Holber race car gets a new engine. Progress Report
#181
Under the Lift
One one GTS here at least, severe coking of the combustion chambers, raising the compression to 210, lead to severe pinging. We had the intake system cleaned with a BG Products treatment, compression came down to 200-205 max, and the pings disappeared.
#182
Inventor
Bosch numbers are lower numerically for colder (for NGK, colder is higher #s).
And because your WOT switch works well, we should have some protection with WOT ignition retard as well as the new knock sensors. However, I expect WOT will be leaner than ideal and you will have knocks. If the mixture is not 12-13 on WOT and there are more than just a couple of knocks on a run, it needs to be tuned right away. WOT is going to be no better than stoich with your stock LH. I have a Sharktuned chip set for 30 lb injectors and about 425HP.
Louie does this, as well as zeroing out the LH WOT map (which adds to the base map, unlike the EZ map), and tuning just the base fuel map.
#183
Supercharged
Also, using a boosted chipset as a surrogate, will probably introduce some rather interesting fueling characteristics - some fat, some lean... just be careful.
#184
Supercharged
You should start by disconnecting the WOT input to the EZ-K at the ECU connector (or cut the wire). Then ST the cruise map. The EZ WOT map is flat, ie rpm based only, with no compensation for air density.
#185
Under the Lift
Maybe this was alread covered, but what size injectors will be installed? If you're going to run anything less than 30lb, I think you may have issues using those chips.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#186
Administrator - "Tyson"
It might not be a bad idea to try the plugs Todd uses in his car. They are a non-projected racing plug (about $1.50 at our local Farm Supply store, not kidding) by NGK. He saw some fouling during the cold months during stop / go driving, should not be an issue at all in your car in NorCal. These are the plugs of choice with the import tuner crowd, designed for constant high rpm's where you are trying to avoid the spark plug turning into a glow plug.
I'll try to find the number, if you cannot find them locally I can send some out there ASAP if you are interested.
Is high load / low rpm still the rule of thumb for a new motor?
#189
Inventor
A non-projected tip with the same heat range is cooler than a projected.
#191
#193
Good info Guys!
Ill see if i can get the WR5 or 6DC and give them a shot.
as was mentioned, i have very low mileage 30lb injectors that are going in courtesy of George (great deal!)
Ill back the fuel pressure off from the 72psi i ran on the holbert engine, down to about stock 52ish.
by the way, all this talk about sacrafices with the cam timing. the 85 cams are a natural for this. they are a full 8 degrees retarded , over the entire duration vs the GT cams. in otherwords, i dont even know if the porken tool could retard the GT cams this much! however, the exhaust cams are the same effective timing and duration. what would the retard of the exhaust cam create? anyway, with an already head start on reduced cam timing, and the ability to reduce torque and power in the mid range Rpm by flappy disconnect, i think we are in good shape.
mk
mk
#194
#195
Inventor
I made >15 rwhp more by going from +3° advance to -1° retard with my S³ cams, same dyno session. The tq/hp peaks move about 100 rpm with each crank° ±.
Going to -4° raised the peaks even higher, didn't lose hp, but didn't gain, I'm fairly certain because the exhaust was restricting it. With a revised exhaust, it feels much more powerful - dyno soon.
The 32V gears have a ±7.5° range in the slots, so with the 32V'r (aka PorKen tool) you have a 15° range, no matter which cams you have, S³, GT, S4, or GTS.
