928 Forum 1978-1995
Sponsored by: 928 Specialists
Porken's 85 chips- Awesome!
Old 04-11-2012, 08:16 PM
  #556
Pyzik
Pyzik's Avatar
I have to take apart the intake to adjust the throttle right?
Old 04-11-2012, 08:22 PM
  #557
PorKen
Inventor
PorKen's Avatar
The idle speed screw can be accessed between the intake runners. (Black 1/4" handle and extension, 7mm socket, below.)
You may need a long handled screwdriver to gently move a vacuum hose aside to see it.
Old 04-11-2012, 08:25 PM
  #558
SMTCapeCod
SMTCapeCod's Avatar
^^^ More Blink'rs, please!
Or at least one or two for the O/C!
Old 04-11-2012, 09:11 PM
  #559
Pyzik
Pyzik's Avatar
The screw won't turn anymore an the idle went down only to 1400rpm, the car is warm already
Old 04-11-2012, 09:48 PM
  #560
PorKen
Inventor
PorKen's Avatar
If you also put in the 'rings, then it could be a plenum hose that is rolled over, and/or a loose clamp. Is the brake booster hose connected?
Loosen plenum side clamps.
Remove plenums.
Loosen runner side clamps.
(Install TQrings.)
Install plenums.
Center hoses.
Push each plenum toward the runners as hard as you can as you tighten the clamps.
Old 04-11-2012, 10:04 PM
  #561
Hilton
Hilton's Avatar
Just make one; Ken posted the simple circuit years ago here on the forums
Old 04-11-2012, 10:19 PM
  #562
Pyzik
Pyzik's Avatar
It was doing it before I installed the rings, I will check everything again tomorrow if all vacuum lines are ok
Old 04-11-2012, 10:27 PM
  #563
SMTCapeCod
SMTCapeCod's Avatar
OK, you have a vacuum leak.
Does your AFPR pull a vacuum signal? Any chance the MAS isn't fully seated?
To adjust the throttle, you work with the accelerator pedal, or the threaded rod. To get it right requires a view on the throttle plate, so yes you would need to take the center section out.
But, we're on idle/CO adjustment.
Add some yourself before throwing elbows.
BTW, whats up with your headlights?
Old 04-11-2012, 11:19 PM
  #564
Temekun
Temekun's Avatar
Since you reset the brain by unhooking and resetting the rear ground I'm still betting that the refresh has left you with an air leak. I'd start with just making sure everything is seated and the clamps are tight and in place on the runners after that you can try the piece of rubber hose to your ear and move it around and listen for a specific spot.
And what are you doing with your old lights? If you don't want them let me know. You can always stop in the office as you drive by.
Tim
Old 04-12-2012, 12:26 AM
  #565
Pyzik
Pyzik's Avatar
Alright , I will go over everything again tomorrow . I'm little curious , how come there is no 2 rings for the bigger diameter pipe that goes to TB? I drove the car on the high idle (at1700rpm) just to check it out , and the car is a beast! So smooth and responsive! Now it's a true Himen car!
Oh and thats the 7mm I was turning, is it the right screw?
Old 04-12-2012, 03:18 AM
  #566
PorKen
Inventor
PorKen's Avatar
The airflow distribution 'T' touches the plenums (which creates the gap from the plenums to the runners).
Correct.
Old 04-12-2012, 10:11 AM
  #567
Pyzik
Pyzik's Avatar
Check out the idle and the response !
Almost like a motorcycle haha http://www.youtube.com/watch?v=cz_82Wt2MkA&feature=youtube_gdata_player
Old 04-12-2012, 07:22 PM
  #568
Pyzik
Pyzik's Avatar
I rechecked everything I found a broken clamp on one of the runners so replaced that, on cold engine I jumped the fuel pump and set to 56psi and when I start the car the gauge shows 44psi . Is it normal that I set the fuel pressure on engine off is set to 56 and when I start the car it's only 44? All my vacuum lines are zip tied tight but I checked anyway. Oh and yesterday. I set the pressure on warm engine to 58psi and when I jumped the fuel pump today the pressure showed like 66psi . So I turned it down to 56 on cold engine. Also just to be sure , when I recived the chips in those green containers, when installing them , was I supposed to pry it out of the socket they were in or leave it in and just install the whole thing in the brains? ( I left them in and installed the whole thing)
Old 04-12-2012, 08:33 PM
  #569
Pyzik
Pyzik's Avatar
My afpr does have a vacuum line hooked up and my mas is sitting good. Would not putting the top part of air intake couse the problem? Filter is in and no more , should I install the filter top cover too?
Old 04-12-2012, 09:45 PM
  #570
PorKen
Inventor
PorKen's Avatar
58 cold. At idle, manifold vacuum reduces the fuel pressure from the FPR to balance the vacuum at the injectors.
Leave the chips in the sockets. It protects the delicate EPROM pins if/when there is an upgrade available.
Quick Reply: Porken's 85 chips- Awesome!
