dyno @ 21 psi
#76
Drive-by provocation guy
Originally Posted by RKD in OKC
1st off Nice sheet.
I have the Super 61, Dual port wastegate, MBC, Authority MAF, Mafterburner, 48# injectors, LR chips, 4 inch exhaust, Stage 2 intercooler, and Stage 2 head. Headers and crossover are stock. My dyno runs at 16, 18, and 20 produced 350, 375, and 400 rwhp respectively.
I think you should be able to get more power with chips tuned for your MAF and shouldn't have to replace the MAF. When LR was tuning my car they hit a 350 hp wall and were able to tune it out with my now outdated chips and MAF using the MAFterBurner, Adjustable FPR, and sizing injectors to work at closer to stock fuel pressures at the higher output levels.
So I would estimate that the 4", Stg2 IC and head together probably give you about 20% more hp than without those options?
#77
Basic Sponsor
Can you guys(dorklex and Durky) stop the OT on my thread, report sent. Hey where do I send the report to???
#78
#79
#80
Originally Posted by pk951
My Swiss made 418rwhp at 18 or so psi with k27 chips not to bad, I can't find the dyno chart.
Larts set up is very close to what My Swiss had expect for turbo his was a full garrett and MGE head.
ok, so 10% for the full Garrett and the head????
Puts the numbers to about 378whp without. Still a big number for K27 and only 18psi. I would love to see the chart if you can find it.
#81
#82
Basic Sponsor
#83
I dynoed my car at the exact dyno shop where mr G reached his 393rwhp. The word out there is that he was running higher boost than what he claimed, since there is not video or boost log of the run we have to depend on the persons claim it has the same validity as me stating that he lied in his boost level, is my word against his. At least I had the courage to video my boost level, but do not loose heart I will be back with more videos and more hp at the same boost level, you can count on that larts never gives out, no retreat no surrender (too much movies,lol)
But your results should be deemed very comendable in that you are sitting at OVER 400hp at the crank with chips that are way off. And it is not timing being pulled out since your a/f is very rich AND you run 20% Xylene.
And ST, and many others, will tell you that a dead on tune/chips in many cases will easily net another 5-10% at the wheels. So you get some new chips and at the same 21psi could be in the 360-370whp range.
So well done Lart!!!
#84
To bad MY Swiss does not post here he has the dyno chart at 18 psi he got well over 375Rwhp.
Sorry guys at 18 psi 415wrhp not bad for an old turbo.
The dyno chart is some were if i find it i will post it.
#85
#86
#87
Lart: Sorry for the OT pal.
RKD:
2.8L? 2.8L 2.8L? Start a thread. You keep letting the cat out of the bag, every once in a while, so let's here about it already. Spill the beans?! What is the deal with this 2.8L already and all the mods?
RKD:
#88
I had the 4" and Stage 2 IC and head when we were hitting the 350 rwhp wall. Also swapped from a really nice K27/8 to a Super61, but until the chips/injectors/fuelPressure/MAF were tweaked to work with each other it wouldn't make over 350 rwhp no matter how much boost was cranked in.
So from about 350whp to 418whp with same boost, 18psi, only making adjustments to " chips/injectors/fuelPressure/MAF" ??
Can you share more details about what those adjustments were?
#89
Go back a few pages it was not a k27 the chips were k27
To bad MY Swiss does not post here he has the dyno chart at 18 psi he got well over 375Rwhp. Sorry guys at 18 psi 415wrhp not bad for an old turbo.
My Swiss Thread
#90
It main idea here is that the chips think they are seeing stock air measurement and controlling stock injectors at stock fuel pressure. Running higher boost increases the flow into the engine and increases fuel requirements. The MAF output is massaged so it sends the same voltage range to the chips as the stock AFM even though it is measureing a higher peak flow rate. The larger injectors and adjustable FPR are used to get the correct AFR from the stock injector pulses.
