928 Forum 1978-1995
Sponsored by: 928 Specialists
Holber race car gets a new engine. Progress Report
Old 08-06-2008, 02:37 AM
  #31
Bill Ball
Under the Lift
Bill Ball's Avatar
Classic Amsoil coking.
Old 08-06-2008, 04:01 AM
  #32
mark kibort
mark kibort's Avatar
thats a lot of oil, not carbon build up. probably time to do a "non-stock" way of oil vapor removal, instead of recycle.
mk
Old 08-06-2008, 04:13 AM
  #33
mark kibort
Here you go, the moment of truth. The Holbert engne exposed.
Jim, are you watching? Still think there is something real special about the Holbert "one off" engine? Looks like stock parts to me.
Hey, look what i found in the engine.............. the lost cam tooth that never made it to the magnet.
notice how clean the pan is. thats untouched as it came off the engine.
mk
Old 08-06-2008, 04:14 AM
  #34
mark kibort
Holbert engine is reduced to a core, now its time for the build up. should be finshed by the weekend.
mk
Old 08-06-2008, 08:18 AM
  #35
Black Sea RD
Former Vendor
Black Sea RD's Avatar
That engine is surprisingly clean for all the heavy use it has seen. Both my engines were stained a yellowish/amber color inside. I guess Amsoil does pretty well in our engines.
Thanks for the pictures Mark and very good luck with your build up and the new engine!
Constantine
Old 08-06-2008, 09:29 AM
  #36
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,168 Likes on 1,225 Posts
That head surface doesn't look ready for a Cometic gasket.
Old 08-06-2008, 01:07 PM
  #37
BC
BC's Avatar
He sent it in for work - hopefully they don't monkey it up.
Please take a picture of the heads when you get them back mark.
Old 08-06-2008, 01:13 PM
  #38
BC
BC's Avatar
(Disregard the valve seats, they were done horribly wrong) - but look at the head mating surface here:
Thats what you need (or better) for cometic.
Old 08-06-2008, 01:56 PM
  #39
123quattro
123quattro's Avatar
Yep. You need to be able to see your reflection while looking at it.
Old 08-06-2008, 02:47 PM
  #40
mark kibort
jThanks C,
I was very surprised as well, especially, since i didnt have anything to do with its first 18,000miles of use .
the pictures dont do it justice, it looks brand new. no sludge, nothing!
When we took apart scots motor that was using vavoline racing oil for a season, it didnt look near as good and that was only one year!
mk
Constantine
Old 08-06-2008, 02:56 PM
  #41
atb
atb's Avatar
It looks like the counterweights were polished, or is that just "Amsoil sheen".
(Edit)-Nevermind, I thought I was seeing a reflection, it wasn't.
Old 08-06-2008, 03:29 PM
  #42
Tom. M
Deleted
Tom. M's Avatar
Crack that girdle open..lets see some oiling pathways..and the crank oil pathway would be nice to see. So..amsoil is a high detergent oil...?
Either way...the Holbert motor was likely hand built under very tight tolerances..be interesting to get a few measurements off the bore/ring end gap/ etc..... Can you see any port matching/machining (intake or exhaust)?..
What is the final build of the new motor going to be? 6.4L with big valve heads?
Old 08-06-2008, 04:09 PM
  #43
Dennis K
Dennis K's Avatar
That counterweight drilling looks different from what I've seen on 3 other stock cranks. A lot deeper.
Old 08-06-2008, 04:16 PM
  #44
FUSE69
FUSE69's Avatar
Hi Mark,
I hope you're going to scrape off all that insulation from the firewall while the engine is pulled!
Tass928 posted on the 'weight savings' thread that all that junk is 10lbs!!
Best of luck with the build up
Old 08-06-2008, 04:17 PM
  #45
hacker-pschorr
My bad, I didn't see that post.
Quick Reply: Holber race car gets a new engine. Progress Report
