928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 03-20-2016, 12:46 AM
  #6241
Captain_Slow
Captain_Slow's Avatar
Pulled out the cheap code alarm and a bunch of wires connected to nothing. Connected the radio head unit (amp still disconnected), turned the key, and the display lit up when the gauge pods lit up. Turned the key one more click and the car started right up (was a little worried I'd removed something that would cause a no-start). Returned a few wires that had been altered, spliced, or piggybacked to like factory....glad it all worked. Tomorrow I can finally replace the guts in the HVAC center comb flap and footwell flap actuators.
Old 03-24-2016, 01:43 AM
  #6242
silbershark
silbershark's Avatar
Perhaps not a big deal to some, but my dh and I measured the hoses that still need replaced and removed the TB covers. I was happy like a fat kid getting birthday cake to find the TB gears are steel instead of coated alloy (and square tooth, since I already have a square belt)!
Also very pleased to find there are no oil leaks at the cam seals.
Getting my next parts order ready, and it will be an inexpensive one. BONUS.
Old 03-24-2016, 02:21 AM
  #6243
ltoolio
ltoolio's Avatar
In what is 99% overkill, I've prepped my windshield washer reservoir for reinstallation.
Did the Simple Green w/ rocks tip from Stan for the inside, and painted the exterior with red plastic paint since it was so discolored from rust and grime.
Ideally, I'll never have to look at it again, but if I do - at least it'll be mostly pleasing to the eye.
Who needs rust on something you'll see once every 5 years when you can have red paint!
Old 03-24-2016, 02:24 PM
  #6244
Whitesands
Whitesands's Avatar
New bits going in today, center vent lever and microswitch, pencil for size ref.
Old 03-24-2016, 04:45 PM
  #6245
Donald Smith
Donald Smith's Avatar
Smile
Possibly found the source of my auto tranny not working properly. Broken spring found in the pan. Ordered a new filter and gasket, and will change fluids and spring. To be continued......
Old 03-27-2016, 04:56 AM
  #6246
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
Fri nite ' bout had a heart attack! ..
Running good, 75mph, hit the hammer.....and... BAM! Red lights, not the good kind, the instrument "!" kind. ... Sh**!.
So I turned the screw a 1/4 turn today.
Old 03-27-2016, 10:11 AM
  #6247
Paddcomp
Paddcomp's Avatar
I cleaned my throttle cable ends.
Old 03-27-2016, 11:30 AM
  #6248
cobalt
cobalt's Avatar
Received 2,146 Likes on 1,288 Posts
I did a complete overhaul. All new fluids; oil, tranny, coolant, power steering & brake. New tires, found my power steering hose was leaking and replaced it. Apparently it had a small hole and was sucking air in without leaking for a long time but finally let go. Steering is 100% improved. Then I cleaned the underside which is just as clean as its top side.
Washed it and took it for a long drive. She drove like a new car and got all sorts of attention.
Old 03-27-2016, 01:27 PM
  #6249
The Deputy
The Deputy's Avatar
Default Added some support brackets to the door panel.
Made these support brackets up at work. The two bottom bolting areas of this panel were broken, drivers side, so I added these brackets.
Really stiffen up the door panel. You can clearly see the crack in this picture.
These brackets and the pop-rivets will not be visible.
Brian.
Old 03-27-2016, 09:34 PM
  #6250
Captain_Slow
Got tired of looking at old split and flaking heat shrink wrap on spade connectors around the engine compartment. Removed the crumbling old stuff and applied Deoxit to the connectors. Installed the new heat shrink wrap to connectors. The small details can make a huge difference.
Old 03-28-2016, 04:47 AM
  #6251
545svk
545svk's Avatar
Is that timing belt tension?
All good after 1/4 turn?
Old 03-28-2016, 07:41 AM
  #6252
Adk46
Adk46's Avatar
I took my car out for a spin. It occurred to me that perhaps after the intake refresh, my cruise control might work. I didn't know exactly how to operate it, moved the lever around randomly, and it kicked in!
Seems not to kick in every time, or immediately, so perhaps nothing has changed.
Old 03-28-2016, 09:50 AM
  #6253
OTR18WHEELER
Yeah, a few 6k revs, and a quick flogging up the road, I couldn't make it come back on.
I was very limited on time Saturday, I really wanted to clean the crud off while I was in there.
The belt was tracking true, and everything else appeared fine.
Old 03-29-2016, 11:19 PM
  #6254
FRUNKenstein
FRUNKenstein's Avatar
Great day to drive the shark to work - sunny but cool weather. It got the spot of honor in the garage and jealous looks from its younger siblings.
Old 03-30-2016, 02:07 AM
  #6255
granprixweiss928
granprixweiss928's Avatar
I took the engine out of my 81 928 (for headgaskets)
and then started to tear down.
I did all this in one day, by myself.
Quick Reply: So what did you do to your 928 Today......
