will give you the power you want and also help suppress detonation.
It's really not the final compression ratio that gives a turbo motor it's huge advantage over a NA motor. Raising the static compression (and keeping the same final compression ratio) will actually make less power.
Old 11-23-2007, 05:24 AM
  #104
tommo951
tommo951's Avatar
Excellent work Jim, its a good job there are people out there who still shoot for the stars!
Very inspiring!
Old 11-23-2007, 05:34 AM
  #105
333pg333
333pg333's Avatar
tommo, just out of curiosity have you ever had yours dyno'd? I'm wondering what you came up with having similar mod's to mine. PM me if you'd rather.
Patrick
Quick Reply: BAM!.....602 RWHP 951
