Porsche 944 Turbo restomod
#167
Beautiful car and i'm looking forward to your engine build.
A lot of people install a steam vent kit on our cars as well. https://www.lindseyracing.com/LR/Parts/COOLSTEAM.html
#169
951 oil check valve vs. 944 oil check valve
#172
Ah, I don’t need to take the bumper off. The clamps are for the water hose for the headlight washer system. Which I don’t have! :-)
https://cdn4.pelicanparts.com/techar...mall/pic07.jpg
Ignore the arrows in the oicture. The clamps are at the top of the bumper.
#178
The (stock) engine build is coming along. I will try to post some pictures this weekend so y'all can point me out where I'm f'ing things up.
I have wired in the Zeitronix ZT-2 and will be ordering a LCD display it. I was wondering if someone has managed to replace the stock O2 sensor signal with the narrow band outout signal from the Zeitronix. Will this work? Can I just replace the stock O2 sensor with a screw plug and leave the O2 connector in the harness disconnected?
#179
#180
I don't like to be dictated on the way I should be wiring my injectors. The LR billet fuel rail bracket only allows me to connect the injecor wiring from the side where also the sparkplug wires are routed.
A small modification of the bracket did the trick.
The stock NA head is on!
New waterpump.
The headers have not been coated. Only painted to see if I like the looks. For the final (3.0) build I will have the (aftermarket) exhaust system coated with Zircotec.
I love (cheap) tools!
New waterpump.
mj951 (10-04-2019)
