928 Forum 1978-1995
Sponsored by: 928 Specialists
Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
Old 04-13-2016, 04:21 AM
  #646
Strosek Ultra
Strosek Ultra's Avatar
Check out the tuned length of the intake ducts.
Åke
Old 04-13-2016, 09:01 AM
  #647
Strosek Ultra
Here the internal design of a good crossed intake manifold.
Åke
Old 04-13-2016, 09:49 AM
  #648
V2Rocket
Rainman
V2Rocket's Avatar
Wonder how long those runners are?
Old 04-13-2016, 10:52 AM
  #649
Strosek Ultra
Tuned intake manifold
First introduced by Mercedes 300SL in 1954, tuned intake manifold is not exactly a new technology. It is discussed here just because its principle is useful to our further study of variable intake manifold.
Before 1950s, engineers believed short intake manifolds were the best to engine breathing. Then they discovered that under some conditions long intake manifolds could actually improve output, thanks to a so-called "supercharging effect". How is that done ? Let's see the following illustration:
When fresh air is sucked into combustion chamber, it gathers speed and momentum in the intake manifold. As soon as the inlet valve is closed, the fast-moving air hits the valve and compresses, generating high pressure. With no where to go, this high pressure bounces back, travels along the intake manifold, hits the plenum at the other side and bounces back again. In this way, the high pressure bounces back and forth along the intake manifold until the inlet valve opens again, creating pressure waves.
Now the interesting thing is: if the inlet valve opens again exactly when the pressure wave comes back, the pressure wave will help charging the combustion chamber due to its high pressure. This is not unlike charging the combustion chamber with a light supercharger, thus we call this supercharging effect.
In order to match the timing of valve opening, the frequency of pressure wave shall synchronize with engine rev, obviously. This frequency is dependent on the length of the intake manifold (L in the figure). The longer the length, the longer the time pressure wave takes to bounce back thus the lower frequency of pressure wave is attained. As a result, a longer intake manifold leads to supercharging effect at lower engine rev. A shorter manifold leads to supercharging effect at higher rev. By selecting a suitable manifold length, we can obtain the desired power characteristic.
Calculations found in order to achieve useful supercharging effect, the intake manifold shall be unusually long. If it is too short, the pressure wave will bounce back and forth too many times in the manifold before the valve opens again, by then the high pressure is largely diminished. Therefore a tuned intake manifold shall be long.
Unfortunately, tuned intake manifold works only across a narrow rev band. If the engine revs beyond that band, the pressure wave will arrive too late in the intake stroke, contributing little to charging. If the engine runs below that rev band, the pressure wave will arrive the inlet valve before it opens. In both cases, the low pressure area of pressure wave may even work against cylinder charging, hampering torque output.
A sports car engine may employ a shorter tuned intake manifold to optimize its output at high rev (in the expense of low to medium rev output). On the contrary, a heavy sedan or commercial van engine may choose a longer manifold to favour low-rpm output at the price of high-rev output. As you can see, the selection of manifold length is always a compromise. That's why many modern engines turn to variable intake manifold...
Old 04-13-2016, 10:53 AM
  #650
69gaugeman
69gaugeman's Avatar
Originally Posted by Mongo
LOL, the Slivovitz isn't real in the states. My uncle brews the real stuff in Croatia.
Oh, I've had the real stuff....
Originally Posted by mark kibort
im thinking of buying it.. found another newer one for cheaper too.
why do you say the 16valve is a no go? due to the shape? the shape looks like the S4 runners, no? i wonder how close in size.
the challenge is cutting them off and whats left, either connecting to the short manifold of what carl has made , or something else , maybe 968 manifold?
then, seeing if you can spread them out by about 1/2" each and spread the side to side spacing by about 1-1.5 " as well.
You do a lot of thinking. Just buy it, cut it and see. It's only money.
hacksaw or my usual Axe.... wonder what would work best.
those runners do look pretty nice though.. It just keeps calling me to buy it and hack off its legs!
Doooooo iiiiit!!!!
Old 04-13-2016, 11:00 AM
  #651
Imo000
Captain Obvious
Super User
Imo000's Avatar
Have the 968 ports extend into the 928 ports, this should remove most of the transitional lip.
Old 04-13-2016, 11:55 AM
  #652
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by Strosek Ultra
Do not increase the area of the 928S4 intake ports, you will loose air velocity. The ports at the gasket surface are actually too large unless the heads are sitting on a high speed 7 liter engine having 42mm intake valves.
Åke
968 ports are huge.
Actually, those AM ports look huge, too....although it is tough to tell from a picture.
Old 04-13-2016, 12:04 PM
  #653
Walt L
Walt L's Avatar
Old 04-13-2016, 12:12 PM
  #654
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,183 Likes on 1,233 Posts
Old 04-13-2016, 12:15 PM
  #655
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
_That's_ where BMW got that idea? Wow.
Old 04-13-2016, 12:30 PM
  #656
Wisconsin Joe
Wisconsin Joe's Avatar
...Unfortunately, tuned intake manifold works only across a narrow rev band. If the engine revs beyond that band, the pressure wave will arrive too late in the intake stroke, contributing little to charging. If the engine runs below that rev band, the pressure wave will arrive the inlet valve before it opens. In both cases, the low pressure area of pressure wave may even work against cylinder charging, hampering torque output...
2-stroke engines use a tuned exhaust that accomplishes essentially the same thing.
Insane power across a very narrow rev band.
I know snowmobile racers who do some amazing stuff. They get the engine/pipe combo dialed in, and then work over the clutch/CVT combo so that the engine is revving "just right" no matter what the speed the machine is going.
These are mostly "Ice Drag Racers".
They are really fast.
Old 04-13-2016, 12:52 PM
  #657
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by Hacker-Pschorr
notice how that one is "backwards"?
wondering if those exhaust pipes are a tuned length...so long, probably has a nice bottom-end power boost.
Old 04-13-2016, 01:21 PM
  #658
mark kibort
mark kibort's Avatar
can you make the engine sing a song with all different exhaust lengths to make different notes?
Old 04-13-2016, 01:23 PM
  #659
mark kibort
expansion chambers on 2 strokes is an entirely different set of concepts. man, does that give the engine power though! any one remember the kawasaki 500 3 cylinders? thats the last time i was scared on something motorized!
Old 04-13-2016, 01:24 PM
  #660
mark kibort
i should do it, huh!!! ive got my wallet in hand... debating!!!!!
Doooooo iiiiit!!!!
Quick Reply: Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
