Project REAR WW LINER - GTS & Others
#408
Pete, one nice thing about having the GTS outer liner halves finally fitting is that the bulk of the outer form is the same for all the versions of the 928, so I think all I have to do is change the upper wheel arch form from the GTS to the earlier version and adjust it for the narrower rear fender width of the earlier cars and then I will have the correct shape also for the earlier cars.
There is going to be some difference in the mounting brackets, but I also have all of those developed for the earlier cars, the ones that are different from the GTS, all except still the right rear upper bracket for the earlier cars. I haven't yet spent the time to see what kind of bracket I can devise for that part of the mounting of the earlier liners.
When I have the GTS liners well on their way I will try to finish up the liners for all the earlier cars.
Then I may also have to acquire an OB, an S2 and S3 in order to see what kind of mounting brackets might be needed for all of them, if in fact they need to be different from the S4 and GT brackets.
#410
There are a few bucks in lapsed DMV fees the previous/current caretaker should help settle with (if available)..but...wouldnt be a bad idear.
Latest posting:
Im oblivious to who gets Leroy how or when..but it would generate product if it could happen.
Latest posting:
#412
Hi Jerry, so glad you are close to production! Please count me in for a set for my '92 GTS. Hopefully, there are a few other Western Canada 928-Philes and we might be able to coordinate some shipping when you are caught up.
Best regards, Tim
Best regards, Tim
#416
Jerry. PM sent but it basically said put me down for a set of insulated ones for my 90 S4.
#417
Liners
Jerry: I just caught up with this 28 pager. I'm sure you know, but just thought I'd mention in case you get frustrated again, that it should be obvious from the length of the thread and the new names that keep appearing, that this has wide, let me restate that, WIDE, appeal. ALL GTSs are/will disintegrate if they haven't already and apparently many S4s and OBs need your product.
#418
Spoke with Jerry re. CDN possibilities......stay tuned
#420
