Rennlist Top 10 HP/TQ
Old 10-06-2005, 09:40 PM
  #526
Skunk Workz
Skunk Workz's Avatar
Originally Posted by Duke
Do you know how much the dyno calculated your driveline loss? It should generate both a rwhp number and a calculated flyhweel number.
Usual driveline loss for a 420hp 951 is about 40-42 hp.... 380whp or so,then.
Old 10-07-2005, 09:23 AM
  #527
Markus951
Markus951's Avatar
Markus, it is interesting to see your EGT since too retarted ignition can make the EGT dangerously high. Not saying it is the case with your engine, just interesting for us engine nerds
there are three thing that cause egt to climb up:
lean mixture
late ignition timing
early cam timing
from these two latter ones are practically harmless to engine
first one on the contrary is fatal to the engine
only thing that might be in danger due to late ignition-caused egt buildup is the echaust valves, and if they are good material (this case sodium filled), it makes no harm to get over 1000 celsius.
But of course that is something all of you know, just wanted to point that out here.
Markus
Old 10-07-2005, 11:15 AM
  #528
fast951
fast951's Avatar
Have you examined the factory exhaust valves? Do you think it's made out of the same materials across? Perhaps Skunk have examined the materials the stock valve is made out of?
If you are running high EGTs for whatever reason, make sure the spark plugs can take it!
John
Email
www.vitesseracing.com
Old 10-07-2005, 03:02 PM
  #529
Skunk Workz
I haven't done that yet John... Or,to address that rightly,I haven't gotten the answer for that yet...I sent one away for testing. Are you a psychic..?
Old 10-07-2005, 03:07 PM
  #530
fast951
fast951's Avatar
It'll be inetresting to compare the results...
Old 10-07-2005, 03:35 PM
  #531
Skunk Workz
You did the same..?
Old 10-07-2005, 05:34 PM
  #532
fast951
fast951's Avatar
Old 10-08-2005, 12:29 AM
  #533
shaheed
shaheed's Avatar
thanks for the congrats...i have my work cut out for me now with two money pits.....john can i come live in your garage?
Old 10-08-2005, 01:30 AM
  #534
NZ951
NZ951's Avatar
I have added you to the list Shaheed
Beware... I am on your tail!
Old 10-08-2005, 01:49 AM
  #535
shaheed
shaheed's Avatar
machtig you realize ted did his dyno runs with the old stage II, without the full 3" exhaust and with a slipping clutch, right?
Old 10-08-2005, 01:52 AM
  #536
NZ951
NZ951's Avatar
I also heard the sun was in his eyes too...
Old 10-08-2005, 01:55 AM
  #537
shaheed
shaheed's Avatar
nah that was just special tool unbuttoning his shirt.
Old 10-08-2005, 02:08 AM
  #538
NZ951
NZ951's Avatar
Pass me the barf bag Shaheed, I'm going to lose my lunch...
Old 10-08-2005, 08:08 AM
  #539
special tool
special tool's Avatar
Yes, the old stage 2 and you should see the exhasut that was on that car for the run. Some muffler shop welded in a TWO INCH section in place of the cat.
Worst I've seen.
The dyno guy goes,...."UUUUUH, Jim, you might want to take a look at his exhaust"
Old 10-09-2005, 02:40 AM
  #540
TRWright
TRWright's Avatar
Worst I've seen.
Jim, take a picture of that exhaust and post it up. No one on this site will believe those numbers were made with that thing.
Shaheed, with John so close to you, I have a sneaking suspicion that the car is going to slide up a few spots. . .
Quick Reply: Rennlist Top 10 HP/TQ
