Porsche 944 Turbo restomod
Old 09-15-2021, 09:37 PM
  #361
SeaCay
Thefu
SeaCay's Avatar
It's like buying something from Honda, usually all the fasteners are included. Very nice.
Old 09-16-2021, 05:25 AM
  #362
333pg333
333pg333's Avatar
Wow!! It still amazes me that these blocks are available brand new from factory.
bobinnova (10-01-2021)
Old 09-16-2021, 08:53 AM
  #363
Gage
Gage's Avatar
I wish Porsche would sell the fastener package alone.
Old 09-16-2021, 02:33 PM
  #364
Zirconocene
Zirconocene's Avatar
Just ran across this thread and read the whole thing. Amazing.
With respect to wheels and a desire for phone dials, have you looked at the Augment versions? They have a number of styles available and are willing to make some custom sets for customers. They're on my win-the-lottery list of things to do.
Cheers
Old 09-19-2021, 07:58 PM
  #365
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
Delaware Porsche corrected their web catalog and they tell me there is one of these blocks available in the US. Price is about $2600.
Old 09-19-2021, 08:32 PM
  #366
Millermatic
Millermatic's Avatar
I've bought all of my fasteners from Belmetric. They have every fastener I've needed so far. Quick shipping and good prices. And they have "yellow."
Now if I could just figure out the right sizes for all of the interior fasteners I need...
The following 2 users liked this post by Millermatic:
bobinnova (10-01-2021), DasSilberWedge (10-31-2021)
Old 09-19-2021, 08:36 PM
  #367
Millermatic
Beautiful block. I've got a spare engine that came with my car... One of these days I plan to rebuild it. I have no idea how much machining it might need and wonder... how much would I _really_ save over just buying a new block?
Old 09-19-2021, 10:19 PM
  #368
Gage
Gage's Avatar
Yes, I receive a shipment from Belmetric weekly and they are great but they do not have the all correct fasteners for the balance shaft housings, cam housing, main girdle, head or intake manifold.
Old 09-21-2021, 05:40 PM
  #369
Doyle623
Doyle623's Avatar
Apparently, someone already snatched it up...
Old 09-21-2021, 08:24 PM
  #370
Mike Goebel
Mike Goebel's Avatar
They do not have the all correct fasteners for the balance shaft housings, cam housing, main girdle, head or intake manifold.
I've actually contacted them before and requested different lengths and they've added it to their stock. Once I mentioned that it was a standard P-Car bolt and they said not a problem. Even if the bolts come in black oxide they will strip and yellow zinc them.
Mike G.
Rob 3 (09-30-2021)
Old 09-21-2021, 08:54 PM
  #371
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
The bare 2.5 block, 944-100-960-00 shows up on the Sunset website so it seems Delaware's catalog still has issues and reverted to the incorrect listing. I've had this issue with them in the past, which is weird because they use the same web hosting service as Sunset, just different pricing.
Old 09-26-2021, 03:46 AM
  #372
Frank@Work
Frank@Work's Avatar
Had the 3.0 crankshaft checked: zero wear.
next step: order rods (Carrillo) and pistons with a 4.5mm higher piston pin.
I read that my choices for pistons are limited, because of the alusil bores.
Normally there is no contact between the piston and the bore, so why would it matter?
Isn’t it the piston rings that should be compatible with the alusil bore?
Old 09-26-2021, 09:30 AM
  #373
Gage
Gage's Avatar
There is contact (normally) of piston to bore in the skirt area of the piston. The silicon particles exposed on the surface of the Alusil are not only very hard but also abrasive. Any material in contact with that surface (piston skirts and rings) must be able to endure a sliding interface without sacrifice.
Old 09-26-2021, 12:26 PM
  #374
Frank@Work
Frank@Work's Avatar
Thanks for clearing that up.[
QUOTE=Gage;17689238]There is contact (normally) of piston to bore in the skirt area of the piston. The silicon particles exposed on the surface of the Alusil are not only very hard but also abrasive. Any material in contact with that surface (piston skirts and rings) must be able to endure a sliding interface without sacrifice.[/QUOTE]
Old 09-29-2021, 05:17 AM
  #375
Frank@Work
Frank@Work's Avatar
Scored a brand new crossover pipe
For the engine build I will be more thorough in getting "it" better than the current engine. (the current engine was "a quicky" to get the car on the road again).
My AugTronic ECU uses a MAP sensor. Currently the MAP sensor is connected to a banjo bolt connection on the intake manifold. I believe it shares a connection with the fuel damper. I would like to use a dedicated line for the MAP sensor. I have an intake manifold lying around with two banjo bolt connections (in stead of the one connection on the older type intakes). That's already better, but I was wondering if it would be even better to place the MAP sensor directly in the intake manifold. Would heat become an issue? The back of the intake manifold (near the oil filler pipe) seems a pretty good location. It is however near the turbo and the downpipe.
Any thoughts on this?
Thank you
Quick Reply: Porsche 944 Turbo restomod
