928 Forum 1978-1995
Sponsored by: 928 Specialists
New Product from 928sRus - Enhanced Intake System
Old 04-15-2010, 02:58 PM
  #91
Charley B
Charley B's Avatar
Originally Posted by SeanR
.................I've had it installed for a few days now and the throttle response seems to be much better, more crisp. It may just be me, but it feels better than it did before.
I experienced the same thing after i washed mine last week.
Old 04-15-2010, 03:17 PM
  #92
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Roger - will you be offering a filter/tube setup similar to Mark's? I like the look of the same diameter tubes for the entire system.
Old 04-15-2010, 05:07 PM
  #93
Leon Speed
Leon Speed's Avatar
Just a pic.
Sean, your engine is really yellow
Old 04-15-2010, 05:36 PM
  #94
John Speake
John Speake's Avatar
Did you gather before and after A/F ratios for the dyno runs, Roger ?
Originally Posted by ROG100
Well we just returned from the first EIS system dyno session.
Lot more detail to come but I am happy with the result.
On an 88 S4 automatic with a well maintained engine and an X pipe we gained an average of 8.5 RWHP and 5 RWT. This was after fitting the new EIS.
The car has circa 200k miles. Three pulls and with the car still on the dyno another three pulls with the new system. Very obvious that more gains could easily be made with shark tuning.
On Jim's GTS we got about 5 RWHP but his car is not stock. We will have the dyno charts later.
Another run next Thursday on another stock S4 just to make sure the numbers are repeatable.
Old 04-15-2010, 05:45 PM
  #95
SeanR
SeanR's Avatar
Waiting on the Dyno place to e-mail us the charts. I've got the files but can't get Winpep to give me the ones I want.
I do know that the A/F leaned out a small bit on my car with this intake on. There was even less pre-detonation than stock. The dyno guys said mine was spot on and that increasing the fuel a tad would give some better numbers. Will have to get hopping on that Sharktuner and see what we can come up with.
Old 04-15-2010, 05:51 PM
  #96
John Speake
OK Sean, that makes sense as the stock fuelling is too rich for max power at the top end. So if the EIS is leaning it out somewhat that is a logical result.
Old 04-15-2010, 06:05 PM
  #97
inactiveuser1
inactiveuser1's Avatar
Will be adding Erams or just hope to make my own setup later on which is why I like the tubes.Just like the Air Intake system I dont like to wait to long to get something going waited over a year on the Air system.
If nothing is available to meet needs will be working on my own custom setup still thinking on whats best and reading more on it as will be learning while designing lol.
Straight pipes are 4" the rest of the system is 3 1/2"
Old 04-16-2010, 12:12 PM
  #98
SeanR
SeanR's Avatar
For some reason I can't get Winpep to show me the same stuff that it showed at the dyno, these numbers are a bit lower than we had there, but the increases are the same.
But here is a run comparison on my S4 with a before and after intake install.
Old 04-16-2010, 12:30 PM
  #99
soontobered84
soontobered84's Avatar
Sean, You might also add to the graph legend (strictly for posterity sake) that these numbers are without sharktuning or any other enhancement. Straight 10 minute bolt-on and go.
Old 04-16-2010, 12:34 PM
  #100
SeanR
SeanR's Avatar
Hacker, When I go back to Rogers I'll mail you the files, just got home after posting that and don't have them with me. Hack gave me some advice. First time messing with Winpep.
Thanks John, ya just did it for me
Old 04-16-2010, 12:39 PM
  #101
S4ordie
S4ordie's Avatar
Nice numbers Sean! Where is the RPM values on these plots? MPH is ok but not the best metric for me.
Old 04-16-2010, 12:47 PM
  #102
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,200 Likes on 1,241 Posts
Just tossing this out there because I'm curious. What do "we" think is the reason for the gain?
  • Less restriction
  • smoother flow into the MAF
  • the car feels sexier with new shiny bits and works a bit harder....
Was the MAF screen installed?
Old 04-16-2010, 12:48 PM
  #103
SeanR
SeanR's Avatar
Hacker is going to do that stuff for me. Just sent him the files.
Told ya I don't know what I'm doing.
Old 04-16-2010, 01:00 PM
  #104
PorKen
Inventor
PorKen's Avatar
Looks like you could squeak a little more HP out at high rpm with SharkTuning by flattening out the newly leaner AFR on top, probably bigger gains on torque in the low to mid range by richening the now way too lean AFRs down low.
Note that tailpipe AFRs are usually .5-1 point leaner than at the X-pipe.
Old 04-16-2010, 01:05 PM
  #105
soontobered84
Hacker,
tentative answers:
yes
yes
no
and the MAF was not messed with at all except to pull the stock airbox and install the EIS.
Quick Reply: New Product from 928sRus - Enhanced Intake System
