928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 08-19-2017, 09:20 PM
  #7231
jetson8859
jetson8859's Avatar
Continued with 90 GT engine build, cam gears, PK tensioner and belt installed and timing all set.
Old 08-20-2017, 07:24 PM
  #7232
ltoolio
ltoolio's Avatar
Installed the newly-wrapped Pod from Classic9. Really love the red stitching on it!
Also fixed a couple of the switches that had broken tabs on them, thereby preventing the switch from sitting flush against the pod. Used some cut metal bits from a large hose clamp as the source material, bent them using some pliers and adhered them using a plastic epoxy compound I got off Ebay. Worked like a charm.
Have the new door panels from Classic9 also mounted. Cleaned and SEM painted the armrests so everything looks clean. Need to reattach a few more things then they are done.
Finishing up the rear bumper next.
Old 08-21-2017, 09:23 PM
  #7233
968
968's Avatar
Hooked up a non working high beam light and retightened new AC belt on my 81 Euro S while looking for a new oil leak that is dripping on the passenger side exhaust. I did not see the source of the leak by the way!!!!
Old 08-21-2017, 10:23 PM
  #7234
The Forgotten On
The Forgotten On's Avatar
Removed the plugs and cranked the engine of my 81 to clear it of any water as a head gasket failed.
Turns out it was cylinder #3 and the other head gasket was leaking externally.
No water made it into the crank case so the oil looks normal and wont warrant me to split the block and replace the main bearings.
I guess that means my piston rings are doing their job as well.
Now I have to pull the engine and rebuild it along with the other systems in the engine bay that are a pain to get to including the front suspension.
Roger and Mark are going to get some good money from me
Old 08-22-2017, 09:36 AM
  #7235
Alan
Electron Wrangler
Alan's Avatar
Candidate for a PKT tension warning connection? https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Old 08-22-2017, 01:54 PM
  #7236
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by dr bob
First steps towards swapping in the new transmission mounts -- Butt is up on stands and a casual survey of the work is done. The big question: how much cleaning will be involved? Hint: I haven't turned a wrench on it yet. Film at 11...
With everything lickin' clean, I decided to try a simple hose-section "spacer" in the existing mounts, a follow-on to others' efforts and shared results. I started with a 1.75" section of 5/8" heater hose with a similar-length section of 3/8" power steering return hose stuffed inside. Squeezed together, they just fit into the gap in the transmission mounts at "full extension". The transmission now sits up where a new mount would put it.
Of course, because it's so simple, cheap, and easy, it's nowhere near the isolation afforded by new transmission mounts. I'm going to drive it a few more times to be sure, but there's definitely more transmission sounds coming up into the cabin now. The Good News is that, along with the motor mounts over the winter, there is no hot air coming up through the console with the windows down or sunroof open.
I may try just pulling the inner pieces of PS hose out of the heater hose spacers before I put the new mounts in. I know I'm going to get them in soon. Just experimenting/playing on the way to completion.
After looking at how squished the hose "spacers" were, with no give at all really, I just put the new mounts in yesterday and called it done. The hose sections were intended to offer a little bit of cushion while raising the gearbox back to normal height. No cushion, no give, hose pieces smashed flat. Might as well have put solid block spacers in there. Full transmission mount replacement took less than an hour, including cleaning and clean-up time, so not too bad. Haven't driven it yet to gauge the improvement. The gearbox sits high enough now to slip fingers between the diff case and the crossmember, about half an inch higher than it was sitting prior to the project.
Old 08-22-2017, 07:26 PM
  #7237
968
968's Avatar
Attempting to stop an oil leak that appears to be at the lower front passenger side valve / cam cover. How do you get your hands in there to try and get away with tightening what appear to be allen head bolts?????
Old 08-22-2017, 09:13 PM
  #7238
dr bob
dr bob's Avatar
Waste no time "tightening" those bolts. They are shoulder bolts that don't change the actual pressure at the corners. They are 6mm bolts under the mushroom heads, so get torqued to barely greater than finger-tight else risk breaking the bolt.
The cam covers seal to the head at the edges with a gasket that's really a formed rubber o-ring-style seal. There are rubber seals under those hold-down bolts, seals at the base of each spark-plug well, and o-ring style seals where the vent system nozzles fit into the cam cover.
For the passenger-side cover, you'll need to remove the front corner engine lifting bracket after the front-of-engine harness has been freed. There's a connector there for the Hall sensor at the back of the cam gear backing plate. At the rear of the cam cover is a bracket that holds the air pump diverter valve. Remove those brackets, the plug wires, the vent hoses, and that fuel hose that passes between the fenderwall and the fuel rail at the front. Once all that stuff is out of the way, the cover can come off.
Easiest way to fit the new gasket is using mini plastic cable ties to hold it in place. Cut each tie as you put the bolts back in one by one. There's an instruction to use a little silicone gasket maker at the joint where the head and intake have a small seam.
Gasket sets come from our favorite sponsor vendors.
Old 08-22-2017, 10:47 PM
  #7239
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,784 Likes on 1,355 Posts
Picked up some refinished Clubsport wheels from Al Reed Polishing.
Old 08-23-2017, 09:03 AM
  #7240
928cs
928cs's Avatar
Technical inspection for my new CS yesterday.
During the measure of the pollution, the main coolant hose has collapsed.
Another item on the to do list for this car
Anyway, the inspection went otherwise quite well and I will registered the car soon.
Old 08-23-2017, 10:01 AM
  #7241
paalw
paalw's Avatar
Wow those are beautiful. Looks like new old stock What did he do to them? Reanodizing?
Old 08-23-2017, 10:55 AM
  #7242
Rob Edwards
Archive Gatekeeper
Yes- they chemically strip the old anodizing, polish the wheels, and then reanodize.
Old 08-23-2017, 01:21 PM
  #7243
The Deputy
The Deputy's Avatar
That's Homer Simpson donut drool stuff right there...
Old 08-23-2017, 01:49 PM
  #7244
axidjw
axidjw's Avatar
replaced the hood struts and now no more ghetto bar holding the hood up..lol
hood matting on the way and next on the list
Also met up with a fellow member in my little town and saw his stunning 91
Old 08-23-2017, 04:33 PM
  #7245
ddarnell
ddarnell's Avatar
Diagnosed and confirmed a suspected timing advance problem. Wife said it starting running bad and pinging at any acceleration. Checked timing and it was 39° initial with 57° total.
Not sure why it changed suddenly and dramatically.
Quick Reply: So what did you do to your 928 Today......
