928 Forum 1978-1995
Sponsored by: 928 Specialists
Lifter noise solutions needed - (gasket improperly installed)
Old 03-13-2012, 12:44 PM
  #106
supercedar
supercedar's Avatar
Originally Posted by atb
Only $100 at HF. That's amazing. Color LCD display and you can snap jpg's. Didn't these things used to run like $400? May have to a make stop to see if they have it in stock.
Adam,
I would be happy to drive down with mine for you to use. I want to check you guy's out anyway
Thomas
Old 03-13-2012, 12:47 PM
  #107
Bill Ball
Under the Lift
Bill Ball's Avatar
At 16mm the head on the HF scope is too big to go through the spark plug hole. You need something less than 13mm. There are a bunch or "endoscopes" on eBay for about $30, but they are 14.6mm. Here's a scope that says the head is 10mm, but the image sensor is only 320x240. http://www.ebay.com/itm/2-4-Video-In...item3a71c2ead5 This one at $50 (bid) is 11.2mm and 640x480 - that should work. http://www.ebay.com/itm/Zoom-functio...item1c24c8ceb5 I can't imagine what might be inside the cylinder that would make such a regular noise for so long. A valve would make a racket for just a short while and the car would not run so well.
Old 03-13-2012, 12:50 PM
  #108
supercedar
supercedar's Avatar
Originally Posted by Bill Ball
At 16mm the head on the HF scope is too big to go through the spark plug hole. You need something less than 13mm. There are a bunch or "endoscopes" on eBay for less than $30, but they are 14.6mm.
I will check the one I bought at Costco, seems it was well under 13mm head. More like 10mm. Maybe that is where cost is. It is also wireless for group viewing on a big screen.
Thomas
Old 03-13-2012, 01:31 PM
  #109
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,200 Likes on 1,241 Posts
Originally Posted by GregBBRD
You will want a "few" different length 6mm allen sockets, to make the job easier.
I use a 6mm allen cut down to only a couple of inches and a 6mm shorty open end wrench to do the bottom row.
It's slow goin since the wrench will only "swing" an inch or two in either direction on some of bolts.
The next time I do this job, I'm buying one of these:
Amazon Amazon
Old 03-13-2012, 02:04 PM
  #110
SeanR
SeanR's Avatar
Thomas
Costco one works perfect for inspecting in the cylinders.
Old 03-13-2012, 02:05 PM
  #111
brianrheffron
brianrheffron's Avatar
I use one of these in conjunction with a laptop
at work (Structural Engineering)and in the garage.
I haven't tried it into the cylinders yet but the
head is just on 13mm so it might work.
Saved it's cost the first time I used it.
Lots of uses and money well spent in my book.
http://www.dartsystems.co.uk/shop/in...roducts_id=781
Old 03-13-2012, 02:20 PM
  #112
Bill Ball
Under the Lift
Bill Ball's Avatar
Yes, that appears to be this one. http://www.ebay.com/itm/Zoom-functio...item1c24c8ceb5
Old 03-13-2012, 04:00 PM
  #113
danglerb
danglerb's Avatar
I've got some Wiha 6mm hex bits I like, they have a magicring in the tip to hold the bolt head.
Old 03-13-2012, 04:40 PM
  #114
atb
atb's Avatar
What do they call the tool at Costco? I did a search for borescope and endoscope at their website but no luck.
Old 03-13-2012, 06:39 PM
  #115
danglerb
danglerb's Avatar
Its an inspection camera, but costco site search blows. Google and plenty show along with comments on the costco version.
Old 03-13-2012, 06:58 PM
  #116
supercedar
supercedar's Avatar
I will check when I get home. Was a xmas gift.
Thomas
Old 03-13-2012, 07:01 PM
  #117
supercedar
supercedar's Avatar
Update: Just googled and it is the Whistler with all the goodies. Wife confirms it was $150.00
Old 03-13-2012, 08:37 PM
  #118
atb
atb's Avatar
Awesome. Thank you Thomas. I'd have you out, but the car is at my house, not the shop. Minimal room to hang out with the kids' bikes and wife's SUV.
Old 03-21-2012, 03:21 AM
  #119
atb
atb's Avatar
Default borescope pics
Well, its been interesting.
The piston crown does show some contact marks. The marks appear to be on (what I'm presuming to be) the lowest part of the crown. Basically, if I dropped a ball bearing down the spark hole, where it would come to rest on the piston crown. The mark is inbetween the valve relief eyebrows, which I'm presuming face curved side down. If not, then the camera is inverting the image and I'm looking at the top half of the piston.
I rooted around with a magnet down in the cylinder, and got nothing. It's a little frustrating, because even with the piston at BDC, I still can't position the probe head in such a fashion that I can see the entire piston crown. Since I am able to see what I'm presuming is the lowest point of the piston top, then whatever was in there isn't any longer, or is its non-ferrous so I can't get it with a magnet.
Any ideas or guesses as to what's going on here? Is this contact mark related to the "lifter noise"?
What might be a good way to flush out this cylinder?
Old 03-21-2012, 04:42 AM
  #120
danglerb
danglerb's Avatar
Do the old vacuum cleaner demo trick, put a thin cloth like a handkerchief over one of the hose connections on a shop vac and stick in a section of plastic hose. Periodically check the hanky for debris. Maybe rotate the engine so you can draw air from intake or exhaust valve.
Poke around with something sticky, like grease.
Quick Reply: Lifter noise solutions needed - (gasket improperly installed)
