928 Forum 1978-1995
Sponsored by: 928 Specialists
My First Porsche
Old 10-31-2011, 05:32 PM
  #31
JohnnyV
JohnnyV's Avatar
Thanks, Randy! Definitely an awesome thread. I guess I was confused because in my previous car forums TB was usually Throttle Body, but I stand corrected
Old 10-31-2011, 05:50 PM
  #32
linderpat
linderpat's Avatar
Received 2,420 Likes on 1,312 Posts
Originally Posted by MainePorsche
Johnny,
Best wishes with the car. Get PorKen liftbars. You're a little over 100k so check/release flexplate tension along with the usual things.
flexplate generally not an issue on the aerlier a/t's. Pre 86 should not be an issue, as the factory did use a clip to hold the shaft in place.
Old 10-31-2011, 07:49 PM
  #33
JohnnyV
JohnnyV's Avatar
Hmm..to check flexplate or not to check, that is the question..lol
Old 10-31-2011, 10:26 PM
  #34
Ish993
Ish993's Avatar
Originally Posted by bwmac
I am a junky so i normally have both pages open at once and just document my repairs at 928oc and repeat any new knowledge that gets sorted here.
Hey, I've been meaning to tell you that................. what?huh?avatar?hmmmmmmmm Oh yeah, as i was sayin'
Old 11-10-2011, 01:36 PM
  #35
JohnnyV
JohnnyV's Avatar
I spent an entire day cleaning and taking apart as much of the dash as I could to see what needs to be replaced, what can be reconditioned. So far so good. Here are so me current pics before I replace all the exterior lights.
Old 11-11-2011, 03:42 PM
  #36
JohnnyV
JohnnyV's Avatar
Replaced all of the front lighting. Here she is now
A quick before/after
Next up, the rears
Old 11-11-2011, 04:43 PM
  #37
Leon Speed
Leon Speed's Avatar
Looks much better, a full set of pearlies again.
Old 11-12-2011, 01:21 AM
  #38
jpitman2
jpitman2's Avatar
S4 wheels? Are they on the right ends ?
Opposite colouring to mine - white wheels on a white car!
jp 83 Euro S AT 54k
Old 11-12-2011, 01:34 AM
  #39
JohnnyV
JohnnyV's Avatar
AFAIK, these wheels came on the US 928S as well.
Old 11-12-2011, 03:43 AM
  #40
Hilton
Hilton's Avatar
jp 83 Euro S AT 54k
They are S4 wheels - but he has them on the correct ends. You can see the deeper dish on the rears in a couple of the shots.
JohnnyV - they're definitely off an S4 - prior to '87 the sets of dish (aka manhole) wheels were 16x7 on all four corners. With the S4, the rears became 16x8 with a deeper inset dish like yours are.
Good choice putting the lights back . They look a little misty, as do most of ours. I keep meaning to get the stuff to polish them clear again - a couple of rennlisters have done so, and if you search for "cerium oxide" you should find the threads with pics and advice.
Old 11-12-2011, 04:07 AM
  #41
Hilton
Hilton's Avatar
Found the thread.. here:
https://rennlist.com/forums/928-foru...foglights.html
And the broken link in that thread shoul be to here:
http://volvospeed.com/install_perfor...g_scratch.html
Old 11-12-2011, 08:16 PM
  #42
JohnnyV
JohnnyV's Avatar
jpitman and Hilton, I stand corrected!! I learned something new
Hilton, thanks for the light info, I will get to polishing them ASAP!
Old 11-12-2011, 09:38 PM
  #43
Hilton
Hilton's Avatar
Making the post yesterday prompted me to order some cerium oxide.. so I'll be having a go at one of mine with some wet and dry (1200/1500/2000) and then cerium oxide to finish.
Old 11-12-2011, 09:53 PM
  #44
JohnnyV
JohnnyV's Avatar
Post before and afters!
Old 12-05-2011, 07:25 PM
  #45
JohnnyV
JohnnyV's Avatar
Small update:
Installed new Bosch battery and WOW what a difference. The old battery didn't fit right and just sucked overall.
With the new battery, lights that never worked started working, idle was smoother, and the overall feel of the car improved. Took her for a nice ride around town and came home smiling
Quick Reply: My First Porsche
