Project pictures...
Old 12-31-2007, 12:22 AM
  #91
Keithr726
Keithr726's Avatar
Nice work! Great looking car. I'm a little dumbfounded wheres the AFM/MAF? What throttle body is that?
Old 12-31-2007, 07:07 AM
  #92
Olli Snellman
Olli Snellman's Avatar
Pete uses VEMS ems which has MAP sensor. Throttlebody is a BMW unit, which is attched to my old intake with new plate Pete made himself.
Old 01-01-2008, 05:17 AM
  #93
pete95zhn
Former Vendor
pete95zhn's Avatar
Originally Posted by 333pg333
I wish you the best of luck with this Pete. Very nice looking car. I'd be interested in what clearances you are running between piston and sleeves? What ems are you using?
Thnks, I'll need it... I right now actually not in the near vicinity of my car or garage, and I can't recollect the clearings, but I'll post them when I'm back home.
It's VEMS. You will get larger write-up about it when all bugs are killed.
Old 01-20-2008, 10:48 AM
  #94
pete95zhn
Former Vendor
pete95zhn's Avatar
Piston to sleeve clearance is 0.0055 inch = 0.1397 millimeter.
I have finally killed the last big bug. I bought an oscilloscope and immediatelly noticed that reference sensor's polarity was incorrect. Now engine revs beautifully, and I've adjusted afterstart, warm-up, and acceleration enrichments and idle settings. it's winter -sort of- here, so tuning starts at April.
Old 01-20-2008, 12:11 PM
  #95
Duke
Duke's Avatar
Great news Pete!
I'm hoping to see the car in person (once again) at some point the coming season.
Old 01-20-2008, 04:12 PM
  #96
333pg333
333pg333's Avatar
Good news Pete. Best of luck with it all. What ems are you using now?
Old 01-20-2008, 04:38 PM
  #97
Olli Snellman
Pete uses VEMS
Old 01-20-2008, 04:57 PM
  #98
DanG
DanG's Avatar
Pete, Chris recommended against using an MLS in combination with the MID sleeves and ARP studs to me. Did you guys discuss the tradeoffs?
Old 01-20-2008, 08:07 PM
  #99
333pg333
333pg333's Avatar
^^^HuH?? Why not? That's not the info we recieved...
Old 01-21-2008, 01:39 AM
  #100
pete95zhn
Former Vendor
pete95zhn's Avatar
I actually am using a WideFire HG, the MLS didn't keep cylinder pressure out of the cooling system. I'm going to find out how much boost WFHG can handle.
Old 01-21-2008, 04:00 AM
  #101
333pg333
333pg333's Avatar
Nice to know now...
Old 01-21-2008, 05:17 AM
  #102
DanG
DanG's Avatar
Chris described it to me as you want some compliance in your block/stud/head/gasket sandwich. A regular fibrous gasket is best with the MID and ARP studs, a MLS in that application may have sealing problems as Pete mentioned. I think the MLS works better with stock blocks/studs as those function as the "squish" in that sandwich.
I'll actually have to splice two gaskets together to make mine, as I have a 2.5L based block (water passage), but need the 3.0L based gasket for the 104mm bores.
Old 01-21-2008, 05:54 AM
  #103
pete95zhn
Former Vendor
pete95zhn's Avatar
Just buy a 104mm 3.0l WFHG and cut out the water passage area. Then go and buy a suitable general purpose gasket sheet, thickness selected so that you can make a sandwich of same thickness with WFHG. "Glue" the sandwich together with a GOOD gasket glue/goo/whateverit'scalled , like Hylomar on this side of the pond, press and let it settle to check again the thickness. Then cut it to required shape and install with WFHG. Just for extra sealing you can use again that Hylomar around the water passage, but only there...
Old 01-21-2008, 06:19 AM
  #104
333pg333
333pg333's Avatar
Well this is interesting in more than one way...
How many miles/kms do both you guys have on your motors?
Old 01-21-2008, 11:34 AM
  #105
pete95zhn
Former Vendor
pete95zhn's Avatar
About 2 hours and 400 meters. Yes, meters. More in April.
Quick Reply: Project pictures...
