Red Car FIRE
#121
#122
Nothing locates the injector in the manifold bore except the clip.
Without the clip, or with it not properly fastened, the fuel pressue will push the injector out of the rail.
#124
Yes it was me.
The the injector doesn't "bottom out" in the intake the hole where it is inserted is the the same size all the way through. Even with the rail bolted down, the injector can wiggle down enough to allow the top seal to come out. Having the clips in properly is absolutely critical, and I found out the hard way. My clip was upside down.
The only way to work on the injectors is remove the rail as a whole, and clip/unclip them all on the bench and reinstall all four together.
Here's a pic of mine.
#126
All of the skinny, lightweight Bosch injectors I tried (when the older style became difficult to obtain) had the groove for the clip in the improper location, allowing the injector to pop out of the rail.
I machined a correct groove in several sets of these injectors, before locating a source for the "proper" injector design.
Might be worth looking at....
#128
The car is covered up and sitting in front of my house...The sunroof is open which I can manually close
but the drivers window is open, I concerned about hooking up the battery to get the window closed
Any suggestions?
Any suggestions?
#129
It turns out that the insurance adjuster that looked at the car and the underwriter have a different value system. So far they have offered 11k. The battle begins
I am thinking more and more and my family supports this as well as to keep it and fix it. I know it doesn't like me but maybe this exorcism helped. Success is going from failure to failure with enthusiasm.
The best oprion is to not allow the car to be "totalled" at all, but make the insurance company fix the car.
The offer of 11K is absurd. Keep in mind that an 86.5 just sold for 52K and that car wasn't ant nicer than this one (I worked extensively on both)...and didn't have 20K+ in "restoration" invoices.
The adjuster's job is to offer as low an amount as he possibly can....to reduce the company's loss!
Go back and tell him to find you a 86.5 in your condition for 11K and buy it for you to replace this one.
The story will quickly change!
#130
Also might help is several of you with 1985-86 cars put them up for sale on craigslist asking BIG money....costs you nothing BUT a bit of time just do not put in a phone # unless you really wish to sell
#131
Drop the console side and power the window motor up at the switch is likely easiest. Or hook the battery up but disconnect the engine Harness from the ce and pull the fuel relay.
#132
Just need some good photos, any one of us can post up one for sale.
