86.5 Intake / Engine Harness / Timing Belt
#212
RennHarry (09-24-2023)
#221
Back On My Feet Again!
And now the passenger door works properly again. Sure glad I didn't mess with adjustment while it was on lift bars!
Cheers,
Cheers,
#224
Rip Torn
As the last post might suggest, I drove it to work on 9-28. Put about 500 miles on so far, in spite of torn boots. C4, 5 & 6 are buggered and started acting up. I got 10 years relief through >>> NUCCA <<< but it wasn't working any more so had to take a break. New images lead to new vector which seems to be working, that and fixing the bad recliner lever, so I'll see how things go.
Cheers,
Cheers,
#225
The Good, the Bad and the Ugly
The REALLY good news is that C5 didn't give me any trouble. Last time I was under the car, I rolled over onto my shoulder and it lit up like a nuclear explosion. Took me out of commission for a month. I think the root cause was broken ballast spring mounts on the La-Z-Boy recliner. Since I fixed those, NUCCA seems to be working again so hopefully I'm good for another 10 years or more.
And here's the Good: Cat-back and shafts came out quite easily.
Here's some Bad, but I think I can fix that.
Here's some more Bad.
I'm guessing that the transmission is sitting a bit low.
I'm also guessing this is why the transmission is a bit low.
And here's the Ugly.
What is this and are those cracks a problem?
I certainly won't touch it if I don't have to.
What else should I give attention to while I'm in there?
Cheers,
Cheers,
