Twin Turbo 928 fixed and back out there terrorizing the streets!
#1667
Other items
On other news, John's getting the new rear muffler sheet metal rolled next. That'll be interesting. And the whole exhaust can now be fabricated with the new manifold ready. It's another huge amount of work that should start after John delivers another white twin turbo to the owner on Wednesday.
#1669
Bellows installed
The main pipes fused on both sides. One more wastegate circuit to go and the downpipes and the newly cast manifold can be installed for fabrication of the rest of the exhaust.
#1672
Big fat center pipe
John's fabricating a big fat oval center pipe for the exhaust. This is where the pulses fully combine and the gas cools. It's going to need three or four vertical support rods to prevent and drumming, booming, or droning.
#1673
Big fat center pipe being test fitted
The big fat center pipe being test fitted. The real production piece will likely need to be made from heavier gauge steel. And as the photo shows, this is the biggest pipe that fits under the 928.
#1674
That thing is huge! It's hard to believe that such a large pipe is required, but that's the great thing about your project. John is sampling lots of data and whether something works or not will be demonstrated by the data.
#1675
been looking at products below to save a little ground clearance:
https://m.summitracing.com/parts/vpe...hoCdHcQAvD_BwE
http://spintechmufflers.com/exhaust-tubing/oval-tubing/
#1676
The other option on the table is to cut a small segment off from two 3.5" pipes and weld them together to form a pipe with the infinity sign cross section. The cross-sectional area is only slightly smaller than dual 3.5 pipes, using the circle segment formula. That version is much stronger structurally and can therefore be made from lighter material and without support rods. The construction there isn't without issues either. If you cut open the whole pipe section side, it will spring open a bit and then that makes mating the ends more difficult.
From the velocity perspective, it would be ok the step down from 3.5" to 3" after the axle mufflers. Then after the rear muffler you could go to 4". That's how a car factory would (have) probably size(s) the exhaust for these power levels (in the 1980s), about constant velocity. I've got a cooling-density-velocity model in a spreadsheet workbook on that. I don't think we'll do that with this version, though. It's a lot easier to go down in size at the tail pipe than upsize the whole rear section, so we're going too large with dual 3.5" rear section and 4.5" tailpipe. Then one can tweak the tail pipe smaller and see when it starts hurting power.
#1679
If one just wants to flatten a single pipe for some section, press with plates is probably just fine.
#1680
[url]http://spintechmufflers.com/exhaust-tubing/oval-tubing/[/url
