928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine builders help needed, pics
Old Feb 26, 2008 | 10:16 PM
BC's Avatar
BC
Call me crazy, but that E1 and A1 means something on that tool, which matches what I remember is on the cams. A and E, IIRC. So in that case, you may have reversed the tool? A would be intake and exhaust would be E.
Old Feb 26, 2008 | 10:18 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Originally Posted by Sterling
if I remember correctly that cam tool is only good for one years cams... its in the workshop manual... if you started mixing and matching cams that never came from the factory, it would make a big difference... its probably not off enough to cause contact when you rotate the engine... I would check it with dial indicators.... if you are way off then you are a tooth off. if you are close its just the differences in the cams.
I used that tool on my '85. It worked fine.
+1 on making sure you have the cams on the correct side of the engine. Don't check the markings on the end...check the raised numbers on the shaft.
"E" is for intake
"A" is for exhaust
File Type: jpg
Old Feb 26, 2008 | 10:20 PM
mark kibort's Avatar
mark kibort
its left side and right side
ah oh. if "E" means exhaust, no wonder im down on power. this pic looks like "E" is on the intake side!! ahhhhhh!
mk
File Type: jpg
File Type: jpg
Old Feb 26, 2008 | 10:40 PM
Mako 928's Avatar
Mako 928
I am also getting ready to do this. I thought the WSM stated that there 2 seperate tools for the seperate years. I.E.
MY 85/86 tool # 9226
MY 87 forward tool # 9248
Old Feb 26, 2008 | 10:42 PM
mark kibort
mine are being checked for the GT CAMS and its an S4 tool\
one of them is 9225-3
Old Feb 26, 2008 | 10:48 PM
mark kibort
rotate the cams a little until the too get seated on both cams. right now, it looks like you need to rotate the exhaust cam CCW to make the intake cam fit the tool. if that doesnt work, you are off a tooth.
the next best thing to do is get the 113mm between the marks.
let us know what you find.
mk
Old Feb 26, 2008 | 10:51 PM
BC's Avatar
BC
Well, ****, there you go. Of course E means intake and A is exhaust.
Where do I get this tool?
Old Feb 27, 2008 | 12:00 AM
David L. Lutz's Avatar
David L. Lutz
Brendan,
The way I understand it (and according to my telephone conversation with DR ) we need both sets of tools #9226 & #9248 for proper uninstall and install on the 87' S4. (someone please correct me if I am wrong)
I have been waiting on tool # 9226 which has the alignment tools you see in the above pic's. I should get them by next Tuesday. When are you needing these? I could loan these to you as I will not be needing the alignment tools for several weeks. (#9226 is a little pricey @ 276.25)
Old Feb 27, 2008 | 12:04 AM
Big Dave's Avatar
Big Dave
Remember...zee engineers were German, so they probably spoke German, too
Old Feb 27, 2008 | 12:05 AM
Big Dave's Avatar
Big Dave
Hammer...how about making a photocopy of those tools with size measurements so folks here can make their own?
Old Feb 27, 2008 | 12:09 AM
Big Dave's Avatar
Big Dave
FYI...
My cam installation page... http://www.928oc.org/928oc_michigan/tbelt9.html
Old Feb 27, 2008 | 12:40 AM
BC's Avatar
BC
Originally Posted by David L. Lutz
Brendan,
Thanks for the offer! But I have S3 cams. Would that make a difference?
Old Feb 27, 2008 | 01:06 AM
mark kibort
I traced them and was going to make a set out of wood. Hasnt happened yet, but i do have the tracings.
mk
Old Feb 27, 2008 | 01:11 AM
Big Dave's Avatar
Big Dave
Nope...they're the same.
Old Feb 27, 2008 | 01:43 AM
BC's Avatar
BC
Brendan,
Since they are the same per Dave, then I would love to borrow them. But it would only be needed, probably AFTER you used them.
