BAM!.....602 RWHP 951
Finally!
602 HP at the wheels.
I have blown many engines to see this result, and I am pretty happy right now.
I don't mind telling you it has been a TREMENDOUS amount of work, and Now I shall force you to endure a complete rundown, because, frankly - all the people responsible for it, deserve it.
Following is today's engine spec:
CEP 2.5 alusil block with CEP/SKI(Brett) Mahle "slipperskirt" pistons/rings
4 stage C.E.P. dry sump, remote Wix, 3 gallon Peterson tank, stock oil pressure and oil temp guage
Porsche crank/rods - worked by Joe@DCE
Vitesse big valve/ported 8 valve head-further modified valves by Joe@DCE
Vitesse MAF/Motronic semi-sequential injection
Vitesse SMT6 fuel/timing controller with modified timing
Vitesse wasted spark ignition
NGK BPR8ES .025
SFR stage 2 / 4-1 headers/x-over v-band to full T4 turbocharger end
SFR short runner/large plenum intake manifold
SFR 3" T4 V-band downpipe
SFR/Special Tool 75mm Motronic-compatible throttle body
Special Tool 1000 ci. intercooler
Special Tool 2.75/3.00" ic pipes (reverse flow) Forge adjustable racing bypass
Large full T4 turbo
Lindsey 3" exhaust wth Borla 40944
Lindsey complete fuel rail@ 3 bar static
Cometic 3 layer stainless gasket
Milledge 503/475
Adjustable cam gear 1 degree advance today
2 Bosch 044 fuel pump (in series currently)
Siemens 72
Tial 38mm
Lindsey black **** controller
4 channel egt
Zeitronix datalogger - wideband/boost/rpm/maf/tps/knock(soon)
Large Setrab oil cooler
And of course - all of the COUNTLESS experimental parts that Lart has sent me for a pittance just to help me. Thanks Luis.
It is obvious to see that this was done at relatively low boost (28-28)because of the torque number. I have the head/cam/intake/exhaust flowing VERY well now so I started at 18 psi today and hit 440 RWHP after some timing work.
Also, I lifted a little early on this last run (obviously),but I had pushed my luck enough today and this new engine is very sweet.
Thanks all you guys for coming out today too - it was a blast!
NGK BPR8ES .025
Large full T4 turbo
Milledge 503/475
Siemens 72
Tial 38mm
4 channel egt
Basic Sponsor
Damn, you are the master indeed, I pledge my life to your teachings. Well after today you are the guy who took the 951 engine where no one has been before, you took off where TinyG left, after he couldn't go anymore because of his intelectual limitations, therefore from now on you should be known as Master tool and tinyG, well the california bum white dude wannabe
CONGRATS!!!!!!!!!! Thats really cool to see!
A couple questions. Why is there a power plateau just above 500hp (is it a function of the intake geometry)? And, why did you choose to piece together the electronics instead of going stand-alone (seems like it would be much harder to tune)?
Congrats on the big power Jim, shame i missed it but i happily just caught the start of traffic on the Hutchinson River Pkwy...made it home just in time!
